I have used an Allen headed socket hammered into the head to remove bolts before.Robert, have you tried an Allen key of a similar size in the slot, to see if it can find a grip?
Good luck with it.
Cheers,
Jock.![]()
Good luck with it.
Cheers,
Jock.![]()
I use torx as there is many more points of contact than an AllenI have used an Allen headed socket hammered into the head to remove bolts before.
Agreed. It depends on the damage. Sometimes an allen just works with what is left of the head. Sometimes a slightly larger torx. Either way it's a bodge but worth a go.I use torx as there is many more points of contact than an Allen
Ditto success here, hence my suggestion.Agreed. It depends on the damage. Sometimes an allen just works with what is left of the head. Sometimes a slightly larger torx. Either way it's a bodge but worth a go.![]()
How about drilling through the side of the heads and inserting a small bar as a lever to get some force on the bolt heads
Best to drill at the 4 oclock position to give a bit of swing. Use something like an allen key or a drill bit than is less likley to bend.
Try using a pair of pliers on the lever close to the bolt head ti get you a bit more grip.
Keep the hole size as tight to the diameter of the lever you use.
Thankfully it’s only the top one that’s gone
I’m wondering about carefully heating up the head with a soldering iron to make it expand, then hammering in a Torx or Alan bit, then wait for it to cool and contract
As mentioned before..
£3.39 job done
You might not even need to drill it with it being a torx head and not a screw..
Speed Out 4 PCS Screw Extractor Tool Set Drill Bits Broken Damaged Bolt Remover | eBay
4pc Screw & Bolt Extractor Drill Bits & Guide Set, Broken Easy Out Fastener Kit. Durable, hardened steel construction. Removes any screw or bolt! Works with any drill. Even works on jagged, uneven, or rough breaks.www.ebay.co.uk
No it’s a tight fitIf the recess is wide enough around it you may be able to tap a small socket over the screw head and unscrew like a socket nut…?
I’ve done this on wheel locking nuts where I’ve lost the key..![]()
That’s my next option as I’d have to buy oneHammer in torx till very tight then use a impact driver in reverse
Following your journey with interestOrdered !
Looks amazingAs mentioned before..
£3.39 job done
And, nobody has fallen out or been banned yet DebsI can't believe your post has generated 3 pages of replies Robert.
Fingers crossed that the speedout kit works!!!
