Gas it for me, and bottles so that we can swap/take with us if/when we swap the van.
I thought Safefil was only uk based so no good abroad but I could be wrong there.
No Asda - Morrisons have had any problems filling Safefill bottles. I've yet to have a problem in Europe getting them filled.As above. Gas It as it was cheaper. Local LPG supplier stated they would not fill Safefill when asked.
alugas, better made and lighteranyone got any ideas on the above ,got 2 calor 6kg atm going to Spain and would probably need a refillable type to be on the safe side.
Hi Tonka, got propane ATM Spain this year maybe France next so a refillable might be the best in the long run also it will work out cheaper to refill here.If it's only Spain your visiting then I would buy a s/hand bottle when you get there. Often sold on campsite noticeboards, Facebook groups etc.. gas exchange is far cheaper in Spain. Less than €15 I think for 13kg.
If you have calor butane now then all you need is the spanish "jumbo adaptor" sold on eBay and web sites if you have propane bottles then you also need a butane pigtail. Far easier way of doing it without all the expense.
you don't say what m/h you have for room just get 2 /6kg refillable gaslow or similar we have 2 /11kg bottles gaslow & take a repsol or cepsa spare bottle because you can exchange it anywhere in Spain . if you have an outside BBQ outlet you can use it this wayanyone got any ideas on the above ,got 2 calor 6kg atm going to Spain and would probably need a refillable type to be on the safe side.
So all in all you take 3 bottles with you , do you keep the spare bottle in your gas locker or rear locker/garage, thought it was not recommended to carry one in rear locker .we have 2 /11kg bottles gaslow & take a repsol or cepsa spare bottle because you can exchange it anywhere in Spain .
It's not something I would do personally but some take them for BBQs etc anyway, if I was doing so I'd sit it in a plastic tub taller than the bottle, the tub would be permanently 'stuck' to the floor of the garage and sealed all round the base with a drop vent going right through the tub and the garage floor.So all in all you take 3 bottles with you , do you keep the spare bottle in your gas locker or rear locker/garage, thought it was not recommended to carry one in rear locker .
hi . sorry late reply no we take French bottles when going to France & Spanish bottles to Spain as we go to Spain in the winter & France in the summer this is our French bottle . we do this so we have some gas in reserve & us it for BBQSo all in all you take 3 bottles with you , do you keep the spare bottle in your gas locker or rear locker/garage, thought it was not recommended to carry one in rear locker .
The Alugas are better quality and if you are tight on payload they are lighter but expensive.Does it matter which make? They all use the same gas.
I don’t agree with your statement that there can be no argument that refillable cylinders are the way to go. An underslung tank creates an empty locker, usually holds more gas, always has an external filling point, is very easy to fill up in various countries by having a few adapters and lowers the van’s centre of gravity. This to me at least makes underslung the way to go.The initial outlay for re-fillable bottles may be a hurdle for some people and if you are only visiting a single country, you could be better off using that country's exchange bottles. However should you enjoy travelling to other countries, there can be little argument that re- fillable bottles are the way to go. Does it matter which make? They all use the same gas.
We did the same thing, one calor, one gaslow.I chose Gaslow for the quality of their hoses - s/steel braided ones rather than unsheathed Gasit ones.
I kept one 6kg Calor and fitted a 6kg Gaslow - both permanently connected. I've found one cylinder is plenty abroad where LPG refill pumps are plentiful but if caught out I can switch temporarily to the Calor, although in 9 years I've never had to do that and I only tour abroad.
