Probably depends on how much you sing whilst on the loo ...Those that wax the loo does it make a big difference? or do bits still stick , and will any wax do and how often do you have to re wax .
any quality wax will do, it seals the surface of the plastic resisting anything from sticking (when lubricated)Those that wax the loo does it make a big difference? or do bits still stick , and will any wax do and how often do you have to re wax .
I doubt it will be much use to you unless you have a dedicated flush tank. Many Motorhomes flush straight from the main fresh water tank.What is this pink stuff? I should be picking my MH up this week.
Let the fun begin.
No problem with smell escaping is what I meant.Look the first person on the planet who’s poo smells of roses and not the stuff you put n them.![]()
As the seal is rubber, WD40 may not be the best choice, I would use a silicone spray.I don’t understand the problem. I put no chemicals in just urine, poo, water and paper. Never had a problem with smell I just make sure that the seal is in good condition by spraying with a little WD40 after emptying.
I find that soap weakens the seal on the pressure cooker don’t know whether the cassette seal in the same compound.As the seal is rubber, WD40 may not be the best choice, I would use a silicone spray.
Like the bio capsule idea, will start using them, once I've finished off the blue stuff.
If youve been using the dreaded blue stuff the bio will not work till all traces of the blue are out of the system.As the seal is rubber, WD40 may not be the best choice, I would use a silicone spray.
Absolutely, silicone or olive oil but nothing petroleum based.As the seal is rubber, WD40 may not be the best choice, I would use a silicone spray.
