Votronic 1212-30 B2B - *warning*
That would not work. It would constantly blow if lower. You can't use a fuse as a current limiter (well, you could, but single use!)
But it that not what a fuse is for?
13a plug can be fitted with 2 - 13amp fuse to limit current to relevant appliance.
Provided your not pulling more than 30amp through inverter it will not blow.
They shipped a newer model to me yesterday, express, from Germany. Just arrived. I've installed and tested and the old unit is being collected in an hour.
Votronic have told me they don’t want my old one back.
I‘ve been impressed with the service from Votronic.
I think the Votronic VCC 1212-30 is a great bit of kit. It was easy to install by wiring it in to the back of my Schaudt EBL using the existing cabling. I also like the way it will provide a trickle charge to the starter battery when the leisure battery is being charged - no need for a battery master or equivalent.
The new version of the VCC 1212-30 has an additional LiFePO4 setting.
There is now a setting for batteries with an internal heater.
If you are replacing an older unit with a new one, do check the battery switch settings! The previous LiFePO4 setting is now the LiFePO4 with heating.
No it does not limit current. It stops current above that amount (not quite true but keeping it simple) by blowing
Eg if your had an appliance like a kettle that took 10a. If you had a 13a fuse great. If you put a 5a fuse in your would not limit the kettle to 5a (eg it works work but take 2x as long) it would blow instantly and the kettle would not work. Eg you cannot use a fuse as a current limiting device. Try it. Put a 3 or 5a fuse in a10a device like decent kettle or hair dryer and it will blow.
(Assuming the inverter is not getting involved either!)
Terminology maybe?
I will hasten to add I'm taking about blade fuses and UK mains fuses, not any other device or fuse which may or may not be different
Hmm. Downloaded the web version in case different and didn't see that. Sent the manual back in the box with the old unit. (German web version had what your posted above)
Thanks for making me aware. I will check my settings.
Fortunately the BMS will stop cold charging
On mine, there was a warning on the box it came in
Here are the latest manuals in German and an English Google translate version! There doesn’t appear to be a proper English version available yet.
The Votronic web site has undergone a big revamp.
Terminology maybe?
I'm saying it "limits current" by blowing if fuse capacity exceeded.
To reduce the danger of inverter overheating the use of a lower value fuse to limit the max current drawn would work.
We're not talking about the "control" of the current, as that would require a Rheostat.
We're simply looking at stopping an over current and a fuse does that.
Sounds like we are saying the same thing. But back to thread topic, using a lower fuse (which was suggested above to limit current) will not help with this issue with this device as the b2b well always pull max current when the battery needs a charge. So a lower fuse will blow on virtually every use and ok may stop the issue but also renders the device useless as it would never work and may as well be removed.
Many thanx for raising this issue activecampers (y)
Three weeks ago I sent an email to Votronic with the serial number of my 30amp B2B. Today I have just received the new modified unit FOC.
No fuss, no messing around.
Excellent customer service from them !
All the best
Antique
I notice there are two versions of the manual and they give different settings for the dip switches for lithium battery.
The earlier manual says - S1 & S2 up. There's only one lithium option.
The later manual on the Votronic site says (for non heated battery) - S1 down, S2 up. (there's also a setting for heated batteries which is both switches up).
The case design is different too. Does this mean if we have the newer case type we should set S1 down & S2 up (which is the AGM setting in the earlier manual)?
Old manual
Newer manual (German):
Old manual
Your UK link is hosted by 3rd party, not votronic, so go with the votronic guide.
I did change my settings on the new version to match the german version above
System still working perfectly - great bit of kit
Used the 12volt link as that older manual is not on the Votronic site now. They are both Votronic manuals. That is the manual that came with my device (which has the newer case design).
The problem is what is shown as the lithium setting (14.4 volts) for non heated lithium in the newer manual is the setting for AGM (14.7 volts) in the older manual. Very different charge profiles.
It could be even if it is doing 14.7 it may be lower at the battery, but I'd rather 14.4 (in fact I'd like the option to go lower than that, but this model only has one option. Their better models have multiple options).
I've emailed Votronic for clarification.
Here is Votronics response:
'During the life cycle (production period) of an appliance, it undergoes a variety of hardware and software modifications to optimise the product or meet customer requirements. The installation and operating instructions supplied with the device must therefore always be used.
Although the installation and operating instructions provided in the download area always correspond to the current production status, they should be regarded as preliminary information. We are happy to provide installation and operating instructions for devices from older production years as PDF files on request by sending an e-mail to service@votronic.de, stating the article and serial number. Your VCC 1212-30 from 2018 has a charging programme for LiFePO4 batteries. Both dip switches on S1 and S2 must be in the up position.
You can find our manuals in English and French for our product at our website here: https://www.votronic.de/download-en_fr/.'
i am tempted to buy a votronic 30A B2B, mainly because of its size meaning i can tuck it away somewhere quite easily.
does anyone have an indication of which serial numbers were affected by the fuse issue? i understand you can check by looking what colour fuse it is, but i havent bought it yet as im looking at a pre loved one.
any advice or info, especially of performance as some of you have had one for a few years now, is welcome
thanks
You need the third generation or later.
But what serial number or marking denotes the third generation? Potentially if I buy a gen 1 or 2 perhaps votronic will still honour the exchange... I've sent them the serial number of one I am looking to buy ...
Mine was fine for three years before Votronic offered to swap it. Votronic do say that if it is properly ventilated, as per the manual, then it should be fine (as my original one was).
Unfortunately, as we see many times on this forum, professional installers and individuals ignore the ventilation guidelines specified in the installation manuals for B2Bs, solar controllers, inverters and battery chargers. This is true for all makes.
Swapped my 30a Votronic a year back with no problems.
Was very happy with the performance of it but better safe etc.
New one has been just as good producing a steady 30a even in hot conditions.
All the best (y)
Can’t you get the seller to send you a photo looking into the cooling grills?
All the best (y)
Thanks, it's the size that appeals to me, I can tuck it away somewhere. I realise it's only 30A but driving for a couple of hours would replace any power we used the previous day .... So it's only part of the solution along with doubling the amount of lithium and increasing the solar if I can ...
MisterB This is the original one that Votronic swapped out
The serial number started 20V
This is the new one that Votronic sent me to replace the original
The serial number starts 23V
You can see the difference in the fuse position in the first and second one. The fuse in the latest version is much lower down - it’s attached to the PCB. The original one has a black fuse holder so the fuse is much higher up.
My replacement Votronic is working very well.
My van is wired using a CBE 520AN fusebox, with a relay connecting the leisure and starter batteries when the engine is running. The Votronic can be wired in this configuration. But I took the opportunity to adapt the wiring, cutting a resistor on the circuit board to disable the relay. My B2B is now wired directly to the starter and leisure batteries. In this configuration it trickle charges the starter battery when on hookup or solar. A very worthwhile alteration.
Thanks, the info re the serial number is really helpful. I've seen one with the 20V serial number and messaged Votronic, hopefully they will offer to exchange it, I just want to make sure that the seller hasn't already had a replacement issued and is selling the old one !!
I already have a votronic mppt which trickle charges the vehicle battery from solar and the onboard controller trickle charges when on EHU, but your suggestion is helpful, thanks
