I have 2 x 5KW and 1 x 1KW. I am going to be sticking with 1KW for most uses. The 5Kw is going for my unit heating.I might swap the 5 for a 2kw to try it out.
Not legal. Needs to be bunded these days.Hi Karl can you not get a IBC tank (about 40/50quid) and get heating oil at 77 p pl Not bunded but I know a farmer who buys 1000l red diesel into one - heating oil will deliver 500 L at a time![]()
Good to hear that.Wissel is back. Hopefully he will see this.
When I bought mine it was advertised as 2Kw. I have to run it in the van nearly shut right down. When I looked in to them again I noticed that the 5 & 8 Kw are a longer length than 2kw heaters. When I measured mine it is too big to be a 2kw heater so they must have sent me a 5kw? Bought it in 2018 though & never fitted until 2019 in this van.I might swap the 5 for a 2kw to try it out.
I don't have the measurements to hand sorry. If you want them I can get a tape measure out later or tomorrow foryou?Good to hear that.
If I recall correctly the 2Kw are about 30cm long & 5 & 8 kw are around 40cm?
Yes they can be run on all sorts. For personal use Red Diesel can be used for heating.Can these heaters run on different fuels such as paraffin or used chip oil? My 95 Bongo used to run nicely on chip oil. Plus it was fun at traffic lights watching people looking around for the nearest chippy! And what's the deal with red diesel, is it legal?
Thanks. I'm seriously considering putting a 2kw in the house garage vented into the lounge, with under the van seat as a future possibility.Yes they can be run on all sorts. For personal use Red Diesel can be used for heating.
No need .I was just pointing out I bought a 2kw & got supplied a 5I don't have the measurements to hand sorry. If you want them I can get a tape measure out later or tomorrow foryou?
Very late to the party but a brilliant commentary on your diesel install.I installed a 2KW diesel heater 2 days ago. Here is my initial review.
I was heading towards the peak winter usage of gas at 1 bottle per week and these are currently costing £42.99 per swap.
In addition my gas heater just doesn't cut it in the winter even on full blast. So a Diesel heater has been long on the cards.
Now I have my industrial unit I could strip stuff down and had places to store all the crap while I did the work and it wasn't so much of a hassle to do.
Soo. The install. I wanted to install it under the bench seat opposite the one I use as a bed. But due to the water heater being in an awkward position this was not possible with the chassis rails.
Moving it is possible but is a future project and I didn't want to do it just now. So. I installed it under my bed as that is the easiest place to get to. Right at the head of the bed.
It wasn't until I started testing it I suddenly thought about having that fan/tick right next to my head whilst trying to sleep and got a bit concerned.
This fear turned out to be unfounded as once the cushions were back on it is actually quieter than the blower in my Truma gas/electric heater.
Noise levels are therefore not an issue at all with the 2Kw heaters at low. And at low it is heating my caravan beautifully. I have had to turn it off once due to it getting too hot in here once, the sun was out and heating the van up.
Then twice I have opened a roof vent with the fan on for 2 minutes each time to knock down the heat a bit at night. Turning it off cools the van too much and then it has to ramp up to get the temp back up again. So letting a little bit of the hot air out works out better.
It is not something you have to do often with the 2KW heater.
2KW vs 5KW heater. I chose the 2KW heater because I would rather have one that could go very low and use the least diesel rather than work most efficiently in the winter. I think this was the correct decision. The 5KW in my van cab pumps out a LOT more heat on the lowest setting and would have been too much for my caravan.
Usage: The diesel tank gauge hasn't moved off full in the 2 days I have been using it. So I just timed the ticks. It is running at 1 tick a second at night and during the day it drops lower than this. But I just did the maths based on 1 tick per second.
1 tick = a 0.02ml dose. So 0.02ml x 60 x 60 is 72ml an hour and 1.728L a day. I am buying my red diesel at 99p per litre. So the cost is £1.71 a day or £11.97 per week. Even if I have to go the more expensive supplier round here it is £1.15 per litre it would be £1.99 per day or £14 per week. When I can get onto the kerosene it will be £0.79 per litre or £1.36 per day or £9.55 per week. I was considering getting a Kerosene bunded tank but the cost of it and the savings means it is probably not worth the effort. The payback time would be too long.
Anyway I think that is off the beaten track
My calculations are that if you can get red diesel then the cost of running a 2KW diesel heater is a quarter of the price to a third of the price of gas bottles and probably half the cost of LPG.
Summary. Not as noisy as expected, much cheaper to run than expected. Dead easy to install and a good level of heat even on the lowest setting. For a caravan it is better because refillable LPG are not always practical. For a motorhome if you use the main diesel tank I think it still works out cheaper than LPG in a refillable but perhaps not as clear cut depending on the price of Diesel. However, if you are fulltiming during the winter. Having the diesel heater running from your main tank gives you a much long run time before needing to seek a refill. With a dual 13KG gaslow in the peak of winter you would be seeking a refill every 14-18 days. A 90 Litre tank in a fiat ducato would last 53 Days. So there is that advantage to consider also. In 2009 and 2010 winters I got snowed in and had a hellish job getting cyclinders delivered. I couldn't get out to get my Gaslow bottles topped up. It hasn't happened since, but...
Anyway, I will post follow ups if I have any further information.
Check out David McLuckie who has tested them on all sorts as well as doing all sorts of other experiments. Including putting a window in one to see how they work.Can these heaters run on different fuels such as paraffin or used chip oil?
Watched a vid on YouTube about this the other day. Old boy in motorhome had same issue as you. He had also been running his on low for long periods. Burn chamber was coked up with carbon. Strip down scrape out and was all ok.Well it has packed in on me giving me E08 and constant E10 errors. It was pumping out LOTS of white smoke. I think I know what it is and what caused it.
My suspicion is I have run it on low for too long without giving it a high heat cycle often enough.
There is a small hole next to the glowplug to let air in to mix with the diesel and I suspect that is blocked/coked up.
So later today I will be removing the glowplug and giving it a clean.
I have not lost confidence in it, but just wanted to keep this thread updated and fair.
I will update later on how easy/hard it was to service. What was involved and if it fixes it.
Just to add. I think it is the diesel flame front hole that is blocked as per this old David McLuckie video.
I just ordered a service kit and it comes with those.The atomising mesh can be a pig to get out, so I use an mate bolt with a bit of a leading chamfer filed on it.
A slight screw in action grips the mesh so you can pull it out.
I use one of these cheap plastic mesh inserting tools to push the new mesh in and position it correctly.
Thanks for the tips.Don't wait for the kit, a 12mm open end spanner will get the plug out without dismantle it, or a deep socket cut with the grinder to allow for the cable. Once the plug is out, use a pencil with the rubber at the end, or a 6-7mm coach screw with coarse tread for wood. That will get the mesh out and you can clean it, as well as the tiny hole. I use a bit of skinned wire to clear the hole, and the mesh I blow it with wd40 then burn it with a gas blow torch. I found at 1.3hz will keep the plug clean, providing you run a hot cycle evrey couple of weeks for 10-15 mins. I have it set on 1.5hz now as minimum to prevent this blockage.
Mine gave the E08 error after I first installed it due to my stupidity. I had fitted the exhaust creating a low point and it had filled with condensate. Rerouted to remove low point and still fine 2 years laterWell it has packed in on me giving me E08 and constant E10 errors. It was pumping out LOTS of white smoke. I think I know what it is and what caused it.
Fortunately my exhaust is fine. constant down grade from the body of the heater to the exhaust silencer. Thanks for the tip thoughMine gave the E08 error after I first installed it due to my stupidity. I had fitted the exhaust creating a low point and it had filled with condensate. Rerouted to remove low point and still fine 2 years later
