That’s a relief for you. They’ve always got to squeeze something out of you though.
I know this was a few months ago but having had almost constant problems with the Comfortmatic I am amazed there isn't much mention of the plastic parts in the clutch plate that break & cause most of these problems? As you put:Wohoo. I have my van back, and it's working
The diagnostic software showed a sub system error of engine and clutch speed mismatch. Effectively the clutch was not disengaging. Bleeding the clutch fluids alone did not clear the fault, indicating mechanical problems.
The clutch fluid was contaminated (this is the brake type fluid that operates the clutch cylinders, not the separate hydraulic type oils that move the gear change).
The master cylinder internal seals were degrading (part of the contamination above). Master cylinder has been replaced.
Clutch itself also failed. The buffer bushes were found to be broken. The clutch (not flywheel) and slave cylinder have been replaced.
The electronics have been reset and recalibrated.
Fairly costly exercise especially the master cylinder form thingy. But Simon Potter, Adams Morey Portsmouth has tried to lessen the load especially on some of the labour. Overall, especially as I also had them do the 4 year service, there has been a bit of a discount. Even so the piggy bank is overdrawn.
For future maintenance there is a strong recommendation for frequent changes of the clutch fluid, even on an annual basis, despite relatively low mileage of motorhomes. Changing the fluid needs to be able to bleed the clutch and as that is operated by the Comfortmatic system, rather than a manual clutch pedal, the garage does need the diagnostic software - Multiecuscan might well suffice for non Fiat Professional systems. May explain why some motorhome dealers like mine don't go anywhere near it. Having checked / changed fluid some calibration routines are desired to allow for the minor wear that takes place from year to year.
At 3.5 years, 17,000 miles failure shouldn't really have occurred. Difficult to say from the things that needed attention which bit broke first to then cause issues with other bits. With the fluid contaminated, inevitably that hadn't been checked / replaced when the manual says it should have been looked at after 2 years. The pants service plan I had been given by the dealer up north had amounted to little more than an oil change.
Difficult to say what could be done to avoid the problem, or prevent it. One key area seems to be trying to avoid holding the vehicle on the clutch, on hills, and particularly on /off leveling blocks. It's notable that when this failed, although it was probably already failing, in the previous week I'd been stuck in mud, and then it had been on and off ramps where I was having stuff fitted underneath (nothing to do with Adams Morey).
All I can do for future is to drive normally, trying to avoid poor behaviours such as any holding of van on clutch rather than brakes, neutral if stuck in queues at lights, and then a good servicing regime.
There is a Dutch website with loads of complaints about it:Clutch itself also failed. The buffer bushes were found to be broken.
Well just back from a bit in France then switzerland, and back through the fatherland, 45k now and the comfortmatic just seems to get better with the miles on itDid the Slovenian, Austrian, Italian and German alps last year on my run down to Croatia and back with my Comfortmatic and like you, zero problems
Wish I could say the same with the Pia airbag light![]()
ExcellentWell just back from a bit in France then switzerland, and back through the fatherland, 45k now and the comfortmatic just seems to get better with the miles on it
Don’t fix what’s not broken!!Excellent
It’s always better to have the new clutch fitted before the old one gives up.![]()
Id get 150k out of this clutch If I kept it that longExcellent
Yes they do need access to the port to do it correctly.Quick question folks, does anyone know if access to the OBD socket is required after a clutch oils change?
I'm having mine done at Adams Morey in Portsmouth tomorrow and my OBD port isn't "standard". I did ask them but no one could give me a definative answer at the time.
Thanks for that, I just hope they are aware of all that info.Mine has a lock on which I removed before it was loaded onto the lorry.
They have to tell the ecu to power up. Then the program moves the actuators to purge air. Finally they should do a clutch position relearn via the software. Not doing it right or in the correct order risks air in the pipe that will blow out the seals on the slave cylinder and spray clutch fluid onto the clutch.
This is why most garages won't do the fluid change.
Adams Morey Portsmouth seem very knowledgeable about Comformatic clutches. Panic not but it sounds like you do need to make sure they can access your non-standard OBD. What have you done to your OBD?Thanks for that, I just hope they are aware of all that info.
Not nervous at all.![]()
They should be now. The Southampton branch messed up on mine last year hence fixing it under warranty this year. The Portsmouth branch seems more motorhome friendly as the manager there was a motorhomer. He is now regional manager according to the Bournemouth branchThanks for that, I just hope they are aware of all that info.
Sorry to hear this club is expanding fingers crossed you get home smoothlyWell, annoyingly we've joined the club. We're near Inverness having done NC500, most of it but having gearbox transmission problems. Had a Diagnostic test in Inverness and been told its a fault code P 2919-64, possible failure plastic cover springs, advise new slave cylinder and clutch replacement.
Estimate £1,735.
I and management despair. We have cancelled our forthcoming bookings at a cost and will endeavour to get back to Devon without breaking down.
I can't believe Fiat make such crap, our 2nd massive Fiat repair cost in 1 year.
What enjoyment can we get out of motorhoming when these problems keep occurring.
Pi@@@@d off to say the least. Living the dream has become a nightmare.
If this was the USA there would be mass litigation, there is always the odd problem with cars, but the number of problems with comfortmatic gearboxes on just this small forum is unreal, can you imagine how many break down Europe wide, FIAT should really be forced to pick up the bill for this as the comfortmatic is simply not fit for purposeWell, annoyingly we've joined the club. We're near Inverness having done NC500, most of it but having gearbox transmission problems. Had a Diagnostic test in Inverness and been told its a fault code P 2919-64, possible failure plastic cover springs, advise new slave cylinder and clutch replacement.
Estimate £1,735.
Estimate sounds good value as they need to take the wheel/hub assembly off to access the bellhousing. It's a lot of work. New dual flywheel/clutch, often replaced at the same time, isn't cheap either.Sorry to hear this club is expanding fingers crossed you get home smoothly
They've only dropped to Comfortmatic because they can now cram enough gears into the slush box to come close to the inherent efficiency of the stick shift boxes.There could be a good case for taking legal action against Fiat as they have dropped the Comfort-Matic completely . . If that isn't admission as unfit for purpose I don't know what is !!!
(If it's any consolation the 'new' 9sp auto appears to have solved all the issue)
I don’t really think you can say it’s unfit for purpose without having the figures to back it up, ie all the comfortmatics that’s run with relatively few problems and those who break down and the reasons for the breakdown. As for replacement with the 9 speed that’s just progression, not an admission that the comfortmatic is useless.There could be a good case for taking legal action against Fiat as they have dropped the Comfort-Matic completely . . If that isn't admission as unfit for purpose I don't know what is !!!
I just waded through a lot of this Dutch thread. What are plastic clips doing in a clutch? Must be a recipe for disaster. So many of the contributors have had these plastic clips break up. Members on that thread seem to think that there was a change of something when engine went from Euro 5 to Euro 6 and that 2017/18 and early 19 more at risk.know this was a few months ago but having had almost constant problems with the Comfortmatic I am amazed there isn't much mention of the plastic parts in the clutch plate that break & cause most of these problems? As you put:
https://www.nkcforum.nl/topic/5-probleem-met-automaat-fiat-ducato-uit-2017/
Google translate will be your friend
My Ducato was built in 2014 I believe (2015 reg) 2.3 150HP and I am waiting to have it taken apart to find out if I have this clutch plate - I am getting fault code P2919-64 CSC fault - signal plausibility failure.
This is really helpful Riverbankannie. Cheers Smudger55I just waded through a lot of this Dutch thread. What are plastic clips doing in a clutch? Must be a recipe for disaster. So many of the contributors have had these plastic clips break up. Members on that thread seem to think that there was a change of something when engine went from Euro 5 to Euro 6 and that 2017/18 and early 19 more at risk.
A few knowledgeable garages in Netherlands get a mention. I might try and make a list from that and the German forum. Seems like we need to find the equivalent French forum to find a good garage there.
