AndyPK
- Oct 7, 2015
- 5,496
- 17,889
- Devon Firefly
- Motorhoming since 2015......
Changed to Igloo Energy two months ago……..
No sh*t Sherlock! (see what I did there!Three more energy companies have deduced to stop trading![]()
That’s taught me a lesson on fastNo sh*t Sherlock! (see what I did there!).
You can exit Octopus variable or fixed rate deals anytime without penalty. As the price cap is applicable to all suppliers are there any variable rate deals cheaper.Octopus appear to have good reviews but they aren't anywhere near the cheapest so make sure you do your sums before committing to be with them for any period of time.
Now that my Mum has gone into a care home we want a rate for her flat with the lowest possible SC as there will be very little energy usage going on
The companies would like you all on high fixed cost deals ,like here, so the actual supply of anything doesn't really affect there income.Yeah, I think it just proves that everyone should look very carefully at things like SC and unit costs in their particular situation.
Not at the moment on the face of it, it's a matter of working it out based on units rate and standing charge, for Mum a higher unit rate is preferable to high standing charge.You can exit Octopus variable or fixed rate deals anytime without penalty. As the price cap is applicable to all suppliers are there any variable rate deals cheaper.
Considering the builder has to pay for the gas etc to be connected to a property, exactly how much does the pipe wear out ? Surely it would be a whole lot fairer if everyone just paid for what they use.I’m still at loss as to why I have to pay a standing charge.
I can’t do that with my customers![]()
really you couldnt make it up first you pay for the cost of the instal and then pay rent on it .Just waiting for garages to start putting a charge on your fuel bill for use of the pumpConsidering the builder has to pay for the gas etc to be connected to a property, exactly how much does the pipe wear out ? Surely it would be a whole lot fairer if everyone just paid for what they use.
That'll never catch on, well not with vested interest least ways, the current method let's them slide a bit onto both charges, like tax , and national insurance, which are indistinguishable from each other If you're paying out. What does need explaining is where all millions ££s already paid out has gone, with water pipes continuously fracturing every time there's a hint of cold weather, and then they have the audacity to put the blame on the Victorian infrastructure they so greedily scooped up when it was all privatised.Considering the builder has to pay for the gas etc to be connected to a property, exactly how much does the pipe wear out ? Surely it would be a whole lot fairer if everyone just paid for what they use.
The standing charge covers amongst other things the running of the networks (not the generation side of things). There's a whole lot more to it than the bit of pipe running to your house. The gas has to be filtered, pressurised and pumped through a countrywide network, there's a whole raft of gas transfer stations across the country which all need regular maintenance, Leaks need fixing and pipes need replacing. Similar thing with the Electricity transmission towers, Cables, transmission and distribution sub-stations (inc transformers, Switchgear) all need maintaining and improving as demand increases. Trust me a 400kV supergrid transformer isn't cheap and you can't buy one off the shelf.Considering the builder has to pay for the gas etc to be connected to a property, exactly how much does the pipe wear out ? Surely it would be a whole lot fairer if everyone just paid for what they use.
In the winter the gas pressure increases causing more leaks hence the replacement of cast iron mains and ductile mainsAlso by law water companies are allowed to turn down the pressure so not so many leaks appear.
Instead of making the water companies update the infrastructure.
You couldn’t make it up.
Well if it wears out the more it’s used surely it should be paid for on the basis of who uses the most gas , not people who are careful of gas use subsidising the one who use loads.The standing charge covers amongst other things the running of the networks (not the generation side of things). There's a whole lot more to it than the bit of pipe running to your house. The gas has to be filtered, pressurised and pumped through a countrywide network, there's a whole raft of gas transfer stations across the country which all need regular maintenance, Leaks need fixing and pipes need replacing. Similar thing with the Electricity transmission towers, Cables, transmission and distribution sub-stations (inc transformers, Switchgear) all need maintaining and improving as demand increases. Trust me a 400kV supergrid transformer isn't cheap and you can't buy one off the shelf.
I for one am not buying that logic, unless we can as nation all play by the same rules.The standing charge covers amongst other things the running of the networks (not the generation side of things). There's a whole lot more to it than the bit of pipe running to your house. The gas has to be filtered, pressurised and pumped through a countrywide network, there's a whole raft of gas transfer stations across the country which all need regular maintenance, Leaks need fixing and pipes need replacing. Similar thing with the Electricity transmission towers, Cables, transmission and distribution sub-stations (inc transformers, Switchgear) all need maintaining and improving as demand increases. Trust me a 400kV supergrid transformer isn't cheap and you can't buy one off the shelf.
There are tariffs with no standing charge. Or certainly there were - I don't know if they're still available.I’m still at loss as to why I have to pay a standing charge...
Possibly, but it probably only suits 0.0001% of the population, and is fiendishly difficult to comprehend, so they have that base covered as well.There are tariffs with no standing charge. Or certainly there were - I don't know if they're still available.
look on the bright side here you also have to pay for each Kw you wish to be supplied with. Even if you never use any electric.I’m still at loss as to why I have to pay a standing charge.
