I don’t know a lot but my thinking is towards the starter motor not quite being right.....
I do know the differenceYou are running before you can walk Tam. The current will vary a bit as the battery starts to accept a charge.
1. Have you got solar disconnected?
2. Connect the lead direct between the batteries with the 50 amp fuse removed like you did yesterday. Measure the current through the lead.
3. Remove lead replace fuse so it is back to standard.
4. After the last test the battery will have come up a bit so put a bit of a load on it for ½ hour.
5.Now measure the current with engine running.
When you have done that I will give you a couple of other things to try.
As Garry says it is starting to look like it might be the alternator but as he doesn't know the difference between the alternator & a starter motor I wouldn't worry too much at the moment.![]()
I do know the differencebut as you Yourself know Lenny 12 midday is still too early For my brain....
What brain?I do know the differencebut as you Yourself know Lenny 12 midday is still too early For my brain....
Right we have a slight problem lolYou are running before you can walk Tam. The current will vary a bit as the battery starts to accept a charge.
Well above my pay grade,,if it doesnt work after hitting it with a hammer its a job for the garage,,BUSBYRight we have a slight problem lol
While I was doing my jump lead test I discovered that really my connections at leisure batteries wasn't too great so I decided to remove all the battery terminals and redo all the connections...
Of course while doing that I have reset the bloody panel and dumped all my water etc ...so the dt201 is now requesting a full charge as it thinks my batteries are half charged.
But
I've had it running now about 10 minutes and on initial startup I had 15amps going in and its only dropped to 10amps and seems to be staying around that at the minute which is higher than ive been getting so far
In 10 minutes with engine running its raised it from 80ah to 82ah
So tightening the connections seems to have helped somewhat at least.
But to reset panel ill have to connect 240v till tomorrow I think
Still putting out 10 / 11amps just now which is more than beforeForget the panel for now.
I'm using a heavy duty jump lead but I have to join 2 together to reach the batteries.I would expect the results to be the other way unless your cable is not heavy enough and you are getting a volt drop across the cable.
Measure the voltage at each end of the cable.
Have you ever tried just 1 leasure battery, in case there was a problem with some of the other batteries in your bank. As in that one maybe not wanting to take a charge , if that is even possible for a battery to go faulty and stop requesting current for a charge.Right we have a slight problem lol
But
Yeah you could say that lolGetting exciting now,,BUSBY,,,Sorry Tam it must be doing your head in,,
Didn’t someone mention bad earths....?I'm now getting the same 10.5amp input from 240 hook up as I was getting from the engine ....hmmm![]()
Yes it might be worth looking at the ends to chassis terminals?Didn’t someone mention bad earths....?
The problem with diagnosis from a distance is that it is very difficult to explain exactly what tests are needed to someone with, on his own admission, very little basic electrical knowledge. The steps are:The suspense is killing me! After gawd knows how long,and a number of very useful suggestions as well as some daft ones,the solution must be imminent..........surely!!!!!!!!!!!!!!!!!!!!!!!!!
OR....is this the technical query that even the best brains on MHF can’t answer????????...... Maybe?
I do wish you’d get on with it and we can get back to gassing,wilding/parking,payloads,toilet threads and water ingress....again!
OK well having just been to let dogs out for a pee the batteries are now back at 100% and panel should reset itself overnight.The problem with diagnosis from a distance is that it is very difficult to explain exactly what tests are needed to someone with, on his own admission, very little basic electrical knowledge. The steps are:
Check all terminals for corrosion.
Make sure that the fridge is off.
Use only one measuring instrument and, in particular, ignore the EBL control panel.
Disconnect or disable any source of charge other than the alternator
Check alternator voltage under the heaviest load you can present to it.
Check the voltage at the leisure battery when it is under 80% and loaded with as much as you can give it.
If the two voltages are within 3% of each other voltage drop isn't a problem
If they are not check the voltages into and out of the EBL.
At this point you will know where any volt drop is occurring and can look for problems.
Measuring current has not been of any importance up to this point and so far we have proven there is:
No fault in the EBL
No fault in the wiring
No poor connections
Now is the time to do a current test. If, with 80% or less in the leisure battery and as much load as you can offer, you do not see a substantial current flow then you can consider the alternator. But, and IMO it's a big but, I cannot think of or imagine any way a generator can develop a fault that limits its output current whilst maintaining the correct voltage at its output. Note it is irrelevant at which point you measure the current so I'd suggest the best place is on the leisure battery negative (earth) connection.
Now those, to me, are a set of simple tests that should take perhaps an hour to perform including head-scratching and a tea break. But to someone who has no theoretical knowledge of electrickery even describing how to physically perform those tests is an exercise in gobbledegook. No disrespect to Tam is intended - not only does he struggle with limited knowledge of the subject but he has work to attend and other calls on his time. And if he carries on as patiently as he has been we'll get there in the end.
mine is an e box and it seems the 12v supply just goes in and back out theres two connectors both 3 wires plus minus and d plus think is just a convienient way for the ebox and loom supplied to connect. convertor just connects from battery and d plus input which is also used for the split charge most of my wiring apear to have been made for a nine metre van and coiled up under cupboaNothing to do with the charging problem but I realised how and why the fridge is wired like it is.
Tam's fridge has a relay on the back that switches the 12v but it is still wired via the relay in the EBL the reason for this is so the fridge can be run of the habitation batteries if required.
