CaptainPaul
- Apr 15, 2017
- 1,817
- 16,649
- Carthago Malibu ⛱
- Since 1980s
I always got around 20 - 22 mpg in my bigger vans (3.0L Iveco engines) so sounds about right Tam
It's the alko chassis on mine and torsion suspension on that (well it looks like that,but what do I know) it has the grease nipple's on each end ,will get the back end lifted off ground and greased up today.Yours being fiat though could be completely different to mine. Mine has a truck chassis and it's all torsion beam suspension etc . The fiat is very different.
Aye on the rear.It's the alko chassis on mine and torsion suspension on that (well it looks like that,but what do I know) it has the grease nipple's on each end ,will get the back end lifted off ground and greased up today.
Just off to garage now.
I've no checked it properly yet . Really need to take a note of how many litres I put in and then do it at the same point again . I never let it get lower than the quarter mark on guage as never that accurate . And if the fuel price is high like the one yesterday I don't fill it I just put enough in till I get a cheaper stationI always got around 20 - 22 mpg in my bigger vans (3.0L Iveco engines) so sounds about right Tam
Aye I realised I've mucked that up lol.Tam I make 600 kms to be around 375 miles ( 600\ 8*5) and 90 ltrs be around 20 gallons,
So around 18.75 mpg
Worse than my Aston Martin!Tam I make 600 kms to be around 375 miles ( 600\ 8*5) and 90 ltrs be around 20 gallons,
So around 18.75 mpg
So around 18.75 mpg
I rest my case your honour. You forgot to convert the Kms to Miles, before multiplyingAre you sure of your calculations jock . By my rough way of doing it that would put you at 30mpg
I reckon I'm around 20mpg
Don't really notice any difference garry to be honest. Apart from that vibration on front left it was always smoothSpeaking of tyres, now you’ve done a few miles how are the maxxis….
Aye I realised that afterI rest my case your honour. You forgot to convert the Kms to Miles, before multiplying
by 4.54.
Thanks Phill D.
Cheers,
Jock.
Have you tried swapping the front wheels side to side ?Don't really notice any difference garry to be honest. Apart from that vibration on front left it was always smooth
For rough mileage from Garry's, it should be on your MOT.Right not the best way to figure it out but according to my polarsteps I've done 601 miles since I left garrys ( not convinced thats correct) . And from looking at my bank statement I've put in £185 of diesel.
So if I divide £185 by average £1.35 per litre
Which is roughly 137 litres
So 600 miles divided by 137 litres, then multiplied by 4.556 to get the gallon gives me
Is that right?
I will try and remember to take note of mileage the next time I fill up
Chances are that's already happened. It's got different front wheels from what it had when I bought it. And then different tyres fitted on those wheels later. Still does it. I don't think it's the wheel or the disc. Its a suspension or steering component. But I can't feel any play side to side or up and down from the wheel. The steering wheel has sat at 11 o'clock rather than 12 since I bought it and if I let the wheel go it drifts to the left. But no sign of uneven wear on tyres etc either. On some road surfaces it does feel like the tyre is bouncing up and down so it may well be a weak shock on that side.Have you tried swapping the front wheels side to side ?
That would show whether it's a tyre or rim problem.
It's been out and about a lot since that was done. Mot was done in Wales.For rough mileage from Garry's, it should be on your MOT.
I used to do all that but don't bother much now. I think my first few long trips I posted our departure mileage etc and updated it daily and all fuel and lpg costs etc. But you forget sometimes or it becomes excessive .Tam Polarsteps is never correct as it does straight line distance
We have always bought a small notebook and written down every time we fill the price, trip miles, total miles and where we bought it, plus the price. We have done that with every car and every motorhome we have ever had. And we quite often when we sell the vehicle pass on our little notebook and start a new one with the next vehicle.
So when you’re waiting at a few station and somebody in front of you is writing in their book, you know why.
Carol
Not an engine mount it's definitely suspension or steering.Have you eliminated worn/perished engine mounts or maybe a CV joint?
If I remember right, the MOT this van had wouldn't have found anything.Not an engine mount it's definitely suspension or steering.
No cv joints on this as its rear wheel drive. My guess is a track rod end, tiebar or the shock . But the components on this vehicle are bigger than your average van and as such it is hard to find any play just checking by hand ..
By rights a thorough mot should have picked up something but sadly unless a shock absorber has signs of leaking they generally don't pick it up.
Gas shocks are almost impossible to detect bar the drive of the vehicle.
That's why I said a thorough mot.If I remember right, the MOT this van had wouldn't have found anything.
Check the distance between the top of the tyre & the top of the wheel either side to see whether you have a spring that has sagged.The steering wheel has sat at 11 o'clock rather than 12 since I bought it and if I let the wheel go it drifts to the left. But no sign of uneven wear on tyres etc either.
