Two on Tour
- Sep 16, 2016
- 11,496
- 65,180
- Elddis Autoquest 175
- Since 2010
Two on Tour Thanks, I just need to buy a regulator to bring the inputted gas level to 30mb then!
Also worth noting that CD&R (owners of MFG) are the buyers of Morrisons, and they want to sell MFGIt's worth noting MFG is not just about the acquisition of Morrisons, they run many filling stations, in my area usually Esso and Shell branded. The availability is going to get more and more challenging![]()
That is how mine is set up at present.I am going to have a gaslow system fitted on Monday but you now cast doubt on it , I am now thinking do I go ahead or not , having one11kg and keeping one 6kg calor, as a belt n braces option.
the booze cruise is still onGoodbye booze cruise, hello GPL cruise.
Exactly the same set up and experience for us.i have 1 11kg gas it refillable and a 6kg calor as a backup i have never had to use the calor in the last 5 years
You won't be able to do that by just connecting them together with a hose as all that will happen is the gas vapour from the full bottle will initially rush into the empty bottle, but when the empty bottle reaches the same pressure as the full bottle (probably just take a couple of seconds) the gas pressures in both bottles will be equal and no more gas will transfer.I already have two 47kg bottles at the house that we use for cooking and have two Gas-IT bottles with external filler. How easy is it to safely fill the refillables from the larger cylinders? Ideally without moving the heavy bottles? I would say 6 meters is about as close as I can get the van.
That's the set up that works for us, except our 11kg refillable is Gas-it, rather than Gaslow.I am going to have a gaslow system fitted on Monday but you now cast doubt on it , I am now thinking do I go ahead or not , having one11kg and keeping one 6kg calor, as a belt n braces option.
How has it worked out well when youve not had to use the small bottle for 5 years, I would say it’s not worked out well, no problem filling with lpg so I would say I wish I’d gone with x2 refillable?Exactly the same set up and experience for us.
Has worked out well so far.![]()
Why? If only having one refillable has worked there's no need for 2, thus no need for the spare either (although I'd still carry a spare 'something' just in case there were issues with the refillable).How has it worked out well when youve not had to use the small bottle for 5 years, I would say it’s not worked out well, no problem filling with lpg so I would say I wish I’d gone with x2 refillable?
Well if they had 2 refillables less filling up and you’re not carrying something just in case you never useWhy? If only having one refillable has worked there's no need for 2, thus no need for the spare either (although I'd still carry a spare 'something' just in case there were issues with the refillable).
Morrisons at The Fort.What Morrisons did you fill at ? I had to go to Morrisons Kilmarnock 72 p.
Notice it’s up to 82 p now.![]()
I agree and that's what we do as we prefer to have to fill less especially as we may be in out of the way places and/or settled and not wanting to move, but it's not a necessity.Well if they had 2 refillables less filling up and you’re not carrying something just in case you never use
I suppose it depends on which way you’re looking at it
'Forklifts' raises a question.
So will we.@ManTheVan
Definitely sticking with our 2 x Gas-it 11kg set-up.
CheersMorrisons at The Fort.
Well obviously everybody's view is different, but it's worked well for us.How has it worked out well when youve not had to use the small bottle for 5 years, I would say it’s not worked out well, no problem filling with lpg so I would say I wish I’d gone with x2 refillable?
Probably not but I would be prepared for raised prices as for us, we do not have any alternative and would still be cheaper than calor bottles.I wonder what the running costs are for them selling lpg ? Maintaining pump, insurance, weights and measures etc. can’t imagine it’s cheap
As things stand, with.less demand from cars, you can see why big companies do not want MHs on their forecourts just for gas. Maximum I've ever spent on a refill is about £16, usually its just a top up of £4 or £5. I've some times asked for help, a big van taking up forecourt space, just getting in the way. And it's almost embarrassing, a few pennies against others' hundred pounds.It’s a pity that the independent Andy’s Gas at Cribbs stopped access to their pump at the covid lockdown and has not opened it up again.
I am sure that if both Asda and Morrisons there both stopped, they would be able to attract all MHs with refillables coming anywhere near Bristol and make the pump viable especially if promoted within clubs and on apps. They also do the exchangeable bottles.
Time for clubs to reach out to them? Jim
Bottled Butane & Propane Gas In Bristol (LPG)
"Andy's Gas specialise in the more personal house to house gas deliveries, carrying the heavy gas cylinders up stairs if needed, and fitting the bottled gas to your gas fires for you if you wish, and switching them on for you."www.andysgas.net
