Solar use recharging cycle.
acenip
Armagh
I had a lot of help from the Fun community recently with the setting up of my solar and lithium. I thought I'd start a new chat regarding the use of the various things and recharging. Currently we're enjoying a decent bit of sunshine so that's been useful working things out.
My shunt reading this morning was 74% as shown. From what I've read bringing the ah back to zero is goal. Is this correct? Are there any other stats from this screenshot I need to consider?
bigtwin
Derby
Concorde
It is.
Charge current to zero, and SoC % to 100%.
All things being equal, they amount to, more or less, the same thing.
Ian
acenip
acenip
Armagh
So if there's no alternative power source to charge, hookup, or alternator because we're not driving and the overall charge is dropping each day, what percentage would you expect our appliances to fail to work?
Fiat Based Hymer
One of the advantages of LiFePO4 lithium batteries is that the voltage stays very constant as the batteies discharge.
All of the appliances on our Sterling Power batteries continue to work right down to the point at which the BMS switches off the batteries to protect them.
Not recommended to do that too often !!
acenip
acenip
Armagh
We actually have a 200ah LiFePO4 battery, so good to know we can take it that far. As it's a new installation it's going to take a bit of time to figure it out. The good thing is all the gas stuff is still here if we go to far.
Ottershaw
Hymer S820
First motorhome May 2021
You may find if you allow your battery to get that low that the BMS turns it off that you may have difficulty recharging it again, personally I'd be finding some method of charging it when it gets down to around 15%, go for a drive or get on hookup.
acenip
acenip
Armagh
Good to know. It's all about finding my limits ATM.
acenip
acenip
Armagh
Just returned from a 5 day trip with the new lithium/solar system. My first mistake was allowing our 3 way fridge to run about 7 hours the first day, won't be doing that again. Regardless, overall it was a very good experience. We used our microwave, small airfryer, toaster, travel kettle and espresso coffee machine for 5 days. Each day we lost slightly more than we could recoup, partly due to a couple of rather cloudy days. Our 200ah lithium fell to 35% on our final day. So our usage would need to change if we don't see better solar conditions. Unfortunately we don't have a B2B, probably won't be able to have one fitted without changing our original alternator.
A few more outings would help us figure things out better.
jumar
Spain
Hymer Tramp
Since 1994
Can you explain a little more about not being able to have a B2B fitted with your current alternator? You may have opened up a positive reply or two....
Swift Suntor 590RL
Why is that ?
We have a 2019 Burstner on the Fiat 2.3 150 we have 700 watts of solar 2 x 100 Transporter Lithium and a 12/2000/80 Victron inverter charger. We do not have a B2B as the installer said it is not required, we can easily pull in excess of 90 amps when driving. This system has been in for over 4.5 years and 27000 miles. Works perfectly. The installer warranted it for 5 years and the batteries for 10. The only stipulation is if stationary and running the engine just to charge the batteries no more than 15 mins at a time.
