Silver-Fox
About 15 minutes ago an f15 going over head heading to Chipping Cambden.
800 feet used to be the standard military drop.
It could probably be cut a few feet but there is absolutely no chance of a canopy opening in 150ft.
What would be used to break the fall I have no idea.
Actually, because it's Russian there's a trap in the floor you lift then someone walks it alongHere comes a stupid question.
If you are towing a tank, presuming there is a neutral for each track, do you need some “steering” it![]()
Can see how you got your forum name.Actually, because it's Russian there's a trap in the floor you lift then someone walks it along![]()
Thinking more about this … the RQ-4 Global Hawks which take off and land at the US airbase Sigonella, Sicily, but mostly show as Catania, which I think is the nearest civilian airport.Do you know why it’s flagged as Kemble
Aha that might be the 3rd Gorgon sister from earlier, wonder where that’s beenJust had a B52 go over us.
I tracked it's full flight, but didn't take a screenshot. It went quite a way South East - nowhere near Ukraine, going over Greece and the Med.Aha that might be the 3rd Gorgon sister from earlier, wonder where that’s been![]()
.…….says heCan see how you got your forum name.![]()
Cheers, I use an IPad if you do how do you screen shot ?
If the iPad has a Home button, press Power button and Home button at the same time.Cheers, I use an IPad if you do how do you screen shot ?
4 x Ukrainian National Guard helicopters just popped up in Northern Romania and landed at Iasi, Romania. They display as plane icons, but way too low and slow
Or brave
Watching over Tiraspol side. Minutes ago I was outside cleaning the solar panels of snow, lots of rumble above me, circling sort of.Italian Gulfstream G550 looks like it’s got the AWACS day shift over Romania.
Not noticed this type before. Modified business jet, carries Israeli made early warning radar (the big slabs on the side) and can ‘see’ out to a radius of ~230 miles.
That could be wounded casualties taken to Iasi hospital. It has happened in the past.4 x Ukrainian National Guard helicopters just popped up in Northern Romania and landed at Iasi, Romania. They display as plane icons, but way too low and slow
Maybe recovering personnel from exercise Red FlagOne of the F15s off Norfolk is squawking 7700 - one of the ones that diverted to Fairford instead of Lakenheath the other day
