Sorry but i cant see the filters, yes its busy.This is my set up, filters are replaceable.
Not much room for anything else !
Those look the same as the Gasgit ones I threw away, I didn't think much of them.
Answer from supplierI would give that one a miss connectors and body are plastic and connections are 12 mm so that means adaptors it would end up a right bodge. Also quite large most gas lockers it's quite tight getting a couple of Truma ones in don't think you would stand much chance with that one.
I would give it a wide berth.
Not suitable then, only any good for fitting after a regulator which defeats the object.![]()
EG Spinner LPG CNG Filter 12mm IN - 12mm OUT
Innovative gaseous phase filter with an universal replacement cartridge Spinner 12mmwww.lpgshop.co.uk
Hello John,
This filter is for low pressure and we don't have any other that will suit your needs.
Regards,
Mario Włodarski
Customer Relation Manager
LPGShop
They are certainly good at misdiagnosis on lpg systems especially refillable cylinders with or without any filters ⚠Looks like an improvement on the older version I have. The only issue I have had is the gloop that collects at the bottom of the filter sometimes bubbles, not an issue until they do a pressure drop test and decide that the shut off valve on the cylinder is leaking. Easily resolved, clean out the gloop before hab check.
What does that mean, leAking?They often try to say that the refillable cylinders are “letting by “
It means leaking from the cylinder into the hose but not a gas escape.What does that mean, leAking?
Yes basically the cylinder shut off valve is allowing gas to pass (letting by )It means leaking from the cylinder into the hose but not a gas escape.
So the black bit is ally?, just looked like plastic. Decent update then if it is and cheaper to service,Forgot to mention it is aluminium not plastic.
I kept getting leaks with the gasit filters thew them & fitted Truma ones.Just to add, I removed my Gas it filters as I couldn't get the new paper filters to fit, there was nothing in the filters except the filter had almost come apart in one.
What are the wires for on the Truma Duo regulator ?
Stop it freezing in very low temperatures they can ice up if you have a high flow rate through them, must admit never turned mine on.I don't understand why the regulator is heated ?
That is a good price, maybe clearing stock as that one has been replaced now.Been having problems with boiler tripping on gas and a 212H fault code displayed on the control panel. Local caravan service centre connected boiler to a diagnostic module yesterday and everything OK. Static and on load tests carried out on regulator, static a smidgeon under 30mb when boiler started this dropped to 24mb hence boiler tripping. Test carried out 5 more times twice it dropped to 28mb and boiler fired up, 3 times 23/24mb and boiler faulted to 212H . New regulator ordered these are £200 ish but on eBay £79.95 delivered.
Truma DuoControl CS Replacement Regulator (G4) | eBay
Find many great new & used options and get the best deals for Truma DuoControl CS Replacement Regulator (G4) at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Old stockBeen having problems with boiler tripping on gas and a 212H fault code displayed on the control panel. Local caravan service centre connected boiler to a diagnostic module yesterday and everything OK. Static and on load tests carried out on regulator, static a smidgeon under 30mb when boiler started this dropped to 24mb hence boiler tripping. Test carried out 5 more times twice it dropped to 28mb and boiler fired up, 3 times 23/24mb and boiler faulted to 212H . New regulator ordered these are £200 ish but on eBay £79.95 delivered.
Last time checked them nothing in the pot and filters clean so not changed them yet.Have the same filters as you Lenny replacement filter cartridges are an insane price
How much are they now they were 20 quid each.Thought I would replace them when fitting the new regulator but not at the prices they are asking nearly as cheap to bin them and replace the regulator![]()
Which type of filter do you have ?How much are they now they were 20 quid each.
