Busy lad here again, C250 toilet cassette, had the MH since May and only done a typical emptying routine, empty, flush out and restock chemicals, after our recent outings I thought it's about time to give the cassette a good going over
out it comes, emptied and flushed then outside to near the hose pipe and the removed the flap mechanism, now I have read that someone broke the sliding flap grooves on theirs by using a lever and the reply was to use something that is a snug fit between the grooves and then twist out, so I whittled bit of wood down to fit, twist and out it pops no damage
Out with the bleach and scrubbing pad and give everything a good clean, all mating faces and rubbers seals seem in good order, all is good or so I thought, I noticed the float was not moving so I gave it a bit of attention cleaning crud off all areas, took the float out to do this, it is then I noticed the magnet embedded in the float had some build up on it thus causing it to rub on the cassette body, scraped this off and it now moves freely so I popped it all back together and primed it up ready to go back in.
At this point I am thinking so what does the float do? after a bit of research I find I have a light on the toilet flush panel that should light when its full, further investigation reveals the reed switch that should be in the cassette housing was missing, all the mountings and wiring are there so I can only assume previous owner must have removed it because the light was on all the time
I found a reed switch on Ebay and have one ordered due next Tuesday and we shall then see it it works.
