kevenh
Road bikes have three tyre fit methods:
From Cycling weekly dot com
Edit: my MTB can be very muddy when it has a puncture. With my road bike it’ll usually be dry ?
Types of road bike tyre
I haven’t looked at going tubeless on my road bike. I may get around to it ?There are three types of bike tyres on the market – clinchers, tubulars and tubeless – they each have their pros and cons:
Clincher road bike tyres
First up is the clincher, the choice of the majority of road riders. This features a bead around the outside of the tyre which hooks under a lip on the rim, with a separate inner tube running inside. The main advantage of this system is convenience, with the inner tube being easy to change in the event of a puncture.
Tubular tyres road bike tyres
Next is the tubular tyre. With this design the inner tube is sewn into the tyre, with the whole thing then attached to the wheel using glue or rim tape. This is the choice of a lot of racers due to the generally lower rolling resistance and weight, but can be impractical when you puncture.
Tubeless road bike tyres
Finally you’ve got tubeless tyres. These are similar to clinchers, but with the tyre sitting firmly enough against the rim to hold the tyre’s pressure, eliminating the need for an inner tube all together. The tyre is then filled with sealant, which plugs cuts or gashes in the rubber.
This system greatly reduces the chance of punctures, although the snug fit that is required between the tyre and the rim can make tubeless tyres fiddly to fit.
