Why hasn’t this voltage issue on Lithium batteries been mentioned before ? Is it actually an issue ?
is that a proper MOSFET Regulator /Rectifier or a nasty old shunt type ????
I wouldn't assume the EBL includes voltage control. I could be wrong but it is not something I would expect. Hopefully someone more knowledgeable than me will be along shortly. Motorhome kit should have voltage tolerances that can cope so I don’t see it as a job the EBL should need to do.Is this a problem if the power comes via an EBL rather than directly from battery? I’m assuming that the EBL does some form of voltage control?
Better from the EBL, as would cut-allow power to determined circuits depending on the selection from the panel or the battery status.Is this a problem if the power comes via an EBL rather than directly from battery? I’m assuming that the EBL does some form of voltage control?
It does, as it monitors the voltage and would protect appliances from under voltage.I wouldn't assume the EBL includes voltage control.
The EBL battery monitor unit seems to protect the battery from complete discharge but I can’t see a 12V voltage control role of the type being advocated.It does, as it monitors the voltage and would protect appliances from under voltage.
Most of the devices labelled as 12V, intended for use in a vehicle, will not need any voltage stabiliser. It's only a few devices, the ones that usually have a 12V supply powered from the mains, that require a voltage stabiliser. Putting everything on a voltage stabiliser would, as you rightly say, be a waste of power.This business or running our nominaly 12volt kit on a voltage anywhere from 11.5 to 14.5volts, has often made me think a stabilised supply would be better. However I thought one would use a single Buck Converter regulator for the all the 12volt kit, not fit different units for each item. My one concern is how much power they waste, how efficient are they? I suppose running nominaly 12volt kit on higher voltages mean they would consume more power and get hotter, so perhaps the Buck Converter losses are not so important. Finally how smooth us the output?
Apologies, by "control" I thought you meant the ability to turn on, turn off or protect (battery monitor), not to filter the voltage.The EBL battery monitor unit seems to protect the battery from complete discharge but I can’t see a 12V voltage control role of the type being advocated.
The stabilizer I installed for the Maxxfan has this specifications:This business or running our nominaly 12volt kit on a voltage anywhere from 11.5 to 14.5volts, has often made me think a stabilised supply would be better. However I thought one would use a single Buck Converter regulator for the all the 12volt kit, not fit different units for each item. My one concern is how much power they waste, how efficient are they? I suppose running nominaly 12volt kit on higher voltages mean they would consume more power and get hotter, so perhaps the Buck Converter losses are not so important. Finally how smooth us the output?
Mine has OVP1 (Over Voltage Protection) attached to it. MaxxFan is very picky, but I suspect it is moisture that makes the MaxxFan Deluxe do funny things (I use mine on 'Air In' all night). I cleaned my pcb on the MaxxFan with circuit board spray cleaner and it corrected it immediately and it has lasted for 18 months and counting.I wouldn't assume the EBL includes voltage control. I could be wrong but it is not something I would expect. Hopefully someone more knowledgeable than me will be along shortly. Motorhome kit should have voltage tolerances that can cope so I don’t see it as a job the EBL should need to do.
OVP on an EBL is a mains protection that cuts in at 265V, it is not going to help with the normal voltage fluctuations of the 12V side.Mine has OVP1 (Over Voltage Protection) attached to it. MaxxFan is very picky, but I suspect it is moisture that makes the MaxxFan Deluxe do funny things (I use mine on 'Air In' all night). I cleaned my pcb on the MaxxFan with circuit board spray cleaner and it corrected it immediately and it has lasted for 18 months and counting.
I don’t find the need to regulate the voltage on the 12V side because I buy kit that is designed to run on an automotive power supply e.g. an Avtex tv that comes with a car plug as well as a mains adapter.
Thanks for your informative response. Apuljack refer to the OVP as a 'slow-acting under and over voltage device'.
Yes, it cuts out to prevent a wild over voltage but, surely, it helps to regulate the input voltage to the transformer and thus, in turn it has a stabilisation effect upon the output. GIGO applies?
So GIGO doesn't apply, and the input voltage on a transformer has no effect upon the output voltage?ED O'DARAC I assume you are trying to quote and reply to my posting. Your reply appears to be part of my quoted post which is rather confusing.
No the the OVP will not regulate the battery output voltage.
Not sure where GIGO (garbage in garbage out) comes into this. Anyway it doesn’t apply to the output voltage of a LiFePO4 battery which is what was erroneously claimed to be causing a problem in the video at #1.So GIGO doesn't apply, and the input voltage on a transformer has no effect upon the output voltage?
Thanks for the information.
The battery charger has been designed so that it will output exactly the voltage and amps that the battery needs at that point in the charging cycle. You can even set the voltage by changing the battery type setting. So a Gel will be charged at 14.4V, but an AGM will be charged at about 14.7V. The electronics compensates for the normal fluctuations in the mains input voltage. That should be the same for any 3-stage smart charger, including solar and B2B chargers.So GIGO doesn't apply, and the input voltage on a transformer has no effect upon the output voltage?
That's interesting Paul. I had my maxxfan installed in 2019, and straight of the battery, no step down at all. Voltage is in region of 12.6v min to 14.2v max, mostly 14v max. The components on fan pcb from memory are rated for 15v, my battery will never see that voltage.I rang the UK importer for Maxxfan before I fitted a Maxxfan Deluxe to our van a few weeks ago, and they confirmed that the Maxxfan is still susceptible to over voltage and that an updated control board would likely be fitted to new Maxxfan's later in the year, so I fitted a voltage stabiliser to our Maxxfan.
I strongly suspect that your assumption is incorrect. As far as 12V from the battery going to the "appliances" it just passes the voltage straight through. It will almost certainly manage the voltage from a solar panel, but that's about it.Is this a problem if the power comes via an EBL rather than directly from battery? I’m assuming that the EBL does some form of voltage control?
Not come across an EBL with built in solar controller.I strongly suspect that your assumption is incorrect. As far as 12V from the battery going to the "appliances" it just passes the voltage straight through. It will almost certainly manage the voltage from a solar panel, but that's about it.
My understanding is that very few are making a living purely from YouTube anymore. You've got to have sponsors and a generous Patreon following. And/or sell a lot of merch. Several of that media companies that were backing the bigger channels have collapsed, which is why lots of familiar faces are appearing in new channels which they've set up themselves.Mind you, if he's making money on YT; he's having the last laugh.
Happy Jack.
All I can say is Bob E publishes his YT earnings and without much effort its £16k.My understanding is that very few are making a living purely from YouTube anymore. You've got to have sponsors and a generous Patreon following. And/or sell a lot of merch. Several of that media companies that were backing the bigger channels have collapsed, which is why lots of familiar faces are appearing in new channels which they've set up themselves.
Assuming we're both using the same definition of an EBL - i.e. an Electrobloc that manages the van's electrics - then the one in my Pilote certainly includes a solar controller. Maybe not a very good one....Not come across an EBL with built in solar controller.
What is the model number of the EBL?Assuming we're both using the same definition of an EBL - i.e. an Electrobloc that manages the van's electrics - then the one in my Pilote certainly includes a solar controller. Maybe not a very good one....
