Yeah but you'd need 3 to get anywhere.
Sure, lithium and cobalt are quite rare, and they are found in the earth. But they are not technically 'rare earth metals', like neodymium and samarium used for rare earth magnets. Lithium is an alkali metal, and cobalt is a transition metal.Lithium and cobalt are rare earth minerals
That's because when they ask each household every says ' yes we have offroad parking' but failing to realise they have one space at the house & 5 occupants them have answered yes.We are told (which may not be true) that 84% of properties have off road parking
Or they won't work. Then if there are no benefits it will soon become a civil war.as has been suggested, the road usage tax will be set at 75p per mile (or even £1.50 per mile) for cars, that will force everyone on a low income onto public transport, as private motoring becomes unaffordable for them.
But most of it will soon be in other countries? one of which hates the sight of us & soon will have voted to exit the union. Then they'll be making up the lost oil revenue with inflated elcetricity prices.If we go ahead as the government plans and installs an additional 30GW of wind generation we will have a massive excess of generation.
Where is the information to support this? You keep saying it but anyone who I know of running small businesses do far greater mileage than 100/dayThe vast majority of vans are used for local area deliveries and local tradesmen.
At present. They are proposing the introduction of it ,although as usual the meters will all need changing again & Ofgem state that they will 'rigorously oppose it'?You are misrepresenting the law. You should check out what it actually allows for, and note that it requires the permission of the householder.
it's not new but still expensive at 51kFor £120,000 it ought to be.
Ooh goody.. I'll have two please..You do know you can buy a Tesla for less than £40,000?
Bad news sells papers, even the FT. Very few if any of them reported that it was a lower than required by regulations buffer. There was never a shortage of capacity. Secondly very few published an update a few hours later when the system worked as designed and the buffer was restored to it required minimum level.
This is the first time it has happened since 2015, prior to that it happened quite frequently every winter. The reverse of what most people suspect is true, the grid has actually got more stable over time. Remember years ago we used to be worried about gas shortages during winter which was causing problems for the national grid planning.
Here is just one example from 2010. there are many more examples.
The Big Freeze 2010: An audit
The chilling season goes on. Susie Mesure, Andrew Johnson and Emily Dugan reportwww.independent.co.uk
Here is the thing though. If we go ahead as the government plans and installs an additional 30GW of wind generation we will have a massive excess of generation. Storage can be built to take this excess and supply it back when there is a lull in the wind. The storage could be fast acting batteries, Medium speed but bulk storage using compressed air which is scaleable and hydrogen to supply the current gas turbine generators which are slower to come online but can do large amounts.
I have experience of this type of system from my electrical apprenticeship and my work in data centres. The batteries would provide the fast response for short term supply while the air compressor systems come up to speed. The compressed air systems could last for hours if not days. The gas system could be there for extreme events where we are under supplied for weeks.
This is not going to happen overnight and this does not need to be complete by 2030 as the deadline is actually 2050 for us to be carbon neutral. We have plenty of time.
Finally, the wind tends not to stop blowing UK wide. We are currently more reliant on the unpredictable onshore wind farms. Offshore has a far high uptime and it is extremely rare for the wind to stop blowing in all the seas surrounding the UK.
Remember the big advantage of wind is that once you have paid for the infrastructure you don't then need to continue to pay for fuel and worry about geopolitically caused supply issues.
Only the basic 2 wheel drive with no extras. More likely £70k like the one my brother in law has. Warp speed acceleration!You do know you can buy a Tesla for less than £40,000?
Multiple sources. Average van mileage per year is 12,000 -13,000 depending on the source.Where is the information to support this? You keep saying it but anyone who I know of running small businesses do far greater mileage than 100/day
Well, at the grand age of 78, 79 come Sunday(!) ie expect that by the time 2030 comes round I have either gone to another place or just too ancient to manage a motorhome. But then, I am an optimist so I might drive on into the 90's. And there will still be lots of diesels about even so as a ten year old MH is still in its youth. Mine has just past 45K miles at 11 years of age.‘Plan for the worst, hope for the best’.......I hope the value of diesel vans will go up.....but there could be a lot less fuelling points to use by then.....!?!![]()
30gw capacity isn't what they generate. Typical percentages that I have seen are 15-30% of installed capacity. Wind speeds less than 30mph will only generate a tiny amount of electricity. The point is we will need a permanent generation capacity using gas for when the wind doesn't blow enough. Storage is obviously desirable, but probably would not be enough when we get a static high pressure region for more than a week, which happens several times each winter.
13,000 miles per year divided by 50 weeks = 260 miles per week.
Over 6 days =43 miles
Over 5 days = 52 miles.
That means more than 50% of of van users do less than 100 mile per day by a margin.
Which in Breckland district ( which is bloody massive ) street lights are not exactly thick on the ground, even on the housing estates they put the minimum to stay legal.. The ones we do have are fed with quite thin cables considering, and only 1 in 10 are left on after midnightost (all ??) dense residential streets in towns have street lamps.
And what would happen if we get to 2030 and nobody can afford, or want to buy, a new vehicle![]()
As they will not be free to use all the charging points will need a secure card reader.. it is going to cost billions and if councils started a program NOW they might get finished around 2050
Sid52 Check this out.
UK offshore wind capacity factors – Energy Numbers
energynumbers.info
You have to exclude the really old ones and the demo ones and pretty much every single one is over 30% and almost half are at or over 40% with a few getting into the high 40s and one touching 50%+
Back to these 'average' figures againMultiple sources. Average van mileage per year is 12,000 -13,000 depending on the source.
Van use falls roughly into two categories. Work vans drive to a job and sit there all day, they're used for carrying tools and materials. Depending on location, mileage could well be less than 50 miles. I used to do about 5000 miles a year when I was landscaping. Even if driving to jobs further away, it would not usually be more than 70 miles. A battery van, apart from the price, would have suited me fine.
Service vans and delivery vans do much further mileage, could be up to 4-500 miles a day doing long distance drops. The Merc Sprinter and the like are motorway bashers running all over the country doing 500 miles a day, so currently batteries aren't any good.
I have covered this before. The vast majority of vans are used for local area deliveries and local tradesmen. The manufactures are currently supply side limited on batteries. They can only get so much at the moment.
So if you have for example 1,000Kwh of battery supply do you build 20 x 50Kwh vans with 100 mile range or 10 x 100Kwh vans with 200 mile range. The profit margin is the same on both and there are enough customers to soak up all the supply you can provide...
I was explaining why ALL the vans being built at the moment have low range. I also said this.Back to these 'average' figures again
What happens to all who do more, a lot more, than the average figure ?
Once the new battery factories come online and supply constraints are removed expect to see longer range vans.
You make 2 statements of fact there that are wrong.But most of it will soon be in other countries? one of which hates the sight of us & soon will have voted to exit the union. Then they'll be making up the lost oil revenue with inflated elcetricity prices.
Lots of reasons for the improvement over global average. One is prime location. We have one of the biggest wind resources in the world due to us being an offshore island.That's some very interesting and encouraging numbers. So is the increased capacity due to better positioning as regards wind direction, shadowing and velocity, taller tower, better performance in marginal wind speeds etc?
https://www.thisismoney.co.uk/money...electricity-without-warning-compensation.html
No;1 in most towns won't work. Where my nephew lives, which didn't even exist 50 years ago , the council allowed to be built a town where most of the roads are 5m in width You cannot park in the road unless staggered, The average per house is 4 vehicles. Being a 'green' area with huge amounts of trees, bushes & rabbit run alleyways,+ huge amounts of houses have no parking whatsoever within 2 or 300 metres.
Alternate them where? everywhere is like it in most towns now?
Mate delivered a 130k car up north recently where the bloke said he had lived there 4 years & at no time had he ever been able to park closer than 4 streets away??
I inadvertantly went down a dead end in devon last year. solid parking both sides ,nose to tail each side half on pavement, no off street parking of any sort & even the 'turning'area at the end parked solid. Nowhere for me to turn whatsoever. Had to reverse out 500m.
You appear, like me, to have been too long away from places that used to be passable & are now absolutely bumper to bumper in every street.
2) ok in areas where people have access to other means of transport & where parking is strictly controlled.
I.e if you aren't wealthy you can't even afford to live there to start with. If you are wealthy you would be leaving the car in the multi storey private garage regardless of the cost & plugged in permanently.
3) You wouldn't have to worry about them being blocked it is the street that would be blocked.
These days when the bin men are collecting you are doomed to be stuck behind them until the end of the road or a turning you can go down to go another way. There is usually nowhere for them to pull in & collect.
In reality they shouldn't be using a vehicle for anything under about 8 miles.This is what is causing many of the problems, along with too many people, people who think it is a means of getting from Ato B , school runs ,etc;etc,
I've not read through this entire thread but has the home charging of EVs been mentioned. It is going to be a nightmare. Not a single new dwelling has yet been built with charging EVs in mind. Home charging is the only realistic way forward for EVs.On-street parking can be very problematic. The posh Bristol BS8 postcode known as Clifton is a notorious example. Many residents have no choice except to park 2 or 3 streets away from where they live in very expensive Regency terraces. It is car crime central. An acquaintance came back to his BMW M3 one morning to find it had been stripped of front body panels. Brazenly carried out in full public view. No chance of charging EVs on the street unless pavements are ripped up and more substations and much fatter cabling installed in what is a highly protected Conservation Area jealously defended by the Clifton and Hotwells Preservation Society. Next, how would you protect your EV charging cable from copper thieves unless you stand guard for hours? I doubt if anyone keeps a MH on the street in BS3, even the Van Life community, because there aren't enough Residents Parking Permits to meet demand and they are costly.
