- Dec 25, 2015
- 1,639
- 33,106
- Autotrail Tracker FB
- Since 1998
What is a SOG, please?
A device for extracting the stink from your loo and blowing it into your neighbours awning.What is a SOG, please?
When we collected our new van, the chap who was doing the hand over, said that he used fabric softener, so may well give it a try.I find fabric softener reduces any smell and breakers up the poo in the cassette
Thanks. I think I've got a SOG and didn't realise what it was. Is it the noisy thing that comes on when you press the flush button and it wakes everyone up in the middle of the night? If so, are they efficient at getting rid of smells?A device for extracting the stink from your loo and blowing it into your neighbours awning.
If you change the filter regularly they are good at getting rid of smells. If you don't they just move it somewhere else.Thanks. I think I've got a SOG and didn't realise what it was. Is it the noisy thing that comes on when you press the flush button and it wakes everyone up in the middle of the night? If so, are they efficient at getting rid of smells?
I haven’t got one, but I believe the fan only comes on when you open the flap. If it’s a noise when you flush then it may be the pressure pump you’re talking about? They can be noisy for a short burst.Thanks. I think I've got a SOG and didn't realise what it was. Is it the noisy thing that comes on when you press the flush button and it wakes everyone up in the middle of the night? If so, are they efficient at getting rid of smells?
As never Wild Camped I often wonder what they do with there Toilet waste , do you bag it then bin it or throw it over a hedge or ditch on leave it for someone to pick up or in the extreme do you put bags lined up in the Motorhome to dispose of them properly ? us when on Campsite we empty the toilet about every 2 days so we think Wild Camping is out for us.Its a waste bin for waste of all types in a bin bag knotted whats wrong with that it all goes to landfil or incinerated. Plus it was said in jest as i read post as being lighthearted and amusing.
It is Bio clothes washing liquid or powder, but not in tablet form. It can be in liquid or powder form, but the easiest way is to use the dissolvable capsules of liquid.We too hated the Blue Stuff but then found Fenwick's Top n Tail which we find much more pleasant... However may try Bio tablet.. plenty on here seem to use them.![]()
This will be the Thetford version. It's different to the SOG.I haven’t got one, but I believe the fan only comes on when you open the flap. If it’s a noise when you flush then it may be the pressure pump you’re talking about? They can be noisy for a short burst.
Most informative. Thank you. I now realise I don’t have a SOG, but I do have the Thetford extractor fan. I don’t find it very efficient, but that’s possibly because I’ve never found the charcoal filter and consequently I’ve never changed it. I‘ll take a closer look tomorrow.This will be the Thetford version. It's different to the SOG.
The Thetford is more of an extractor system to eject smelly air from the cassette to the outside (via a tiny charcoal filter that needs frequent replacement - about every 4 weeks worth of equivalent use) so you don't stink out your MH when using the convenience. One is fitted to my van. The fan is small, hence the noise in operation as it has to spin fast to achieve any air movement. As I go to the loo, before opening the flap, I briefly press the flush button triggering the fan to start and thus creating an lower pressure in the cassette. Once the flap is opened more air gets pulled through the toilet bowl, cutting out those niffs in the MH. The fan runs for about 5 minutes unless you turn it off.
The SOG system is I understand a bit more sophisticated. It is intended to promote the breakdown of the waste in the cassette by drawing air over the effluent and promoting the oxygenation that would help bacteria do the work - a very mini sewage plant. There is probably a much greater volume of air moved.
Maybe Two On Tour uses Chrome.I opened the link but unfortunately it is all in German.
Usually the Thetford filter will be under the toilet cassette. There are two slightly different shapes dependent on your toilet type. Changing the filter might be beneficial for the nose of anyone near your van, but I doubt it affects the efficiency of air movement to stop smells inside your van.Most informative. Thank you. I now realise I don’t have a SOG, but I do have the Thetford extractor fan. I don’t find it very efficient, but that’s possibly because I’ve never found the charcoal filter and consequently I’ve never changed it. I‘ll take a closer look tomorrow.
WD40 is not oil based and will extend the life of the seal as well as improving the efficiency of the blade mechanism. Have been MHoming for 11yrs and never had to replace a cassette seal.Those with SOG type systems may well get away without anything other than natural additives. But realistically for most of us who have limited capacity of cassettes I wouldn't have thought without additives there is enough time for natural SOG systems to have started to effectively break things down. The use of the Bio type stuff kick starts that process. It's not just about what whiffs you might get in your MH or when emptying.
I'd be very wary of using WD40 on the seals to the toilet bowl flap and cassette. So many of the rubberised plastic things will not be compatible with certain types of lubricant chemicals and oils and you may risk damage and deterioration.
I use silicone grease on the sealsWD40 is not oil based and will extend the life of the seal as well as improving the efficiency of the blade mechanism. Have been MHoming for 11yrs and never had to replace a cassette seal.
SOG is a trade name that has become synonymous with the product, like Hoover. Thetford also make a ventilation fan which is often fitted to their toilets. If the ventilation fan is made by SOG it works when you open the blade. If it is made by Thetford it works on the first press of the flush button.I haven’t got one, but I believe the fan only comes on when you open the flap. If it’s a noise when you flush then it may be the pressure pump you’re talking about? They can be noisy for a short burst.
Look the first person on the planet who’s poo smells of roses and not the stuff you put n them.I don’t understand the problem. I put no chemicals in just urine, poo, water and paper. Never had a problem with smell I just make sure that the seal is in good condition by spraying with a little WD40 after emptying.
As never Wild Camped I often wonder what they do with there Toilet waste , do you bag it then bin it or throw it over a hedge or ditch on leave it for someone to pick up or in the extreme do you put bags lined up in the Motorhome to dispose of them properly ? us when on Campsite we empty the toilet about every 2 days so we think Wild Camping is out for us.![]()
good thinking I have a spare cassette ,my son asked me 2 Christmases ago what present I would like , he couldn't get over it, any how took it to Spain never used it , now Isolating on Campsite , and original has broken slide, what a relief to have a spare !!Could buy a spare cassette and wild camp for four days? Providing you have somewhere hermetic to store the full one!!![]()
Does the full one not travel well in the underslung carrier?Wouldn't be without our spare cassette. Only used a couple of times but extremely useful when needed! It's stored in a carrier under the van so out of the way. When it's full it's stored in a black bag in the garage.
The previous owners of our new-to-us MH had used the blue (formaldehyde) liquid which we rinsed out thoroughly before swapping to Elsan green, which has been excellent; really effective and usable with septic tanks. When that runs out we will certainly try the bio sachets trick.NB for those who have used Blu type chemicals you need to ensure there is no trace left of those if you are swapping to more environmentally friendly systems like Bio washing liquids.
isn't it soft before it lands in the cassetteI find fabric softener reduces any smell and breakers up the poo in the cassette
I know how you all like a good toilet thread!
We have a 7.3m motorhome with a toilet and shower in it. A lot of sites want you to use your own facilities now, toilet blocks may even be shut. We have always had a rule - no number 2's in the motorhome loo! We have stuck to this for 5 years.
OH is very squeamish and I may have to take this emptying role on. We use the blue stuff in there all the time and have a bottle of pink stuff which we have never used, the cartridge being dealt with by sterilizing tablets when we come home.
Any tips anyone can give me? Do you empty on a daily basis? Do you clean with pink stuff after every emptying? Any other words of wisdom?!
I also wondered how much grime and mud the underslung ones pick up when on the road, as have been considering getting one.
