Sorry people. The dart board is one night only and will come down tomorrow to make space for the musicians.... Reading the thread I shall be packing darts!
No problem Alanyes i can see it thanks. i can pop over tomorrow and bring my wifi iboost to check your settings if you dont mind, so i can see if i am doing anything wrong. we are the ones you spoke to yesterday re your van being a 2014 and ours a 2015 - a bailey autograph parked right in front of the entrance to the club room !
Dave
Did everyone manage the bridge height as our van with dome is taller than our previous one.? Thankyou
Thankyou Carol !Don't go under the bridge Anthea at least that's what Ambilkate says and they live here. Can you put avoid bridge on your sat nav.
ThankyouDon't approach via the bridge. Take the A528 then the B5067.
Anthea it’s best to avoid the town and come in from the north but in saying that if you come through the town it wont be a problem as it doesn’t take you under the low bridge.Did everyone manage the bridge height as our van with dome is taller than our previous one.? Thankyou
Thankyou Dave we are coming from the north!Anthea it’s best to avoid the town and come in from the north but in saying that if you come through the town it wont be a problem as it doesn’t take you under the low bridge.
Its on the way home the problems arise, when you come out of the show ground and come up to the traffic lights do not turn right that will take you to the low bridge and it’s a bugger to try and turn round.
Thankyou DaveHave found funflair old post if anyone is worried about the low bridge.
OK here are the directions for getting to the West Mids Showground SY12PF Gravel Hill Lane should work in your Sat Nav, but its worth familiarising yourself as if you miss the turning from the North A528 you will be faced with the low bridge on Cross Street which a lot of you would fit under but its not really worth the "brown trouser" moment finding out and you will light up the low bridge sign.
If you follow the A49 and then A5124 and then make sure you use the A528 as it saves you getting snarled up in the town if you followed the A5112 (this would still miss the bridge though so no panic)
The X mark cross street where you don't want to be,
The right turn onto the B5067 Berwick Road is the one you don't want to miss so watch for it just after you around the nasty little roundabout (not on my CoPilot map?) and over the railway (bridge not lines), after the turn it's just keep left and onto Gravel Hill Lane with the flats on your left hand side and you will see the showground and the entrance on the left, the gateway is set back in a wide entrance so OK for big vehicles.
When you leave make sure you go the same way as turning right at the end of Berwick Road puts you under the bridge and the low bridge lights will flash and you will wet yourself.
Below is an alternative for anybody who really wants to approach from the West but you need to leave by turning left at the end of Berwick road onto the A528.
You can come in this way as you are going the right way on the one way system BUT you can NOT leave the same way without going under "the bridge" the sign will most likely flash at you but keeping in the left lane is OK.
Martin
Martin and Jen
Seasons greetings and best wishes for safe travels in 2020
Broken Link Removed Quote Quote
Broken Link Removed
Trust me, the low bridge isn’t 20m high.View attachment 354408
If you zoom in on the sign, you will see the low bridge is 20m - even we got under that .......![]()
I thought that was wrong as we came under it last time in our lower van that is a misleading sign!
It really depends on how good their aim is!Yes it will be. ?
Janine. Was waiting to ask if I should remove the dart board. Have now moved my gear out of the way.
After last night, I think the safest place is actually the dartboard itself ...It really depends on how good their aim is!
Thank you Martin, best wishes for 2020 look forward to catching up with you and Jen in the new year.I am getting withdrawal symptoms now, have a great time everybody
Martin
do you need prizes for the raffle?By request, there will be a raffle tonight.
Robin
Yes please, but no panic if folks have nothing to bring.do you need prizes for the raffle?
Dave
