bigtree
Or a nearly new Concorde.you can buy a real house for that much money
And all along you boast about how much younger you are than everyone else on here.Old age and arthritis starting lol...have never been able to kneel for any length of time ...but worse now ...and back sore with pulling these floor boards up ...me body is aching lol
In one of your photos I saw a welding plant.Do you have your own welding plant? Cause if you do i could have a job for you. . wouldn't be able to make it up elsewhere i dont think ...it needs to be built actually on to the van in section's
You said you were a coded welder.I currently don't have a guy on site lol...just me ...struggling to find a blacksmith or welder ...ive spoke to a few most dont want the work they seem to like easy stuff
Thats half the problem as most welders round here dont have big enough workshops to get it inside and many wont work outside. Bodywork welders dont want the heavy duty jobs and blacksmiths dont want the panel work jobs . The framing is 4/5 mm steel that needs a heavy welder. I thought id found a blacksmith to do the frame but he does all the local authority work so is very busySee I'd easy help but I haven't worked on autos. I'm used to structural stuff so thick steel at high-ish power. I can't see why a local welder wouldn't want to take it on though. It's still drivable aint it? You could easy get it in to their workshop which would make it a lot easier for anyone.
Yes because i have a welding plant. But its only a 160 and for the heavy frame it needs to be a bigger machine.In one of your photos I saw a welding plant.
I amYou said you were a coded welder.![]()
I am younger.And all along you boast about how much younger you are than everyone else on here.![]()
I feel your pain, no more tiling floors etc for me.I am younger.
Doesn't mean i dont get sore joints though eh ...both legs and ankles broken at age 20 didnt help ... years of crawling around on cold ground under motors didnt help either. And nearly 3.5 years of no physical work means most of my muscle turned to fat![]()
Right, I know I'm going to be shot down in showers of sh!!t but I know nothing about welding. Is it not possible to hire a welding M/c.I am
But i dont have heavy duty machinery and to buy it to do one job would cost as much as getting someone to do the job
I haven't done heavy steel work in nearly 15 years
Im just out of shape to be honest ...will be fine ...just kneeling on cold metal in cold and damp probably not the best ..ive ordered some padded knee padsI feel your pain, no more tiling floors etc for me.
Take 2 days off, let you rbody adjust and get back to it, it will be far less pain.
Those 2 days will make so much difference, and if you can do it again a week later even better.
the body is a wonderful thing
See 4/5mm is thin stuff to me. Only time we ever weld that is for gates and doors. Any sketches of what you are planning for it? Hard to judge what it needs.Thats half the problem as most welders round here dont have big enough workshops to get it inside and many wont work outside. Bodywork welders dont want the heavy duty jobs and blacksmiths dont want the panel work jobs . The framing is 4/5 mm steel that needs a heavy welder. I thought id found a blacksmith to do the frame but he does all the local authority work so is very busy
What is required isn’t heavy duty.I am
Stop whining, hmm, have I said that before.I am younger.
Im crap at drawing ...next time youre passing pop in for a brew and ill show youSee 4/5mm is thin stuff to me. Only time we ever weld that is for gates and doors. Any sketches of what you are planning for it? Hard to judge what it needs.
I did ....but it falls through gaps in floorAs for the knees, I thought the old bus seat in a lot of the photos was one you had kept behind as a mat to kneel on.
The frame for the bike is heavier than the machine im using . My machine would need to be up at full and will constantly cut out trying to weld thick steel.What is required isn’t heavy duty.
It still isn’t heavy duty, I worked in the truck manufacturing industry.The frame for the bike is heavier than the machine im using . My machine would need to be up at full and will constantly cut out trying to weld thick steel.
Its heavy duty compared to 1mm body panels.It still isn’t heavy duty, I worked in the truck manufacturing industry.![]()
Did I say body panels ?Its heavy duty compared to 1mm body panels.
I welded train chassis and tank simulators![]()
No you just pointed out the obvious that there was a welding plant in the pic.Did I say body panels ?
Can’t say I ever saw chassis’s and axles made with 1mm plate.![]()
You implied all we made was cabs.No you just pointed out the obvious that there was a welding plant in the pic.
But i already telt ye its nae bloody good for heavier steel .
Yer being pedantic
I never implied anything as this thread isn't about you or what you welded.You implied all we made was cabs.![]()
We had noticed.And nearly 3.5 years of no physical work means most of my muscle turned to fat
To be honest the chassis is pefect all the way from front to rear. Its just the sills thats knackered at the back. A the floor bracings are good too the only really rusty bits are the bits the bus converters added or altered as they left them bare steel with no paint or protection on them. Im just cutting those parts out completely as not required.We had noticed.
Front end of the chassis looks so much better must give you more confidence in the van.
In a van that size well worth keeping the rear heater got to keep the pouches cosy.
