Nanniemate
- Oct 1, 2019
- 7,548
- 52,354
- IH
- Still dropping clangers and making it up as I go along
Rob do you not have home start on your breakdown service ? Try it Sunday if it won't start call them out and get it delivered to your chosen garage it will be there for Monday morningNope haven't tried that recalibration thing. The software says gearbox temp needed to be over 20 deg, but was only 9 deg.
But I'm now quite wary of making anything worse when I don't understand what I am doing and realistically don't know if it is safe, or not to run that command, or others. If there are bits broken mechanically then I'll be increasing damage. If electronics calibrate incorrectly, could those then damage the mechanics? It must be remembered that this has all started a week or so having been towed off a muddy pitch, and then also after the can had been driven in short hops on and off ramps. This could easily have put unexpected forces into the gearbox / clutch, which would correlate to the broken thingys in the links above.
I'll have perhaps one chance to start it and get it to go into gear to get it to Adams Morey. If I can't drive it I'm going to have a really expensive challenge of some form of recovery transport. I'm at the point of accepting fate, and cost and having booked in with people who I believe should be trusted, must await what they come up with, otherwise I'm chasing in ever increasing circles and expense on parts and stuff.
