I would say the battery is cream crackerd.12v socket in kitchen. Cab battery was showing 11.4 now gone upto 12 but wont start. Nothing comes on then all needles flicker on dials and nothing else.
I bought the Vanhaus one and the battery doesn’t seem to hold it’s charge - so not always ready but it does have the 12v lead to plug in (with engine running!)I now carry a rechargeable compressor which works well and is always ready for an emergency.
It is a good unit but like you say battery doesn't hold it's charge, I always charge it before a trip, eaiser than using the 12v lead. Also recharge after using it.I bought the Vanhaus one and the battery doesn’t seem to hold it’s charge - so not always ready but it does have the 12v lead to plug in (with engine running!)
If it is just a one off and something has drained the battery you will probably get away with it . If the battery is more than 4 years old probably worth replacing.Sat waiting for recovery cant see them having a battery we are in France heading to Spain . If he just jump starts will we be ok or do we need a new battery to continue
In France Norauto are good for batteries. A sort of French Halford. They had a starter battery for us when ours started heating and smelling a few weeks back. Fitted it too in spite of it being under a seat and a sod to get at.Sat waiting for recovery cant see them having a battery we are in France heading to Spain . If he just jump starts will we be ok or do we need a new battery to continue
The van haus one holds charge fine if you remove the battery when you're not using it will then hold charge for months.I bought the Vanhaus one and the battery doesn’t seem to hold it’s charge - so not always ready but it does have the 12v lead to plug in (with engine running!)
This.The van haus one holds charge fine if you remove the battery when you're not using it will then hold charge for months.
Mine's exactly the same, I found out the hard way when I first bought itThe van haus one holds charge fine if you remove the battery when you're not using it will then hold charge for months.
That’s a pain! On the bright side, at least you know now. :-(Jump started easy just drove 250k to the site. Went in to check in battery dead called aa again bit of a pain. The battery is probably 7 years old. We were going to go to norauto but the recovery guy said it will be ok. Obviously not.
Just hoping the garage is fair with their costs, but heyhoThat’s a pain! On the bright side, at least you know now. :-(
Which one have you got? Thinking about getting one for tyres and awning. Saves cables trailing about, keys in ignition ETC always like a recomendation with these sort of thingsI now carry a rechargeable compressor which works well and is always ready for an emergency.
On phone at the moment so can’t detail but my post #13 above shows the one I bought.Which one have you got? Thinking about getting one for tyres and awning. Saves cables trailing about, keys in ignition ETC always like a recomendation with these sort of things![]()
Found that out too late.Especially with the more powerful 12v compressors it is essential to run the engine when pumping up tyres. They draw a high current and barely work below 13v. So you need the alternator to be charging
Why would(should) you not do that?Jump start yourself off your hab batteries.
