Seems even Elon won’t go up thereThere is no point pointing north in the UK as there will be very few satellites in that direction.
I think there are several you tube videos re mesh extenders ...Thank you. I meant using more than one to extend the range through the house.
Wouldn't use mesh extenders as they compete with each other "badly", impacting peak speeds possible.I think there are several you tube videos re mesh extenders ...
Yes we have the original starlink router in hallway with the starlink Ethernet adaptor then plugged in to a 4 into1 ethernet splitter a cable from which goes in to our lounge to a TP-link router. Before we got 40 mbs in lounge,17" walls now we get 250>300.Has anyone used Starlink at home with more than one router in the house? Does it work?
The issue we have is the 4k streaming, we had mesh network setup -> but when you have 4k blueray copies on a local server, the rates required to stream them are > 100Mbit constant. The mesh network mode couldn't cope and the TV bufferred a lot. We did start with our Ubiquity in wireless mesh mode.I have Orbi satellites as a mesh network house and garden with a BT router. No speed degradation at any of the access points - I get around 70mbps from BT into the house and experience same everywhere in house and garden
OrbiI is a good system but not cheap per satellite
Yes, it IS from netflix and for that I have no issues.Just checked t’internet and 25mbos is sufficient for 4K stream with Dolby atmos is the advice
20 MBit for data? Seems wildly OTT..The audio alone is about 20Mbit.
Oh it is, total overkill, but the spec is ridiculous, it truely sounds amazing, but it's telling that most TV's can't support the TrueHD except in passthrough mode.20 MBit for data? Seems wildly OTT..
Lossless does not mean uncompressed though? 20Mbit may be the stream size but is it the bandwidth requirement?Oh it is, total overkill, but the spec is ridiculous, it truely sounds amazing, but it's telling that most TV's can't support the TrueHD except in passthrough mode.
That said, it is the actual system used in Cinema's running Atmos, unlike the DD+ Atmos which Netflix etc claim as Atmos, which does sound "okay" but is no-where near as clear. My home system can change between the modes and it's literally night and day on some movies, but completely unnoticable on others.
https://professional.dolby.com/tv/dolby-truehd/2 -> as it says "up to 18Mbit on blueray", with overheads its' 20Mbit on wire when you actually throw it over tcp/ip networks.
The key bit is it's lossless so literally bit for bit the actual master recording ... unlike almost every other encoding format out there.
Looks very similar to the all in one StarMount 12Volt conversion, but they do have a 12Volt/48volt step up transformer integrated into the casing/ mount.It's ALIVE, Frankenstarlinkstein is alive, 12v supply direct to the hacked dish!
So it does work .... but do I have the time or inclination to sort out a one cable feed or just stick everything together as it is ....View attachment 904092
I'm still working on my case, though at around £30 it's a hell of a lot cheaper, but that doesn't make mine a better solution though, just a different solution.....Looks very similar to the all in one StarMount 12Volt conversion, but they do have a 12Volt/48volt step up transformer integrated into the casing/ mount.
thats the conundrum for me aswell - hence my current 'design'. i do like the idea of simply arrive and switch on, but im not sure re losing the advantage of putting it wherever i want to get max signal - decisions, decisions ..... im probably going to stick with the option of keeping it portable at the moment and because its a hell of a lot smaller, storing it away shouldnt be as much of an issueWhy would you want to fix it to your roof. I have mine on my roof with magnets, but in Spain, on 1 in 4 or 5 sites I can't have it on the roof because of obstructions. Being able to plonk it somewhere on your pitch, (or on someone else's) has been critical for me.
I have the standard router in a static caravan in North wales and the starlink mesh router in the fellas next door 5 or 6 metres away who I let use the connection, the improvement is hardly noticeable, 150-200mb in the std van, 30-40mb in the meshed van. They are tin walls though?Thank you. I meant using more than one to extend the range through the house.
If you want the best router for Starlink have a look at Pepwave ones - they directly support Starlink (well most things, they are still working on some bits) so you can configure and control the Starlink. It will switch over to a cell connection automatically when Starlink off or down. It’s very convenient but probably not the cheapest!Spoke too soon. I can't establish an internet connection, which I assume is an issue to do with the router as opposed to the technicalities of the connections etc. at least I know it's not an issue with starlink as it wouldn't have updated, so it must be a router set up issue.
I will try q different router but I'm pleased with how it's gone so far. At least I haven't broken anything lol ...... apart from the casing, original router, cable and the odd one or two components being removed from dishy ....![]()
and now its reconnected itself ...... im convinced its a router issue otherwise why would it keep showing as connected ... i am going to leave as it is for an hour and see if it sorts iteslf out, if not then i will try a different router - unless anyone has any suggestions that arent too technical
the router is a GL-inet 1300 ..
Thanks, I've got a small Beryl that runs on 5v and it's 5G and will prob give me what I need. If not then I will look to upgrade ...If you want the best router for Starlink have a look at Pepwave ones - they directly support Starlink (well most things, they are still working on some bits) so you can configure and control the Starlink. It will switch over to a cell connection automatically when Starlink off or down. It’s very convenient but probably not the cheapest!
User error, my crimper didn't close down on one of the contacts so it was showing as WAN not connected. I used my tester and realised there was no continuity between the RJ45's on one of the wires in the ethernet cable.what was the reason why it didnt work before on that router out of interest?
Not a lot of use at our house with no/hardly any mobile signal.It will switch over to a cell connection automatically when Starlink off or down.
