- Jun 20, 2022
- 710
- 1,638
- Fiat ducato pvc self
- Since 2017
If you have driven 250k and the battery is still flat I would be worried about the alternator
It can in some cases damage the hab battery, but that is pretty rare if it is only ever done in an emergency. Some american vans are wired to do it at factory, you throw an isolator switch to connect themWhy would(should) you not do that?
I wouldn’t be, it’s a 7 year old battery and likely knackered. If all loads were being serviced fine like fuel pumps and lights and battery lights were off, the alternator will be fine.If you have driven 250k and the battery is still flat I would be worried about the alternator
I don’t know why you would (should) not. I recommend that they DID do it. Just join battery to battery with jumper cables, like you would in any jump start situation. It won’t harm the batteries for a single start, or even a couple of starts. Will get you to a place to buy a battery, so you can carry on and have a holiday.Why would(should) you not do that?
