Lenny's Modding the new Mini Gin Palace 2
No holes for the Heki they fit by the inner and outer frame clamping together.
If you fit the Heki frame & blind on the inside over the Maxxfan like I did it makes a much neater job.
Well, my “heki” is a Remis Remitop Vista, which has a smaller inner frame compared to yours and Maxxfan’s. It would appear awkward unless I trim the Maxxfan’s part or find another inner frame (which would likely be costly). By the way, is Maxxfan’s inner part (garnish ring) bright white, not beige or anything similar? Thanks!
I can see the connection to the battery but can’t find where they have picked up the ignition feed and obviously don’t want to short the two together. Will have to have a better search. I have some 80a vehicle relays kicking around though. It will be better weather when I get back to crawl arround under the van.
Probably put one of the piggy back fuseholders in the fuse box by the steering wheel.
Anyone one who has been in my van will know my party trick of shutting them in the washroom to see if they can get out. 90% fail and are trapped due to the silly small knob on the inside and a really strong spring on the latch.
Problem solved, it's just about passable, I'm finding this 3D design & printing lark a slow long learning curve.
View attachment 1020831View attachment 1020830
We've got a proper handle, which fell off when we were away.
No small knobs inside when I’m in the shower…😆😉
You sure you got the spare payload??🤣🤣🤣
Electronics mostly.
I hope your not like my mate, whatever he buys he has the back off it to see what's in it.😁
When he fixed our Stirling inverter he said this is not Chinese it's put together well, can't remember his guess might have Malaysia or similar. :rofl: Bob.
I’ve always thought - if folk wanted of course - to put what their speciality might be on their avatar panel - i@Jim did it. Then like Lenny HB could put Electrics - others might put Law
, Plumbing etc. then when somebody actually asked a question, they would know that that person was more than likely be talking sense, as opposed to someone like me who knows nothing about electric putting my oar in.
I seem to recall many years ago I think it was on the other MHF where there was some guy who thought he was a legal type person that was giving out wrong information, but if you don’t know the person you don’t know that that information is incorrect
Just my thought, sorry Lenny to interrupt your thread
Does Barrack Room Lawyer count as there seemsto be a lot on here🤣🤣🤣🤣
Mine would be blank !
Finally got around to fitting the Ablemail battery maintainer that I bought over 6 months ago, I can now keep the starter battery topped up if I isolate the Multiplus. Also fitted a switch between +12v and SW2 so I can turn it on regardless of battery voltage, useful in winter when not much solar or if I have turned the solar off in summer.
Fitted the rest of the bits in the garage for my Pi install, made a bracket for the shunt display, I don't need to see the display that is why it is in the garage and made connections easier, need it for the programmable relay.
Made a case for the UART hub that is now fitted and wired to all the Victron gear & the dongle for the Multiplus fitted.
Not happy about the mess of cables on top of the electrics cabinet, I'll try & do something with that when everything is up & running.
All your work looks neat to me! Worst bit on mine is the huge amount of spare loom Carthago left folded on the battery box and trunking! But to be fair it all needs a tidy......
Can I ask what are you going to use the shunt's programmable relay for, Lenny?
To control the S+ on the fridge via the timer I've fitted in my panel. So when I have fully charged batteries and plenty of solar the fridge will run on 12v.
just about to say why, your solar controller can do that, but you've gone to the dark side from Votronics to Victron.
Victron much better with Lithium & Votronic 430 had problems with Lithium.
