Thata what I am aiming to do. However I need to get the motorhome home and it now won't start.That white clip hinges on the centre of the multiplug and pulls the plug and socket tightly together with a "camming" action. I would think a scrap yard would be your best bet but you may be able to jury rig something up with cable ties in the short term ?
Jev is the fuel pump on some Fiats not in the tank itself?I met up with Vanbitz 'junior' at a show earlier this year and shared my pics and method as Ash still has a steady stream of people asking Vanbitz for help.
The simplest solution is to change the fuel pump for one withOUT the immobiliser chip. But a lot of people seem to want to try the surgical removal route. I didn't have much choice being on a relative's driveway blocking their access when my intermittent fault became permanent.![]()
So even with the plug pushed and held in, the engine still won’t start. If that is the case it increases my dubious thoughts about the diagnosis.Thata what I am aiming to do. However I need to get the motorhome home and it now won't start.
Latest diagnosis is power is going into the ECU but not getting out. Currently on a flatbed being brought home.So even with the plug pushed and held in, the engine still won’t start. If that is the case it increases my dubious thoughts about the diagnosis.
SortedLatest diagnosis is power is going into the ECU but not getting out. Currently on a flatbed being brought home.
Anyone know a good mobile mechanic in Milton Keynes?
So joining it fixed the fault ?No it was in the middle of the loom.
Correct. It powered a relay that was cutting off the immobiliser i think.So joining it fixed the fault ?
How did it get cut in the middle of the loom, looks like a clean cut
Hi Eddie if your still here I really need this help please. I've emailed you a copy of V5 from k1200skm@gmail.comIf anyone gets this, if they email me a copy of there V5 I’ll post a crib sheet explaining how to by pass the Fiat immobiliser
Hi sorry I stopped work last year and no longer have access to my filesHi Eddie if your still here I really need this help please. I've emailed you a copy of V5 from k1200skm@gmail.com
Eddie retired. Whoops, he beat me to it.Hi Eddie if your still here I really need this help please. I've emailed you a copy of V5 from k1200skm@gmail.com
Oh ok understand thank you.Hi sorry I stopped work last year and no longer have access to my files
Hi I only recieved two black keys when purchasedOnly have a blue key and a black one
I can only guess that the wire was under stress in the loom and eventually snapped.
I ssume that the outer stetched and didn't break with the inner core as the break down guy got it going by effectively just moving the wires. He thought the problem was with the clip which held the socket into the ecu, which although was broken still held it in ok.
There were a couple of othe wires that when I was putting the loom back would have been under stress if you weren't careful. I assume it was that way when manufactured in 2007
Perhaps try AshVanBitzThanks, saw the offer before finishing the thread and am in a panic! Have 2 days to move the the vehicle and struggling to get help.
Hi Eddie will this crb sheet cover Fiat Ducato diesel 2006 / 2007 please ? NigeIf anyone gets this, if they email me a copy of there V5 I’ll post a crib sheet explaining how to by pass the Fiat immobiliser
Sorry to be the bearer of disappointment but Eddie has retired and no longer has access to the files.Hi Eddie will this crb sheet cover Fiat Ducato diesel 2006 / 2007 please ? Nige
Error reply. Sorry!Eddie doesn't want to offer a solution to a criminal? Just trying to check You actually own the problem vehicle?
He helped me on a 1999 2.5tdi some years ago.
I can help too for Funsters if local (Peterborough). It is an easy process but fiddly !
I have the knowledge but usually only to known, signed up members of FUN.Hi Eddie will this crb sheet cover Fiat Ducato diesel 2006 / 2007 please ? Nige
