The cost of the new slave head and clutch replacement is about £1800.Did they give an estimate of the bill?
And the new ECU?The cost of the new slave head and clutch replacement is about £1800.
Then labour I assume….
Wow would that price not include Labour?Then labour I assume….![]()
Not sure as we sort of dismissed this as it was not as conclusive as the other two. It was not a clear diagnostic reading.And the new ECU?
It includes labourWow would that price not include Labour?
It includes labour
We've had this problem, suggested we may need to have new slave cylinder and clutch due to dirty fluids with plastic springs being damaged. Diagnosed in Inverness.Hi all, good to find a current discussion about the ComfortmaticA lot of what is floating about is very old and I would hope things have moved on over the years (Or maybe not)
I have a 2018 Ducato 2.3 150 based motor home and have the dreaded Gears not available,
Finally managed to get the error codes off the gearbox and have the following:
P2919-64 - thrust bearing Signal/message plausibility
Am I looking at a faulty sensor? Plastict bits floating about off the Clutch plate? or something else? and if it is the plastic bits is there an option to work around the problem other than replacing the plate? I saw maybe early in this tread someone saying that as it is the same gearbox and clutch as in the standard manual if you can force the sensor to ignore the problem for a bit the plastic bits get broken down and stop being a problem as they would in a manual,
I recently booked mine into Camper UK for a major service. It is five years old when the service is due. The comfortmatic system has never been touched so I asked them to change the actuation fluid as it should have been done at four years. They said they won’t touch it unless there is a problem as doing anything causes more problems.We did challenge this and asked her to double check, as well as questioning it under a service. The answer was still no.
I’d be interested to know if anyone has had theirs done at Camper UK?….
I imagine they're afraid to touch it incase something then goes wrong with it and they get the blame.I recently booked mine into Camper UK for a major service. It is five years old when the service is due. The comfortmatic system has never been touched so I asked them to change the actuation fluid as it should have been done at four years. They said they won’t touch it unless there is a problem as doing anything causes more problems.
Could be but perhaps they should be more worried about getting the blame for missing out a specified part of the 4 year major service i.e. replacing the clutch activation fluid.I imagine they're afraid to touch it incase something then goes wrong with it and they get the blame.
I would ask for that in writing so that if the clutch system fails for want of doing one of the specified service items you can expect them to put it right. Bear in mind if it does fail it usually takes out some very expensive components with it and you can add an extra zero to the bill.I recently booked mine into Camper UK for a major service. It is five years old when the service is due. The comfortmatic system has never been touched so I asked them to change the actuation fluid as it should have been done at four years. They said they won’t touch it unless there is a problem as doing anything causes more problems.
I would have thought asking for that kind of guarantee they would become too busy to fit the vehicle inCould be but perhaps they should be more worried about getting the blame for missing out a specified part of the 4 year major service i.e. replacing the clutch activation fluid.
Had my service there a few months ago (don’t even ask) and they told me the same thing about the comfortmatic, so I booked it in at adams Morey and travelled down to Portsmouth from Yorkshire to let the experts do itI recently booked mine into Camper UK for a major service. It is five years old when the service is due. The comfortmatic system has never been touched so I asked them to change the actuation fluid as it should have been done at four years. They said they won’t touch it unless there is a problem as doing anything causes more problems.
Or they might decide to do the job properly in the first place. I bet they use the standard Fiat times for their charges and don’t make a deduction for leaving out the bits of the service they don’t like doing.I would have thought asking for that kind of guarantee they would become too busy to fit the vehicle in
Latest from Camper UK regarding servicing my four and a half year old comfortmatic after I queried the actuation fluid change requirement:-
Apologise, I have been trying to get to the bottom of this for some time for you and I finally have an answer.
So, yes on one hand you are correct however, the way it is worded is not quite correct and most manufactures do change their processes as time goes on so the booklets although at the time are correct but after that may not.
Long and short of it is the hydraulic fluid is to be checked every 2 years and topped up if required but then changed every 6 years or 90 thousand miles which to be honest most motorhomes never see.
The above has come from Fiat and the service packages we have to do and means your vehicle will be due its change next year.
I hope this answers the question and puts your mind at rest on the matter, I have also learnt something as a result of my investigation and will put it to good use going forward.
Then why does it say change fluid at 4 years in the service schedule listed in the handbook? My Comfortmatic is also 4 and a half years old and Adams Morey changed it last year at its 4 year service. What does your Fiat Ducato handbook say (not the old separate Comfortmatic book which has been superseded).Latest from Camper UK regarding servicing my four and a half year old comfortmatic after I queried the actuation fluid change requirement:-
Hi.Latest from Camper UK regarding servicing my four and a half year old comfortmatic after I queried the actuation fluid change requirement:-
Are you going to ask for an earlier change than they deem necessary?
No, I don't think so. If that is what Fiat recommends.Are you going to ask for an earlier change than they deem necessary?
My handbook says the same as yours. I assume Camper UK are correct when they say Fiat now says 6 years, unless anyone can show this to be incorrect.Then why does it say change fluid at 4 years in the service schedule listed in the handbook? My Comfortmatic is also 4 and a half years old and Adams Morey changed it last year at its 4 year service. What does your Fiat Ducato handbook say (not the old separate Comfortmatic book which has been superseded).
I have no idea where the new 6 years comes from and if I were keeping my Comfortmatic I would be getting the fluid changed more often than the stated 4 years, not less often. I have still got 6 months to run on my 5 year warranty so keeping to the published service schedule last year seemed like a no brainer for me. I would be saying to them that I had paid for a 4 year service and it should have included the fluid change so please put it right. If they declined or wanted to charge for this I would put them on notice that in the event of a Comfortmatic failure I would hold them responsible.My handbook says the same as yours. I assume Camper UK are correct when they say Fiat now says 6 years, unless anyone can show this to be incorrect.
