Thank goodness, the last Bailey caravan I had was not good.No, not mandatory![]()
Nicholsong.
Not sure about the old Fiat Comfort Matic box but I think with the new 9 speed ZF version You can nudge the stick forwards or backwards to drop or go up gears in order to decend or ascend hills... As required.
I think you are right. Trigano, makers of Chausson and Benimar to name but a couple of names have used their huge buying power to get a really good deal it would appear with Ford. The 170bhp engine, lots of goodies like stop-start, heated windscreen, lights that follow round corners, and above all a 5 year Ford warranty. It also has a higher rear axle loading than the Fiat.My point ,as you probably get, was that more and more will indeed be going ford as the Transit gets better suited to the mo ho ‘job’
Not to mention that both engine upgrade & gearbox selection are far cheaper too.I think you are right. Trigano, makers of Chausson and Benimar to name but a couple of names have used their huge buying power to get a really good deal it would appear with Ford. The 170bhp engine, lots of goodies like stop-start, heated windscreen, lights that follow round corners, and above all a 5 year Ford warranty. It also has a higher rear axle loading than the Fiat.
No engine upgrade, the 170bhp is standard, certainly for the Benimars. Also the auto box is the only upgrade they do! No habitation upgrade packs.Not to mention that both engine upgrade & gearbox selection are far cheaper too.
It's because the Tessoro is imported specifically as a dealer special for Marquis and is specced in a similar way to the their dealer special Mileo & Elddis vans. In essence they come with 99% of Benimar's Sport pack, the only difference is the standard auto box.No engine upgrade, the 170bhp is standard, certainly for the Benimars. Also the auto box is the only upgrade they do! No habitation upgrade packs.
Our Mk8 Ford has auto wipers and Remis blinds.It's because the Tessoro is imported specifically as a dealer special for Marquis and is specced in a similar way to the their dealer special Mileo & Elddis vans. In essence they come with 99% of Benimar's Sport pack, the only difference is the standard auto box.
In Europe the Transit based MoHo's are 130 as standard and don't have the same standard kit although the Tessy's all have rear reversing sensors as standard and all Transits come with cruise control as standard on all trim levels
The Mk8 facelift Ford 'auto pack' now comes with auto wipers and a heated windscreen option, the former is why the current Remis cab blinds can't be fitted - there's a big lump of plastic behind the rear view mirror. I'm not bothered about auto wipers and pulling the sensor is easy enough, if I can realistically remove the cowling I'll retro fit the blinds.
UK specced Tessy's are a class product and now out sell the Mileo, we spent a lot of time looking at the 463 but opted for the new Tribute F70 due to payload and we didn't want the extra beds. fully loaded they are around £10k cheaper and come in a choice of colours... would have liked a microwave though.
It's a small world as all Benimar, Roller Team & Chausson van conversions are built by Auto Trail in Grimsby and Mobilivetta A class vans are built by Roller Team in Tuscany.
Trigano own Marquis, Benimar, Roller Team, Chausson, Mobilvetta, McLouis, Elnagh and Auto Trail, so not really a small world.
Out of 5 new caravans we bought, a Trigano was the only one which did not have to have a major repair within the first year. Indeed it lasted the 5 years we had it without any major faults or any damp.
Aha! I missed that, I'll email them about availability.Yes I have the plastic cowl. The blinds are shaped to fit round them in a sort of "Y". Can't see why the 2020 Tessoros don't. Mine is 2019. Could be another make though. See here, part way down the web page:
Transit NB: The Remis instructions are the originals and may say 'cannot be fitted to rain sensor models'. But when available we do supply rain sensor versions and feedback from customers fitting these says (re the instructions only) "the only alteration appears to be the position of the screen centre supports".
http://www.motorcaravanning.co.uk/shopuk/remi_blinds.htm
Ah I understand what you mean about a small world.
You're welcome. BTW, they are fitted to 2020 model Benimars with the Ford chassis, however there has been a shortage of them and dealers have been fitting them after delivery.Aha! I missed that, I'll email them about availability.
I've finally had decent feedback from a fellow Transit based motorhome owner, thanks it's appreciated.
I'm not that impressed with the new PSA or Fiat Euro 6.2 engines. The torque in them is disappointing especially if you're planning to drive a 7-8m motorhome weighing more than 3500 kg. The Pug 140/340nm and the Fiat 140/350nm will struggle and fully laden will pull away from a junction like a Morris Minor and be honest, the cabs are pretty outdated.
It's the reason why this time we've opted for the Ford, far comfier driving, a cab which offers modern tech, a more intuitive dashboard and the standard 130 engine has more pull than the 160 offering from Fiat.
most modern torque converter auto boxes have automatic change down on steep descents. as you brake & slow the box changes down & stays there.A supplementary question; how much braking effect would an automatic have on descent of the Selvio Pass? Would one have to manually select lower gears?
There is a difference, the 140 has 30Nm (350) more torque but needs to be doing 2500rpm to release it... The 9 ZF speed box is designed to keep the revs low as the comfortmatic can't cope. The older Iveco multijet II 130 with 3 less gears in the comfortmatic maintained 320Nm at 1800 rpm.So, there is no difference between a 130hp engine and a 140hp engine then? I wonder if Fiat are aware of that?
Hi 76 Zedfour, I’ve ordered new van with automatic 160bhp, I have vw automatic now for work and that is brilliant automatic . Good to know your enjoying the new automatic. Regards DannyI had a 130bhp comformatic on a light chassis. I found the auto quirky. It was often in wrong gear, revved greatly on hills and decents, and drove me mad switching constantly between 5th and 6th on motorway cruising. The 130bhp was underpowered and I doubt the van was ever over 3200kg fully laden. On rough ground it was very juddery.
I have done a few hundred miles now in my new 140bhp zf9 maxi chassis and the ride, power and smoothness is much improved. I can't compare to the ford offering but for me it is a worthy upgrade and a pleasant driving experience. The auto is buttery smooth. I am not a fast driver but for me the power is a marked improvement and unladen weight is around 400kg more. The ride on the maxi chassis is far better and very noticeably better on particularly bad ground.
Thats so when it gets nicked cos the door locks are crap you dont lose so muchNot to mention that both engine upgrade & gearbox selection are far cheaper too.
after reading the horror stories about people cooking brakes on these vans going downhill
I am wondering whether the 9 speed torque converter auto would be able to hold the van in a low gear to prevent this occurring
If not, would it be necessary to specify the hill descent control option?
Going down a high mountain pass on brakes will cook them on any commercial vehicle.
Any automatic gearbox I have used (AISIN in a Ford S-Max, Mercedes 7G in a GLK and now Sprinter, VW DSG in a Golf, 7 speed double clutch in a Huyndai Tucson, S-Tronic in Audi A6) allows the driver to manually lock a low gear to go down on the engine. The ZF auto gearbox that Fiat now uses in the Ducato is the same one Mercedes mounts in the front wheel drive Sprinter, renaming it 9G. Those gearboxes work like the others, they allow you to lock a lower gear to go downhill.
Hill descent control uses the brakes, not helpful on long downhill roads.
Doesn’t sound like the hill descent control will be a particularly useful feature on a van not designed to go seriously off-road.
