Northernraider
- Jul 30, 2017
- 34,938
- 260,797
- N&B Flair 8000ib
- AirOn and off since 95
So after a good few hours messing around with mums brakes i had an hour spare to go out for a nosey in the van ....its filthy thats my first observation and its a little rough and ready when you get past the innitial tidy looking interior. The toilet / shower compartment is pretty grim at the minute ...the tray is knackered the toilet is well used and a bit past it , the walls are plastic wet board but the glue holding them to the walls etc has failed so they need reattached. ...so a bit of work needing done in there.
Eberspacher airtronic d2 works ok ...had it running a good 10 minutes or so , gas fire does light...not sure how good it is , hob, oven and grill all work , shurflo pump works but no water in it , all lights work , theres a truma 10l boiler the same as fitted in the caravan that works on gas or 240 ...the fridge ive not fully investigated yet but freezer door is broken so that needs new catches , 2 x leisure batteries ...the wee windows are showing green I've not put a tester on them or that yet to see voltage or if the split relay works etc ...not sure how he configures the cushions to make a bed up ...theres a compressor in beside the batteries which works of a switch but not sure what that does .
I scored a very large very heavy garage type trolley jack as that was under the rear seat ...he did tell me there was a jack there but didnt expect one so big .
So the basics work ....
I took some pics once id taken the spare wheel and jack etc out .
