I'm getting worried, it's all gone quiet !
Are you ok Ian?
Are you ok Ian?
all will disappear very neatly wrapped without hardly any mess to clean at all.
Hi Jenny & Mitch.IAN. If you try to light the gas WITHOUT first removing the cover, it will not light, OR it will briefly light and the pressure will blow the cover off !!
Its a safety feature because it is a vented flue, the exhaust is in the centre and the fresh air is drawn in around it.
Now you don't have to worry about taking it off first, because you've blown it to bits !!!!
A self solving problem !!
Mitch.![]()
That is scary Ian, as the float inside the bulk tank, or refillable cylinders should have cut off at the 80% fill.I mean the gauge is to the top of the red marked area!! Is this bad??? Could it be cause of problem?
But surely when the gauge says full it means to the 80% we have a gasit system with the gauge on the outlet at the top and that goes right as far as it will go, but it's only to the cutoff , don't know what type of gauge Ian has but if it's similar to ours , saying full doesn't mean it's over full.Hi Jenny & Mitch.
Ian's Truma heating system operates differently from the method you describe (Ultrastore/Ultraheat). There is no removable cover for the Trumatic C3402 and 6002 boilers, which can be operated with the boiler empty if preferred.
Can you confirm that it is a refillable system you are using, and not ordinary (non refillable) cylinders.
You are very lucky that you didn't have jets of ignited liquid gas coming out of your gas rings, and it's probably because the fridge is on 240v, (rather than on gas) that you have been lucky not to have damaged that too.
Please be careful if using the hob rings for heating, (not recommended) and burning off the excess gas from the system. If there is insufficient ventilation, there is a severe risk of being overcome by Carbon Monoxide (CO) which is a silent killer. I kid you not.
I personally wouldn't be happy using my gas appliances, knowing that the system has been overfilled (especially if a refillable system). Even ordinary cylinders are not filled to capacity by the gas company, eg, Calor, Flogas, Repsol, Sepsol, etc. They all require a 20% space for expansion, and for the LPG to gas off. Cylinders have a tare weight and a full weight, and the figure in between, is the weight of the gas, (1 x Kg = 2 x litres gas) which allows for that expansion space at the top of the cylinder, where the valve is.
Good luck, and stay safe.
Cheers,
Jock.![]()
Are you ok Ian?![]()
Hi Chaser,But surely when the gauge says full it means to the 80% we have a gasit system with the gauge on the outlet at the top and that goes right as far as it will go, but it's only to the cutoff , don't know what type of gauge Ian has but if it's similar to ours , saying full doesn't mean it's over full.
The possibilities that have mean mentioned (tank overfull, pressure high, liquid in pipes) would have been very, very obvious when you lit the hob. If the hob appeared to be normal then pressure isn't over-high. Most likely, as has been suggested, is a build-up in the boiler when it didn't light first time. You didn't have the removable (travel) cover on the flue did you?Ok
Ok tigger, but could that have caused the vent cap to have been blown off??
No he didn't, as I have explained in my post above Tony.You didn't have the removable (travel) cover on the flue did you?
Saw you this morning as we were going into Gibraltar - I recognised your numberplate from your avatar. Did you have a good day?all the crap i have had and am still enjoying it latest mishap washed my phone will try and get a cheap one in gibralter vodaphone is what they are advising dont look back keep going forwards,sights like this make it worthwhileView attachment 92483
Think it's suspiciously quiet, do you think Ian has been kidnapped by the Germans after him trying to blow up their awning![]()
TBH Ian, in the 11 x years we've been using the same heating system as yours, not once have we suffered the problem you had this morning. I hope it doesn't happen to you again.When I wake up in the morning I shall turn the hob on first to release excess gasses if any and all done !!!
.The possibilities that have mean mentioned (tank overfull, pressure high, liquid in pipes) would have been very, very obvious when you lit the hob. If the hob appeared to be normal then pressure isn't over-high. Most likely, as has been suggested, is a build-up in the boiler when it didn't light first time. You didn't have the removable (travel) cover on the flue did you?
I thought it had to be to do with overfilling. Glad you are sorted, with Gus's help.Me and gus have released a lot of gas now to halfway in the red and she has fired up lovely. Just a simple case of overfilling !! I am still going to get a new regulator though!!! When I filled it to 80percent last time all has been fine !!
