- Oct 16, 2008
- 16,414
- 97,639
- Nearly aint got one.
- Caravan & motorhome 45 + yrs
You have made great progress
Next time you come mate.... you will have some where to sit proper like...
Not on some old packing cases...
Have you considered a french drain?Having to rethink for the moment the "Hard Standings".... the field is like a bog.... not a very well draining one like the other one in Dorset..
Not draining very well at all... puddles every where...
A happy peaceful Christmas to you both in your cosy new home.
Trouble is the field is pretty flat, and all seems to suffer...
And not really got any low point`s for water to drain off into...
Locals say it has been particularly wet this Autumn.... so case of wait and see..
Or build 5 hard standings on stilt`s......
Thanks for your suggestion..
Probably end up with a full draining ditch from your neighbouring properties
If it helps Old Fella, the spec sheet for our Winnebago , shows an exterior width of 8ft 5ins, not including the mirrors, but they are way up anyway. You are right it would have to be hit straight on, but theoretically it would work. Perhaps to facilitate things you could just make one post removable, for as and when required.
I know how desperate you are for us to visit and the kudos from having such a magnificent motorhome at your likle CL. But that aside we both appreciate all your efforts on our behalf.
Never a truer word said...
The next field up from us, which is a foot or two higher than us....
I`m sure his water must run into our field... (Can I Sue him..)
And the field down from us is the same level as our`s...
Regretfully, ours does not, but this one does.
So when can we start booking Mo looking fabulous and well done to you guys
looking very good mo you done well
heron bow into soak away does work use on football pitch
