RedFrame
Yes, they're full of itInteresting, do people with posh Black waste tanks rubbish more than us lowly cassette owning fraternity.![]()
Red.
Errrrrmmmm, can someone remind me of the “correct” arrival time ? Asking for a friend with rejection phobia…..or as @Langtoftlad said I'd put them on the less desirable pitches.
We are there! If that doesn’t put you off, then you are safe!Can someone point me to the post with the list of attendees please?
If you want the bestest pitch 20.minutes before everyone else .Errrrrmmmm, can someone remind me of the “correct” arrival time ? Asking for a friend with rejection phobia…..![]()
And when are they arrivingIf you want the bestest pitch 20.minutes before everyone else .![]()
20.minutes after meAnd when are they arriving![]()
Before youAnd when would that be…….
Pretty please…![]()
The clubhouse is usually located between Ditcha and Tonks motor home's so don't worry too much about location.What's the pitching plan?
Earliest arrivals in the furthest corner of the field - or prime location closest to the club house?
Earliest is 1500hrsErrrrrmmmm, can someone remind me of the “correct” arrival time ? Asking for a friend with rejection phobia…..![]()
So will be there at 14.30... is that okay?Earliest is 1500hrs
Ahh, so that's why I've had a pm indicating that I should attend the bash at Thetford on the 30th.There isn't one, Jaws keeps that under his hat, so it's a surprise for all
No! But it’s a bit like Trebor Mints, shove em up your arse and they last a bit longer! Ie instead of emptying everyday or so it’s every 8 - 10 days, and then………look out if you can’t emptyInteresting, do people with posh Black waste tanks rubbish more than us lowly cassette owning fraternity.![]()
Yeh, it's kind'a got a hard shell with a nut inside.And a very nice hat it is too!![]()
No it isn’t John! If I get there at 3pm there will be at least 20 vans parked up, and I know who most of them will be,Earliest is 1500hrs
You should see a Dr about thatThe good news is…… I’m all emptied, good for another 3 or 4 weeks poopoopadoo![]()
No! But it’s a bit like Trebor Mints, shove em up your arse and they last a bit longer! Ie instead of emptying everyday or so it’s every 8 - 10 days, and then………look out if you can’t emptypoopoopadoo!
t$$$T
No it isn’t John! If I get there at 3pm there will be at least 20 vans parked up, and I know who most of them will be,![]()
You should see a Dr about that![]()
I did, that’s why I’m all emptiedYou should see a Dr about that![]()
Make sure your empty for Bridlington as the elsan would be a bit of a challenge for your vanI did, that’s why I’m all emptied![]()
Of course Peter. Not sure it helps to tell everyone though?All this chat about arrivals and pitch, if you want to be pitched on 1 of the 12 EHUs with stand pipe then it is wise to bribe the marshals.
That is normal, isn’t it meanders ?
I presume we are having the same winnings quiz team again this year, see you at the the BashAll this chat about arrivals and pitch, if you want to be pitched on 1 of the 12 EHUs with stand pipe then it is wise to bribe the marshals.
Its knit one, pearl one, same as last year!I am still fretting about the absence of a pitching plan!![]()
