Somewhere there is a fantastic thread about peoples garages with lots of pics.......Andy.
That looks a great bit of kit and will be a bonus!
Also IHow immaculate and tidy your locker space is!!
Very nice... but does that mean you can now do this...
FYI Mick adjusted the angle of the brain on the under floor to reflect the fact that our van is nose down by defaultYes
Question to new owner, do you prefer auto or manual setting
Never worn off with meQuestion to owners
Does the novelty ever wear off?
NO. I have both full VB air and the jacks. If a quick stop or on reasonable flat pitch I just level on air. If on a very un-level pitch like here in Barcelona then I put out the jacks and even they may need pads to reduce the stroke. As an aside I think levelling is important to the fridge, so I always level if the fridge is on. I would say we use the jacks 50% of the stops we make. I bought the remote so i can use that to sight up the pad positions.Question to owners
Martin @funflair will give the SPCan you leave it in storage up on the jacks for a long period? Do you/would you keep the wheels off the ground?
Jacks will lift if handbrake is off I think.It's suggested leaving the jacks down when storing as it reduces stress on the tyres.
The only thing I'm concerned about is leaving the handbrake on for long periods, which may cause the pads to stick.
Maybe the trick is to extend the jacks, release the brake, then re apply the brake before turning on the ignition and raising the jacks
Only when ignition is turned on, and if all four wheels are off the ground I can't see that there is a safety issueJacks will lift if handbrake is off I think.
Thanks for the vote of confidence MichaelMartin @funflair will give the SP
On our IVECO chassis there are stops on the front and rear that take the weight of the hanging suspension so not worried about that.And the suspension hanging?
So we get level in auto baring the final tweek in manual if the ground is very uneven
Brakes on or off ?Spec of new Rams is stainless steel I think it says in the manual
Yes mine is jacked in storage but only to the extent that it is level , the tyres are on the ground but no weight in them
When you get that message David, switch to manual and get the van as level as you can - often virtually levelwe have had a quite a few attempts to deploy our jacks where they fail, due to 'uneven ground', I don't fully understand that message and the ground is often not that far out of level when we have had issues
It was worrying / annoying early on but I have now found that we can deploy the jacks in manual option and overcome the 'problem', just odd that the auto option wouldn't allow what turns out to be OK
we do love ours though, very easy levelling and totally stable when moving around or when windy, possibly more of an issue with the Mercedes Hymer wheels being quite a long way inset relative to body width
On Robert, they will retract with it off.Brakes on or off ?
Reading through the manual on the website I had the impression that you could release the handbrake once the ignition was off.On Robert, they will retract with it off.
Might be an idea to see how many clicks on it takes rather than full lock
