ceejayt
- Aug 12, 2015
- 3,345
- 6,066
- RS Elysian A Class
- Since 2004
A good solution but not something I would be comfortable doing myself
I think I need a solution like yours. A photo of the install would be handyI’ve said this in previous posts but I’ve sikaflexed two 25mm square aluminium tubes to the roof through which I had mounted four m5 stainless bolts/studs with the correct spacing to correspond with the feet on the standard dish mount.
I’ve also sikafleded a smart white (so it doesn’t stand out) quality plastic box (semi designed for the job as it has glands for the cable) to the roof in which I store the majority of the cable in. There is enough mounted through the roof for use inside to place the router where I have it.
In terms of usage, when we ‘arrive’ I just get my telescopic ladder out, climb up and put the Starlink base and dish over the studs, four wing nuts secure it and connect the cable to the Starlink antenna. Very secure for both wind and hopefully light fingered naughty people alike.
Should where I park be obstructed I can get the cable out of the box and put the Starlink antenna somewhere else on the pitch at ground level…
Yes I want to flat mount the panel at some stage, but so far, it’s proved a very easy solution.
Quite a few RV solutions online usually involving a pole and the rear roof ladder or bike rack.Just need an elegant solution for easily mounting it on the motorhome once pitched up where there is clear sky rather than sitting it on the floor and running out the cable.
Would you trust suction pads? I certainly wouldn'ti've seen some with some suction pads on each feet of the stand which would probably work on a flat roof like a motorhome etc.
The authentication they say is similar to GSM (and 3/4/5G) with a SIM card (though with no physical SIM of course). I'd guess it is possibly a Challenge and Response system, but they do throw in Public Key and Certificates into the protocol as well. Starlink has published a white paper which explains a bit, and there have been recent papers and tear-downs at Black Hat. It will be in the dish part that has the security, the other part with the WiFi and power supply is very dumb, and the code has been published for their extender routers based on OpenWrt.So out of the dish and the router, what determines the authentication with the Starlink service? I’m assuming the dish as many are using alternative routers.
Can’t find the post now, but someone suggested they had bought a second kit as a spare and or second service location and will pauses the service. I’m assuming that won’t work if you install at two different locations (or Motorhome and home) as you will overlap on the months you’re switching from one to the other, so can’t get a clean £85 per month with two systems due to the overlapping billing periods.
A guy on Facebook mikeonmoon or similar used suction cups to test it in motion. Eventually moved at 50+ mphWould you trust suction pads? I certainly wouldn't![]()
No way, but if someone is looking for a temp solution just whilst on site. Certainly not while travelling and not in high winds either but better than free standingWould you trust suction pads? I certainly wouldn't![]()
I am currently in quite a windy coastal location. The only thing stopping it flying of the roof is it’s weight and the lead going through my roof vent. I will see if I can get a couple of small bags of sand later as whilst so far it’s ok the big gusts of wind are a concern
Indeed it is. Mine has stood just outside the awning with the dish cable tucked under the Fiamma PatioMat. Been researching VPN arrangements for our trip to France next month as apparently you still need a VPN for British TV reception in the EU. A very helpful person who lives in Jerez, Spain with an SL recommended a Pyramid VPN micro router https://www.pyramidwifi.comI think so many are being ordered someone is going to start offering professional installation. They would be inundated I reckon
The system is so easy, been using it all weekend with multiple grandkids connected and adults. Worked like a dream it is a game changer for travelling in Europe
For me at the moment suction pads seem a great idea !!! So far gusts of 26mph have not dislodged my dishyWould you trust suction pads? I certainly wouldn't![]()
i think if stationary these would be perfect but not whilst driving of course.For me at the moment suction pads seem a great idea !!! So far gusts of 26mph have not dislodged my dishyit remains in place
I have used suction cups for everything from holding internal screens up to mounting external antenna.For me at the moment suction pads seem a great idea !!! So far gusts of 26mph have not dislodged my dishyit remains in place
our VPN is set up on the firestick which we have used in a few mainland EU countries aswell as the UKIndeed it is. Mine has stood just outside the awning with the dish cable tucked under the Fiamma PatioMat. Been researching VPN arrangements for our trip to France next month as apparently you still need a VPN for British TV reception in the EU. A very helpful person who lives in Jerez, Spain with an SL recommended a Pyramid VPN micro router https://www.pyramidwifi.com
Very small mains powered unit £30 to buy and £6.99 30 day contract.
Links by WiFi to the SL router so no need for ethernet cable unless you prefer it.supports up to 15 devices.
Looks like job done to me.
Told you the roof was dirty…
A few pics of the roof mount I’ve fitted as promised. Working perfectly and nice and secure for wind and scroates.![]()
Also means that Flatty Mcflatface can point/orientate in any direction so you can get maximum signal strengthView attachment 761631
No room for it on my roof.
Yes, but how do you fine tune Flatty McFlatface's critical direction, depending location across Europe, without getting up there and adjusting the angle MisterB Dave, Carpmart Harvey?Also means that Flatty Mcflatface can point/orientate in any direction so you can get maximum signal strength
Via a motor? Thanks Tom?the app/dish determines the best direction automatically.
Thanks Harvey.Automatic innit!!!![]()
