Ask him if he got it a Wales, if so he beat me to it.We have a gorgeous Vario parked beside us atm.
2013 van in claret red and pristine. This will make you sick (did me), he bought it 4 years ago for £6k
He may have? I'll ask when we next speak.Ask him if he got it a Wales, if so he beat me to it.
Silly question how do you load the bike up onto the ‘patio’
Not decided on the lights for it yet ...but ill probably make a bracket and just fit some led lamps with a trailer socket.What are you doing about lights when it is fitted? Trailer board fixed to it permanently with a 7 or 13 pin socket?
Good work, going in the right direction now.Quite chuffed with what i got done today. Got the other seat support rail cut out , the rusted wheel arch covers cut out , most of the floor supports buffed up and derusted. And one side panel put in to red oxide primer. Will get the other side painted tomorrow and perhaps a start on the floor rails. View attachment 507178View attachment 507179View attachment 507180
Yeah ...the bus converters put zero protection on any of this so im just hoping to prevent more corrosion in the future .Looking well. It may be the boring never to be seen again bits but you will know it’s done right. Bravo.
All of the above. The red primer contains zinc phosphate. , The sides will be left with just that , floor gets 2 coats then hammerite on top. Ill inject all the sills etc with waxoyl once the welding is completed. ... Underside will be stone chippedWhat rust protection are you planning?
Zinc? Hammerite? Waxoyl??
Cheers James
That tooThe biggest rust prevention you can take is stay away from salted road countries in winter![]()
I have to admit the wiring for the batteries is a little confusing....the ones you can see in the pic is only half of them theres more inside the seatbox with a buzzbar and heavy fuses.. and the pos and neg are both blackLooking good, I hope you can remember how it all goes back together![]()
Behave yourself ...yours is nearly finishedWith my fix or repair daily transit needing a dpf- I'm so jealous!!!
Cheers James
Lol at the minute i cant see this vario taking me away over winter. But you never knowChop chop, winters coming!![]()
You need Uncle Lenny to come up and stay over for a few days. Just find him a FLT spot nearby and do what he says!!I have to admit the wiring for the batteries is a little confusing....the ones you can see in the pic is only half of them theres more inside the seatbox with a buzzbar and heavy fuses.. and the pos and neg are both blackeverything is fairly basic stuff.
Can't decide whether to take the wheel arch of that front side and risk finding or creating more holes or whether to leave well enough alone as it looks and feels fairly solid under there.
Im saving uncle lenny for the real headache to come later when i try to fit the electricsYou need Uncle Lenny to come up and stay over for a few days. Just find him a FLT spot nearby and do what he says!!![]()
But it's no good it doesn't run!Behave yourself ...yours is nearly finished
I dont think so ...the beauty of these are they are pretty basic.But it's no good it doesn't run!
Does your have a dpf?!!!
Dumb idea!
Cheers James
You missed no catalytic converter
Aye it looks that way with city centres .. but then i dont often go in to city centres with the van anyway.I listed most of those off Tam to my mate as ours is Iveco 2005, common rail so not quite your list.
My mate said”You have missed a ‘no’ off””
“Which one I said”
He said “No driving in any built up areas soon.
