Hmmmm filled with nearly 40l gas, one is empty now and the yellow crash sensor button activated :-( (3 Viewers)
Oct 3, 2022
38
50
Hymer B564
Original post saying that you don’t turn the cylinders off when filling 😱😱😱
1 Dangerous 💥+ ❄
2. It’s illegal to not isolate gas tanks in a petrol station. 💥💥💥 it’s done for a reason ! That is safety.
I worked a number of years using LPG on vehicles and saw more than a few go up and when it does it’s always been because an operator hasn’t isolated the tanks before filling. Mix gas and large amounts of petrol and diesel and irt will make for a real BIG bang.
That said a reverse of a fire with LPG is the freezing factor it operates as a fluid at about -40 deg C so will burn thru flesh in a second or so and the flesh will not repair its worse than a flame burn.
Please take care with this stuff it’s not to be messed with.
PeterCarole29
1,287
1,386
Colchester
Renault Master Fleetwood
20 years
Original post saying that you don’t turn the cylinders off when filling 😱😱Thanks for that advice😱
1 Dangerous 💥+ ❄
Thanks for that advice especially the last bit i shall put a pair of heavy duty rubber gloves on when i fill up
32,848
67,154
I'd suggest some thermal lined ones rather than just rubber as that won't offer much protection from the 'cold' - mine have fleece linings, not perfect but better than just rubber.
PeterCarole29
1,287
1,386
Colchester
20 years
Thankyou. yes exactly what i was thinking off but forgive me i was being lazy in my description
32,848
67,154
One other safety tip, when releasing the gun do not bed over it but make sure you are at the side, when you release it there can be quite an escape of gas something you don't want to 'get you' in the face, not likely but certainly not worth the risk. If it does worry you though you could get a mask to go with your gloves, might get some funny looks though! :giggle:
PaulC70
May 8, 2021
1,649
3,157
Bedford, UK
Bailey Autograph792F
Since June 2021
Thanks all for the advice and warnings etc etc, been busy being out and about down here in Devon / Cornwall finding places to stay but also dealing with a few issues health and wife related hence the late reply.
In the end I just did what someone else had suggested ie turned on the "empty" which has been running fine for the last 5 days. So obviously not empty but definitely seemed so when tapping it with a metal key.
32,848
67,154
Tapping with a METAL key :eek: ... Think sparks ... Have you got a death wish! 😉
32,848
67,154
Minxy think you would be better taping it with your head if the tank is empty it’ll make the same sound as your head.
I have a certain reputation on here which I assume you're not aware of so will let you off this time but I have a lump hammer which would soon shatter 'ice'. >:) 😉
