That is an AJAX feature so might be the forward proxy. I am going to investigate to see if there is anything I can do but I doubt it sorry. It will resolve itself when your ISP updates the DNS. You could try rebooting your computer and router to clear the cache if you haven't already?I appear to have the new server but when I type in search for a member no suggestions come up as they did previously. Any suggestions?
Pauline
Are all those difficult words taken from the Welsh languageYou seem to think I don't know what I am doing. But it seems you don't understand how DNS works in the real world vs theory perhaps?
Just a little polite explanation.
The TTL on our domains were set to 15 minutes over a week ago during the initial planning stages. It was previously 2 hours.
The bit that you perhaps don't know or understand fully is that ISP's like BT etc will ignore the TTL for their ADSL customers if they are set below a certain threshold. From my very long experience this appears to be 12 hours for a lot of ISPs and for some as much as 24 hours. So no matter how low I set the the TTL some ISPs will ignore it.
A further bit of information, just for you as I didn't want to get too technical in this thread.
Last night after the migration was complete I enabled port forwarding on the old server for port 80 and 443 to forward them to the new server using IPTABLES, a technique I have been using since 2012 with 100% success rate..
For some reason although this worked initially it started failing after 10-15 minutes and leaving the connection to hang and timeout. I spent an hour or two trying to solve it, but in the end Jim and I decided it was better to have the holding page of the old server rather than a connection timeout like that. Also it was causing the networking daemon to hang causing ALL new connections on all ports to hang. My existing ssh connection was ok, but if that had got disconnected during a failure I would not have been able to recover without a full server reboot which is not desirable.
This morning after some sleep I decided to implement a forward proxy in nginx on the old server which proxies just this one site. Not as elegant as the firewall port forward as it has to be done on a site by site basis and this server has multiple sites.
So to respond to your "I would sugest not". I have been doing this since 1997. I have migrated many thousands of servers in that time. I have 100% success rate/score across multiple freelance services.
So suggest away![]()
I won't lose any sleep over your lack of confidence
PS:
The nginx proxy method is a handy one I have used in other scenarios. But never needed for a server migration before. So this will be a method I keep in my back pocket for the next migration where a port forward fails to work (hopefully never does).
At least it's not just merb62 works fine for me. I think your issue is probably unrelated. Have you tried clearing your browser cache and cookies?
I don't doubt it is happening. I am just limited on what I can do to fix it. I suspect it will clear on it's own when your ISP finally gets around to updating it's DNS.
After reading this I ham retiring to a dark room completely.You seem to think I don't know what I am doing? But it seems you don't understand how DNS works in the real world vs theory perhaps?
PS:
All good now....
It is possible you are flip flopping between the servers. Should settle down.I found the new server, however i have to log in every time i try and access it on my Iphone. I have ticked remember my details, but if doesnt.
Im using a shortcut that i did when on the new server. Laptop seems to be fineIt is possible you are flip flopping between the servers. Should settle down.
Can you test now please? Might need to do a hard refresh of your browser.It took a while but I'm here now but I have no gifs or smileys I think they got left behind Jim can you send a van to fetch them?
You are still flip flopping between the old servers IP and the new servers ip.My only issue seems to be I keep getting logged off after about 15 mins.
Even in the middle of reading a thread, suddenly I get inundated with adverts.
Log back in again and I'm OK for another 15 mins or so.
Note:
I always default my setting to NOT 'stay logged in'
(30+ years in IT, so I only ever save log in's/passwords to a secure area, not on the PC or Google memory)
Interesting - was reading the forum just now [several topics and pages loaded no problem] & it suddenly came up with Bad Gateway 502 on my Brave browser. Switched to Chrome, same message.
Yet perfectly fine on my phone, same wifi network
Turned on my VPN and forum loaded as normal.
Was it the Chrome/Brave browsers having a glitch?
Edit:
Switched off VPN, everything seems ok
You were hitting the old server until 10:48 am today. Then 25 minutes ago you came from a new ip address directly to the new server.Can’t get fun in my iPad, was fine last night but no matter what I do as in clearing cookies and history and deleting motorhomefun favourites.. luckily can get it on my phone but I’m hotspotting to my phone..![]()
You should still be able to get in.
What's gone again, you are still posting and not seeing any activity from the old IP?It’s gone again…
I give up
