Lenny HB
- Oct 18, 2007
- 60,791
- 193,119
- Carthago Compactline
Taking the wires out the ebl is impossible without unplugging all the top cables and lifting the ebl out the cupboard ..no way to get to the wiresTwo jump leads clipped to get her is not a good idea, when we spoke yesterday you said you were going to get a new cable.
What you could do but you won't like it as its a pain with where your EBL is. But you could take the starter & leisure battery cables out of the EBL and join then with a terminal block a bit of 30 amp choc block will do for the test. Then see what the current is with the EBL by-passed.
Then check the current with the EBL connected best to do this test first.
Between test put a load on the batteries for at least ½ hour otherwise you will get confusing results.
Whilst doing your testing leave the ammeter in one place (clipped around the leisure battery negative (earth) connection). There is no point in taking current measurements anywhere else. Take a current measurement charging via the EBL - note reading. Without disconnecting anything connect your jump leads from the starter battery +ve terminal to the leisure battery +ve terminal. Note the current reading.Taking the wires out the ebl is impossible without unplugging all the top cables and lifting the ebl out the cupboard ..no way to get to the wires
It was hard enough to put voltmeter on them.
I'll have a look but don't think it's possible
Will see what other cable I have too but not promising anything
When you say the leisure battery earth wire do you mean at the actual leisure battery? Or the earth wire below ebl ?Whilst doing your testing leave the ammeter in one place (clipped around the leisure battery negative (earth) connection). There is no point in taking current measurements anywhere else. Take a current measurement charging via the EBL - note reading. Without disconnecting anything connect your jump leads from the starter battery +ve terminal to the leisure battery +ve terminal. Note the current reading.
I mean the negative wire or wires connected to the leisure battery negative terminal. Just leave the meter in the same position throughout your testing.When you say the leisure battery earth wire do you mean at the actual leisure battery? Or the earth wire below ebl ?
I never knew you got current going through the earth lead .....learn something new every day lol
Thats why Lenny HB is panicking lolWow, this is getting complicated. Soooooooo glad i'm not you Tam doing this!!!!Just being a bit forward so excuse me, but, would a trip to tonyidle be an idea? If he was ok with that? Lenny is obviously way to far. Is Kendal a long way?
Yeah, poor Lenny. It's really interesting to follow, but i would have lost the will i think by now. Still i guess your going to be so much wiser after you've cracked it & maybe a bit proud of yourself too?Thats why Lenny HB is panicking lol
He's worried incase I haven't fixed it by the time I head south and pop in
Hopefully if we can pinpoint whats causing the problem then its just a case of changing that item.
I dunno like ...ive not a clue whats causing it I'm just hoping one of these two can figure it oot lol.Yeah, poor Lenny. It's really interesting to follow, but i would have lost the will i think by now. Still i guess your going to be so much wiser after you've cracked it & maybe a bit proud of yourself too?
Yes original wiring in place but that 14 amps is with jump lead connected alsoThat sounds good is that with the standard wiring?
If so it looks like your poor connection on the leisure batteries could have been the problem.
I would have liked to have seen more than 25 amps but your van has a lot longer cable run than mine. My starter & leisure batteries are 2m apart with the EBL in the middle.
That is because you have double the wire size an reduced the volt drop.Yes original wiring in place but that 14 amps is with jump lead connected also
Without jumplead its only around 11amps
I think that's the best you'll get. Rewiring from the EBL to the leisure battery with heavier cable would improve things as Lenny suggests but TBH, now you know there's no fault with EBL or wiring, I'd install a good B2B device for your type of use (short stays all off grid). The B2B would increase the charge rate dramatically and compensate for any voltage drop.
Yeah i have one of those cigarette voltmeters which is where i seen the 17v once ...but it did only do it once no idea whyI think that's the best you'll get. Rewiring from the EBL to the leisure battery with heavier cable would improve things as Lenny suggests but TBH, now you know there's no fault with EBL or wiring, I'd install a good B2B device for your type of use (short stays all off grid). The B2B would increase the charge rate dramatically and compensate for any voltage drop.
Keep an eye on your alternator. If you really did see 17v at one point it is on the blink. A cigar socket plug in voltmeter is dirt cheap & handy. You only have to see it stay over 14 & under 15 when travelling to know that all is well.
The price of fish?What are we gonna talk about now??
Thats the thing everything looks clean and tight. The terminals on the leisures weren't the best before but all done right nowIf anything I would clean up all the cable ends & connections so that you know all are ok.
