- Feb 24, 2013
- 13,115
- 101,586
- Hymer S800
- not long enough
Motorhome failed MOT 2 weeks ago, centre prop shaft bearing ?
Booked in for service following week at Mertrux so rang them asked to add to job and get part ordered
Took down, got a call back to say they have found serious issues / work needed
Brake discs and pads, not surprised as noted on this and previous MOT I had told them if they looked bad to change them
Whole exhaust system is hanging off and needs replacing all the brackets have failed
Brake pipes all showing heavy corrosion all need changing which means removing fuel tank
Track rod too much play on one side suggest changing both
Diff oil seal leaking but might as well change while prop shaft off for prop shaft bearing
This is all by phone call, we are away visiting Bevs mum in hospital after having stroke so while he talked I was adding up in my head
I am not good at this bit service was quoted at £500
I guessed £500 to add front discs
Thought maybe £1000 absolute max for exhaust
Brake pipes no idea
Propshaft guessed £200 no idea what that was based on though
So when he said quote was up to £6500 + VAT I nearly got into hospital bed with MIL
So I asked him to give me a bit more breakdown
Turns out exhaust is over £3K for bits brake pipes fairly modest £1200 including fitting
Bev had said how she was looking forward to getting away it was what we needed with mum being poorly
I knew I had just moved sone money around ready for some work in the house and by chance alone had enough to cover this so agreed to go ahead as we wanted it back
I will continue in another post below it’s bringing tears to my eyes just retelling
Brake pipes no idea
