Battery
Stockport, Cheshire
Bravaria i740 AClass
Stopped overnight Carcassonne aire.
Tyre flat tried pumping up with tyre pump from 12v socket now battery flat would it draw from the engine battery obviously has . Hab batts ok.
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
Which 12v socket did you plug into? The cab/dashboard one or a supplementary one in the hab area?
Maybe you have just blown the 12v socket fuse.
How have you checked to find that the starter battery is flat? From the 'Anxiety panel' meter reading? Test meter on battery terminals? Engine won't turn over?
Simon Meadwell
Stockport, Cheshire
12v socket in kitchen. Cab battery was showing 11.4 now gone upto 12 but wont start. Nothing comes on then all needles flicker on dials and nothing else.
Rochester
Auto-Trail Mohawk
17 fun filled years
I would say the battery is cream crackerd.
Hymer Exsis
20 years
I agree the battery sounds knackered. On the plus side, if it can’t cope with a simple tyre inflation, it was probably near knackered anyway.
Can you plug into electric somehow so it charges the cab battery to get you home or at least to a garage to get it sorted?
Norfolk
Two wheel job towed.
Since 2004
I now carry a rechargeable compressor which works well and is always ready for an emergency.
Milton Keynes, UK
Burstner Lyseo 727G
3 years 30,000 miles UK and Europe.. Campsites and off Grid.
But surely the 12v in the kitchen runs of the hab not the engine battery?
Needles flickering is classic signs of a flat engine battery.
Simon Meadwell
Stockport, Cheshire
Sat waiting for recovery cant see them having a battery we are in France heading to Spain . If he just jump starts will we be ok or do we need a new battery to continue
Riverbankannie
Bristol
IH 630 RL PVC
I bought the Vanhaus one and the battery doesn’t seem to hold it’s charge - so not always ready but it does have the 12v lead to plug in (with engine running!)
Lenny HB
On the coast in West Sussex
Carthago Compactline
It is a good unit but like you say battery doesn't hold it's charge, I always charge it before a trip, eaiser than using the 12v lead. Also recharge after using it.
Lenny HB
If it is just a one off and something has drained the battery you will probably get away with it . If the battery is more than 4 years old probably worth replacing.
How is your starter battery charged when you are parked up, solar, Batterymaster etc.?
If you get stuck again you can run a cable between both battery positives to get some charge from the hab battery into the starter battery.
Norfolk
Since 2004
Eastbourne East Sussex
Hymer low profile
Since 1972
In France Norauto are good for batteries. A sort of French Halford. They had a starter battery for us when ours started heating and smelling a few weeks back. Fitted it too in spite of it being under a seat and a sod to get at.
Hymer low profile
Since 1972
The van haus one holds charge fine if you remove the battery when you're not using it will then hold charge for months.
Simon Meadwell
Stockport, Cheshire
Jump started easy just drove 250k to the site. Went in to check in battery dead called aa again bit of a pain. The battery is probably 7 years old. We were going to go to norauto but the recovery guy said it will be ok. Obviously not.
Hymer Exsis
20 years
That’s a pain! On the bright side, at least you know now. :-(
Lincoln, UK
Bailey 79-4T
Feb 2023
Which one have you got? Thinking about getting one for tyres and awning. Saves cables trailing about, keys in ignition ETC always like a recomendation with these sort of things:giggle:
TheBig1
Especially with the more powerful 12v compressors it is essential to run the engine when pumping up tyres. They draw a high current and barely work below 13v. So you need the alternator to be charging
Norfolk
Since 2004
On phone at the moment so can’t detail but my post #13 above shows the one I bought.
Simon Meadwell
Stockport, Cheshire
Found that out too late.
MisterB
Essex
Adria 670 SLT
We carry a Ring compressor but it needs to be connected to a 12v supply to work. We are likely to fit rear air assist later this year, hoping that I can fit some sort of air take off point from the permanently fixed compressor so I don't have to carry two compressors.
Simon Meadwell
Stockport, Cheshire
So breakdown recovery not coming back with a battery, they have closed the job and not told us. Using site contacts for mechanics. The battery is showing 13% on the gauge but i have no confidence in it so going to replace it.
Hymer Exsis
20 years
The battery needs replacing, they usually break all of a sudden with no warning.
Annoying they didn’t tell you.
I remember a mate had one fail about 10 years back in France, the replacement wasn’t cheap but he was stuck and we were in the middle of the Alps in summer main holidays so there wasn’t much choice.
