MANGOFORTH
No that just something I haven't got round to do get ?Window handle still on the outside?
Yes we have a rough plan. Raised floor at, the front, storage underneath, water-tanks under aswell. U shaped Kitchen on the raised floor, tanks go under he cupboards. Bathroom to the right of the door. At the back, sofa on one side so we can see out the window, then opposite sofa a big wall storage cupboard unit thing for clothes and the rest, cut out in the middle of the unit for the tele (obviously). Bed is at the back above the window on a pully/rail/hand winch contraption thingy (or as jasmine called it "a hinch") that drops down to just above the sofa so we can see out the window again. Then in the middle more stuff and things ?
Swings and roundabouts. I don't have a garage so... The layout has been set around our needs and wants. I've watched almost every video on YouTube and picked out the bits I liked. Lots of odd things that I'm sure many people will turn their nose up at. For example, all our electrics will be retrofit in an aesthetically pleasing conduit, simply because it will be easy to add on and change things.View attachment 333585
I shall have to get you one of these. ??
On another note your description of the interior has put doubts on how I was going to lay mine out now. Damn it. I was going to put the bed at the back, high up and have the "tail lift" be the access to the garage under the bed. But as you say, you can't sit in the "lounge" and look out at the view if the bed is there. Grrr.
Well the space under the cupboards will be lost space, unless it dropped down into the void, but then getting the stuff out the bottom will be annoying. It is space saving, will be small tanks linked together so can still get them out. Also it won't freeze in the winter. Also...... When I fitted the glass in the side window, I dropped it. Bounced off my leg and landed corner first onto the ally. Pierced a hole in the panel ? its not strong without the insulation glued to it yet. So seemed like a good place for a water fill inlet ?Why don't you put tanks on outside the same as a fuel tank ? You could even use an old fuel tank for grey water, that would stop the fuel syphoning !! And a nice ally one would polish up nice. Make plumbing, and emptying easier, also easy to flush through and clean .
Cupboard space then freed up for storage.
It would be equally easy if the conduit was out of sight within the walls.in an aesthetically pleasing conduit, simply because it will be easy to add on and change things.
I assume because there was no front cowling to deflect the wind?I'm still at a loss as to what the mpg improving blunder was... rear bumper fell off?
Ally won't rust, only reason the frame isn't ally is the expense. And also there's 17 sheets, 4 edges a sheet. Sooo thats 127 meters of butt welding... no thanks ?
The next one will be different. I already regret so much. But that part of building stuff I geuss, learn and move on.a bit late now i know but you could have bought it on a roll, when my old motorhome was reframed i used ally rolls for the sides, not the easiest thing to move about (my rolls were only 4.5m) but you have the room around the truck, there is also a company in holland that would do the modern motorhome sandwich sides to your own design spec with all the holes cut out for windows etc
Mangoforths Hierarchy of Needs?The next one will be different. I already regret so much. But that part of building stuff I geuss, learn and move on.
I spent all my life building better and better , never got to use them , enjoy , believe me I’ve had all the tee shirts not worth it, but hea ho I’m not here to preach good luck and have fun.???The next one will be different. I already regret so much. But that part of building stuff I geuss, learn and move on.
What does that mean? ?Mangoforths Hierarchy of Needs?
Maslows - play on wordsWhat does that mean? ?
Just has a look, seem to remember that from business studies at school. I'm still on the bottom tier I think ?Maslows - play on words
They say buy your third motor home first! So I suppose build your third motor home first works too?The next one will be different. I already regret so much. But that part of building stuff I geuss, learn and move on.
it would be contaminated with dirtHas anyone ever set up guttering to fill up water tanks?
It has been done on some larger self-builds I believe but ONLY to use for flushing the toilet rather than consuming so a lot of hassle really for little gain. In a 'static' home situation it would be a different matter as they would likely get through a lot more water with a domestic toilet.Has anyone ever set up guttering to fill up water tanks?
That's what filters are forit would be contaminated with dirt
What sort of things do you regret?The next one will be different. I already regret so much. But that part of building stuff I geuss, learn and move on.
