What is the life of gel batteries? (14 Viewers)
Oct 8, 2014
1,732
3,357
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
The D250S is a dual charger, with MPPT solar and a 20A B2B, charging from the alternator/starter battery. The lower left input is from the alternator/starter battery, the lower right output is to the leisure battery.
I have a. CTEK D250S on my van, but without the Smartpass. It seems to do a good job of charging my 2x 110Ah LA batteries. You cannot change the battery profile, and it is NOT suitable for Lithium. There is a newer version (D250SE) that caters for various batteries, including Lithium.
Apr 26, 2015
3,380
8,068
Ottershaw
Hymer S820
First motorhome May 2021
I had three lead carbon gel batteries from Alpha Batteries that lasted less then three years, they started to go down hill after being on hookup for two winters according to the shunt they'd never been lower then 50%, I've now gone to lithium.
TheLifeofBrian
Sep 7, 2020
318
271
Hymer T588SL
Getting there!
Did they replace them under warranty as they have a 5 year guarantee?
TheLifeofBrian
Sep 7, 2020
318
271
Hymer T588SL
Getting there!
No, if you look at the guarantee sheet it's not worth the paper it's printed on.
That doesn't look good. I haven't even got a shunt !
Did you try to get them replaced or not bother?
Apr 26, 2015
3,380
8,068
Ottershaw
Hymer S820
I didn't bother as it would have cost Ā£60 to ship the three batteries back and they would most likely have refused the claim anyway. I chalked it down to experience and Offgrid recycled them for me when they installed the Fogstar Drift.
TheLifeofBrian
Sep 7, 2020
318
271
Hymer T588SL
Getting there!
OK next update!
I got home after driving 4 hours & left the tv & all the lights on & everything was fine for 2 hours!
Next day I plugged into the mains & charged them all day & that night left everything on for 4 hours & still ok!
They were just flat I thought but today I tried my lads MK capacity tester on them (after a full charge) one after the other and the one gave 15% and the other 14% so both obviously knackered :crying:
I'm just trying a pulse charger to see if it makes any difference but I doubt it :swear:
just realised there was audio - luckily I didn't swear!
Feb 6, 2022
76
109
Swift Bessacarr 597
Since 2019
OK next update!
Those voltage readings of 10.6 and 9.6 volts are rather consistent with dead batteries.
Langtoftlad
9,269
160,197
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Presumably you've followed standard advice about separating the pair of batteries - just in case only one is goosed and is dragging the other one down?
Having just had 2 gels fitted, I'm rather hoping they'll last a bit longer than 2 years
TheLifeofBrian
Sep 7, 2020
318
271
Hymer T588SL
Getting there!
Yes they were both charged & tested separately.
Mar 30, 2022
1,767
1,820
Swift Suntor 590RL
I'm still trying to find the cause.....
Could it just be I've taken too much power out of them? I don't really see how, even if I had the satellite & TV on, plus stereo & various chargers for several hours I don't think that would have been more than 15 amps, so even for 5 hours that's only 75 amps (or has my maths failed after 40+ years since school šŸ˜‚) & there are 2 x 110 ah batteries!! Couple that with overcast weather so not much solar power.... :unsure:
I think I'll speak to the battery supplier tomorrow (alpha batteries) & see what they suggest. We're booked into Malvern in 2 weeks so need to get it sorted asap!
Also I'll try testing them individually & see what the results are šŸ«°šŸ«°šŸ«°
If they have died & get replaced I might sell them & bite the bullet & get a lithium - partly to save weight!
Thank you all for your help - excellent Funster advice as usual :clap2:::bigsmile:
If you use your inverter the problem isn't the total amps drawn but the speed at which they are drawn especially with other electrical items being used at the same time.
TheLifeofBrian
Sep 7, 2020
318
271
Hymer T588SL
Getting there!
The CTEK D250S charges the leisure battery from the alternator at 20A, and the CTEK Smartpass boosts this by another 80A to make 100A total. I don't know what size your two Gel batteries are, but I suspect that might be too much for them. For the best long-term battery life, the charging amps should be limited to C/5, where C is the battery capacity. So for two 100Ah gels, that would be 200/5 = 40A. A bit extra might be OK, but I think 20 + 80 = 100A might be too much.
I have just spoken to CTEK & they say:
The CTEK chargers only put in what is required so unless the batteries were discharged all the time then yes but then the voltage and current does drop off and when fully charged the charger switches off.
So that shouldn't have damaged the batteries - the EBL is also set to GEL so I still have no idea what could have caused them to fail???
Coolcats
6,256
11,102
HymerCar Ayres Rock
Hi all,
Anyone any idea what could kill my gel batteries in only 18 months?
April last year I changed both batteries as the old AGMs had died - we got 110ah gel batteries from Alpha & they have been absolutely great all year but got to the Lincoln show Thursday (no ehu) & by Friday night they had both dropped to 11v šŸ˜³
When the sun comes out they read up to 14v but turn a tap on & they drop like a brick to 12v
I've tried disconnecting one of them to see if it's just one dragging the other down but last night (Saturday) it dropped so low it turned the control panel off & the sun had been shining all day & the only thing plugged in was our 2 phones.
This is virtually the same thing that happened to the last pair of AGM batteries!
The only thing I can think is I tried the inverter (that is wired in) with a coffee machine but it wasn't big enough so turned it off.
It's a 600w pure sine inverter with a remote switch:
Other than that the Lincoln show is great šŸ˜ƒ
Any ideas anyone please?
Cheers Chris
Mine are now 7 years old and still fine 2x95Ah
Apr 27, 2016
7,449
8,912
Manchester
A class Hymer
Since the 80s
So, did CTEK give you a number for the amps that will go into a pair of gel batteries discharged to say 50%? I think it will be 20A + 80A = 100A. What amps do they say?
Have you measured the charging amps yourself with a clamp meter? I would imagine the lad who services wheelchairs has one. If not, you know what to buy him for Christmas. :giggle:
CAB96
1,324
2,569
Stockport, UK
T6 Leisuredrive
Autorouter has basically said this twice:
Your batteries should be charged at no more than 40a for the pair (20a each).
Your setup has been charging them at 100a.
QED.
TheLifeofBrian
Sep 7, 2020
318
271
Hymer T588SL
Getting there!
Thanks for pointing that out but I don't think they would have been discharged anywhere near that amount. They have always been charged via the solar which is permanently connected and occasionally EHU but nothing has been used that would take that sort of current to flatten them?
As CTEK say - that is their job to control how much current is diverted to them and I can't see why anyone would fit the extra smartpass if it could overcharge them?
I haven't got a clamp meter but was looking at a smart shunt to monitor them but I think I'm going with lithium which has a smart BMS so I wouldn't need it.
TheLifeofBrian
Sep 7, 2020
318
271
Hymer T588SL
Getting there!
QED.
I can't see why any company would sell a dedicated charger that would overcharge the batteries it was trying to control?
There wouldn't be a need to sell the extra smartpass controller if it could damage them?
If this was the case CTEK would have stopped selling them & no one would install them!
TheLifeofBrian
Sep 7, 2020
318
271
Hymer T588SL
Getting there!
A smart shunt will be much more accurate then the BMS which won't record small discharge/charge
Their selling point is that the battery is the main component & that is what needs monitoring. Their BMS does that - I'm not sure all of them do.
Apr 27, 2016
7,449
8,912
Manchester
A class Hymer
Since the 80s
The first stage of charging is called 'bulk'. The charger is in 'Constant Current' mode. This is not the same as the more usual 'Constant Voltage' mode. In Constant Current mode, the charger pushes out the full amps output that it is capable of. The voltage is whatever results from this. The Constant Current mode continues until the voltage rises to the 'Absorption voltage'. Normally this happens when the battery is about 80% full.
So when the charger is first switched on, if the batteries are at say 50%, they will be charged at the full amps output of the charger.
Don't take my word for it, if you look at Page 23 of the DS250S manual, you can see that happening. After a short desulphation stage, the Bulk stage starts. The current (amps) is constant, and the voltage slowly rises, typical of Constant Current mode. The current (amps) is the maximum the charger can deliver. As far as I know, there is no way to reduce this number of amps.
Some chargers, like the new Victron Orion XS B2B charger, can be set from 1A to 50A in steps of 1A. The Sterling B2B has a half power mode, where a 60A B2B can be set to only give 30A. The small CTEK charger I have can be set to either 5A for a car battery, or 2A for a motorcycle battery.
The DS250S is not adjustable, and neither is the SmartPass. That means the output amps is as I said, 20A + 80A =100A.
For two 100Ah gel batteries I think that is too much. The maximum recommended amps for two 100Ah gel batteries is 40A. @AdrienChen described what is likely to happen in that situation.
The only issue with Gels that I have heard of (and a few years back so may not apply to new stuff like carbon gels....) is that they can "boil" if they are charged too fast at too high voltage, ie bubbles form in the gel electrolyte, that then don't move and are present for evermore, if against the battery plates the capacity is reduced, so it's important to charge, within the battery's specification
To me it seems from your description that is exactly what has happened, the batteries are no good after less than a couple of years, when they should be giving many years of good service.
TheLifeofBrian
Sep 7, 2020
318
271
Hymer T588SL
Getting there!
Thanks for all your comments autorouter - I have emailed CTEK to ask for their comments!
Dec 17, 2019
1,148
2,142
St Leonards, Dorset, UK
Carthago Malibu
Converted caravanner!
You're probably seeing the solar charging voltage the batteries will be flat.
You can't test a leisure battery with a starter battery tester as it won't show you the capacity which is the important bit.
This is the clamp meter most of us use:
Bit of a dark art to me, so how do you use one of these to check if your leisure batteries are ok? Got suspicions about ours.
Jan 19, 2014
9,917
26,427
Derbyshire
Elddis Accordo 105
since 2014
You can't šŸ˜” you have to do a discharge test with a known amperage and after a few hours see what the charge level is by measuring the voltage.
I always think it's a bit like using them, you know if they're getting tired, šŸ¤” actually your suspicions will probably be correct šŸ˜Ž
Apr 26, 2015
3,380
8,068
Ottershaw
Hymer S820
You need one of these to do a discharge test, available on ebay, set a cut off voltage so you don't damage the battery perhaps 50% (12 volts?) set a current load and run the test, it will stop when it gets to the cut off voltage and you will be able to see how many amps were consumed, that will give you an idea of capacity. In this test, the battery dropped immediately to 8.84 volts with a 2 amp load indicating the battery was beyond saving.
