As a general rule of thumb I would agree with all of that. However, the charging profile of Leoch pure lead carbon batteties is the same as that for lead acid batteties and they can safely be discharged below 50 % DOD. Without damage to the battery.
Two batteries but still only 100amps to play with.Yes but we have 2 leisure batteries - I would hope they would last longer than that?
Your 'over 13v' is the batteries' voltage at that moment and not their capacity (Amp/hours of useable power).I have tested both current ( no pun intended!) Batteries and after a full charge & being left for 6 hours disconnected both read over 13 volts - so they are obviously ok..
How are you giving them a full charge? As several people have already said, the voltage during charging is no indication of the battery state of charge.I have tested both current ( no pun intended!) Batteries and after a full charge & being left for 6 hours disconnected both read over 13 volts - so they are obviously ok.
I have been on EHU or traveling with alternator charging plus having solar and all and as you point out using the CTEK controller so not really any other way of knowing apart from voltageHow are you giving them a full charge? As several people have already said, the voltage during charging is no indication of the battery state of charge.
Thanks - I'll have a look at them.As a general rule of thumb I would agree with all of that. However, the charging profile of Leoch pure lead carbon batteties is the same as that for lead acid batteties and they can safely be discharged below 50 % DOD. Without damage to the battery.
Without sounding thick - where do you get 100 amps from?Two batteries but still only 100amps to play with.
I have no other way of measuring them - what do you suggest?Your 'over 13v' is the batteries' voltage at that moment and not their capacity (Amp/hours of useable power).
Agreed but I'd rather find a way of checking them than just scrapping them & forking out £400 plus !!If they were down at 9v probably in a worse state than your current ones.
Struggle by until you get home then take all 4 to the scrappie you will get about 50 quid for them.
It depends on the usage. Some users have quite low amps demand, and in that case gel batteries will probably give more use time, and can safely be discharged to a lower level, about 20%, without deterioration. However other users with high intermittent amps demand, using an inverter for microwave/hair dryer/coffee machine, will be better with a stop/start or dual-usage battery. There's not a tremendous difference in the performance of the battery, it's just that the battery life before it doesn't hold enough charge will be different.1- are stop/start batteries really deep cycle & suitable for leisure use?
Can I ask why you think that please?That battery is suitable as a leisure battery and is AGM. I think you'll be trying to find room for more solar soon ,
80ah Gels are about £160 each at the mo.Agreed but I'd rather find a way of checking them than just scrapping them & forking out £400 plus !!
Thanks. We were using them the end of last year & they seemed to be fine but the last 3 months have just been plugged into hookup outside the house keeping the heater running. I'm trying to work out if that has damaged them or if they just aren't suitable. We haven't been using anything that would draw heavy current apart from Avtex TV, lights & blower for the gas heating.It depends on the usage. Some users have quite low amps demand, and in that case gel batteries will probably give more use time, and can safely be discharged to a lower level, about 20%, without deterioration. However other users with high intermittent amps demand, using an inverter for microwave/hair dryer/coffee machine, will be better with a stop/start or dual-usage battery. There's not a tremendous difference in the performance of the battery, it's just that the battery life before it doesn't hold enough charge will be different.
Thanks Lenny HB but I haven't got any way of checking that whilst I'm away but will definitely try it when I get back80ah Gels are about £160 each at the Mo.
Here is how to test them:
First charge the battery fully and leave it to settle for an hour then:-
Disconnect all charging methods.
For example if it's a 100a/h battery load it with a 5 amp load and run for 5 hours, this will represent a 25% discharge. (adjust load/time to suit the size of the battery)
Disconnect the load and leave to stand for at least 30 min then measure the voltage.
Repeat the test and you will have discharged the battery to 50%.
You can repeat again then it will be 75% discharged.
Sorry but what is DOD?As a general rule of thumb I would agree with all of that. However, the charging profile of Leoch pure lead carbon batteties is the same as that for lead acid batteties and they can safely be discharged below 50 % DOD. Without damage to the battery.
You could do it if you are on EHU and use lights, TV etc., as a load but it's a slow process and best to do each battery seperately so probably best left until home.Thanks Lenny HB but I haven't got any way of checking that whilst I'm away but will definitely try it when I get back
Depth of discharge.Sorry but what is DOD?
I've bought a lottery ticketI had Banner AGM in the first Autotrail I had but they did not last long. Techno used to like Hankook sealed lead acid and I had a pair of those which lasted 5 years then I had a pair of Varta sealed lead acid which are still going strong but I have not long changed to Lithium.
Max recommended discharge of 50% so if you have 2x100 ah batteries it's recommended you don't discharge below 50% which would be 100 ah, Gels can be taken to 20%.Without sounding thick - where do you get 100 amps from?
I think you may be right but I haven't really got another way of checking them apart from leaving them on charge for 2 days including solar. I really need to try giving them a load separately but we're living in the van!Not really, I think your being fooled by the voltage coming from the charger and/ or the solar panel. This is what your seeing rather than the true state of the batteries. It will take many hours to fully charge a depleted battery and its very difficult to measure a battery state when thete is a load on it.
I need to do more homework - I thought AGM & GEL batteries were the same.Max recommended discharge of 50% so if you have 2x100 ah batteries it's recommended you don't discharge below 50% which would be 100 ah, Gels can be taken to 20%.
I'm very worried the wife won't like it if we're in a pub carpark & we have to use torches & cuddle together for warmth! I think I'll wait till we get homeYou could do it if you are on EHU and use lights, TV etc., as a load but it's a slow process and best to do each battery seperately so probably best left until home.
Our failed in Greece we managed to get by with 200 Watts of solar and not using the TV.
I agree Barti Ddu. I don't think they are kapput.Has the TV actually turned off, the lights gone out, or the heating fan stopped whirring at any point? If not - then you're golden. Why the worrying!
Actually, I'm not convinced that your batteries are kapput. Just like the voltage will read higher than the actual standing voltage when charging, it will also read lower than the actual standing voltage when discharging. If you're not on EHU, and it's after sunset so no solar input, and you've got the TV on, the lights on and the heating fan running, there will be a significant voltage drop across the battery, just as you are experiencing. Once all the loads are turned off, check the voltage again after 30 minutes and I suspect it's significantly higher. In particular, the fan for blown air heating can cause the voltage to read lower.
I've got a Victron Smart Sense Battery monitor which graphs the voltage of my leisure battery over time and it is interesting to see the voltage drop caused by running various appliances, and how quickly the voltage recovers when the appliances are turned off.
If it's rainy and cloudy then you'll really struggle to get enough back into any battery with solar this time of year unless you're outside the UK somewhere. You'll need to see the 14v charge for quite a few hours to replenish the power that the heater motor uses to blow the gas warmed air around through the night.I have to say we only have one solar panel & I don't know what rating it is but it's performing really well - looking at the controller it was putting power out even in the rain/clouds!
Some information for you about these batteries. There is also a cheaper version (LDC2) just been released too.Thanks - I'll have a look at them.
