- Dec 31, 2010
- 3,069
- 7,462
- Frankia Platin i7900
- Since 2010
Did you know the 180 2.3 engine is quite different from the others that's why you pay a premiumOooh hello…… all of them 2.3L![]()
No I didn’t, the only thing I know about the 180 2.3L is……….Did you know the 180 2.3 engine is quite different from the others that's why you pay a premium![]()
Out of interest, as you own the relevant software, Have you recalibrated the clutch?So I now have a working scan thingy thanks to Gendan Automotive. Multiecuscan is throwing out the attached error:
Basically, something is broke![]()
I don’t believe you have anything broken.Nope haven't tried that recalibration thing. The software says gearbox temp needed to be over 20 deg, but was only 9 deg.
But I'm now quite wary of making anything worse when I don't understand what I am doing and realistically don't know if it is safe, or not to run that command, or others. If there are bits broken mechanically then I'll be increasing damage. If electronics calibrate incorrectly, could those then damage the mechanics? It must be remembered that this has all started a week or so having been towed off a muddy pitch, and then also after the can had been driven in short hops on and off ramps. This could easily have put unexpected forces into the gearbox / clutch, which would correlate to the broken thingys in the links above.
I'll have perhaps one chance to start it and get it to go into gear to get it to Adams Morey. If I can't drive it I'm going to have a really expensive challenge of some form of recovery transport. I'm at the point of accepting fate, and cost and having booked in with people who I believe should be trusted, must await what they come up with, otherwise I'm chasing in ever increasing circles and expense on parts and stuff.
Its not a bad suggestion, but how ridulous that you have to tell your gearbox that it has a clutch etc to try and coax it into a gear, and seemingly comfortmatic drivers are going to be happy with any gear as long as the effing things starts moving againOut of interest, as you own the relevant software, Have you recalibrated the clutch?
According to that post on the Fiat forum, it’s a thrust bearing sensor. Following with interest.
True but like the Golf the gear change is smooth, fast and very comfotable weather toodling or going for it.They haven’t been without their issues either.
It’s horrible you’re going through all this, but thanks to you, this thread and the handbook Jim posted (in another thread I think), this is a really valuable resource. My hubby imagines all workshops to be equal and doesn’t look at any forums, but this one again proves the value of a great band of users. Thank you MHF and Kannon Fodda. Let’s hope for good news in your next.Nope haven't tried that recalibration thing. The software says gearbox temp needed to be over 20 deg, but was only 9 deg.
Can you not get that done under your breakdown cover?Recovery transportation (flat bed truck) now arranged for unfathomably early on Monday AM. My wallet is not going to like me![]()
A FH 750 with I shift would do nicelyI shift is definitely the best, shame you cant get a v8 Volvo though![]()
You can't insure an event that has happened.Is there insurance you can take out to cover the cost of repairs?
2019, 17,000 miles. Depending on what Adams Morey find I'll be contacting Fiat but won't hold my breath.How old is the van and what's the mileage, it could be well worth contacting Fiat as the problems with Comfortmatic gearboxes is a well known issue, if it is fairly low mileage try the "unfit for the purpose it is intended" path (it worked for me and Fiat accepted the cost of the repair)
But you wouldn’t have to pay transport to a specialist garage to fix it though.Hope you get it sorted for a reasonable price.
Manuals aren’t immune either, Lucy’s car just had to have a new clutch, £1000.![]()
Don't give up hope, mine was also 2019 at 10,800 miles when it failed, it was pretty much the same symptoms as you described.You can't insure an event that has happened.
Even if it had yet to occur im not sure where you would look for such cover. Even second hand vehicle dealer warranties have loads of exclusions and get outs that make them useless.
Unfortunately although I took out a service plan with hab checks (first van bought new I had no idea) called "silver" with the mh dealer which covered last three years, and they were supposedly recognised by Fiat, I now find no record that it will have included even the basic required 2 year fluid check on the Comfortmatic. Hard lesson learnt that these service plans that say major minor aren't always adequate and are a licence to the supplier to do what they want rather than what you need.
First thing I do when starting the engine is turn the stop/start function OFF, it's a pain in the butt.So there I was sitting a queue to get into 3 counties showground yesterday in my Car ( unavailable as a manual) ticking over for well over half an hour, and I realised that last time I was in a long downhill queue I was in the Mh (manual) and I turned the engine off and coasted. Off course the modern answer to this is stop start and every time we moved I could hear the starter motor of the golf behind me and wondered how many times that would happen before it
I'm sure if you set your mind to it you could rig something upI have no choice but an auto….![]()
Whats different? My Fiat dealer said they are all the same just software difference to give higher output.Did you know the 180 2.3 engine is quite different from the others that's why you pay a premium![]()
Crankshaft, pistons, turbo its quite a different motor hence the cost difference.Whats different? My Fiat dealer said they are all the same just software difference to give higher output.
