Frankiej
A36 ? Will have to see where that isWhich are the 3 you have already tried. Filllpg shows the Esso on the A36 as having LPG with an update on the 27 July.
looks like Bath....a bit far maybe
It runs from Southampton to Salisbury right along the edge of the New Forest. The fuel station is just a little bit N of the M27. You do not need to go as far as Bath.A36 ? Will have to see where that is
It is on the roundabout where the A36 meets the Romsey Road (A3090).thanks, trying to get the filllpg site to show me...
I think this is bottle gas only now.The Flogas website is showing this one. You would hope that the supplier site more up to date than the apps.
It does show pumped gas on the actual page.
Just called into Birchanger for LPG ... the pump is not working properly due to lack of maintenance according to staff and will shortly be removed.Harlow was my usual stop now if I going north I will use the services at Birchanger on the m11/a120 junction
I can confirm that the Flogas pump should be fixed at Asda High Wycombe just off M40/A404. This was always my preferred pump due to prices. I haven't actually used it, but a cashier confirmed it was operational today.
thanks sod it i will find an alternativeJust called into Birchanger for LPG ... the pump is not working properly due to lack of maintenance according to staff and will shortly be removed.
That is Nun's Bridge Filling Station with a Spar shop which we often use.Bury St Edmunds To Thetford Suffolk, Flo-Gas available at the small garage on the left as you enter Thetford
You are looking at this the wrong way !Update on Flogas
No point in me taking out a "Key Account" down here in leafy Surrey as there are not enough LPG pumps available, 24 hour ones would be a pipe dream.
As for the Flogas LPG Map, once you have sifted out all the bottle suppliers, the only one flagged up is in Cambridge, which I would also verify by phone.
The other one flagged up was near Woking on an ind estate, this also proved to be a bottle only supplier.
Disappointed as I had my hopes up initially, by their quick response, and key account app form, sent next day.
LES
It would have to be a long journey then, even after expanding map to max 50 mile radius Flogas map only shows Cambridge.You are looking at this the wrong way !
You fill on your journey not look for the ones in your area as people have already said it’s only certain areas that are short on pumps
Hinton Service Station
Lyndhurst Road, Christchurch BH23 5LA
LPG price: 0.74 GBP/L (17.08.2020)
Nisa Supermarket
26 Salisbury Road, Bulford, Salisbury SP4 9DQ
LPG price: 0.59 GBP/L (22.08.2020)
Stonehenge Filling Station
A303 High St, Winterbourne Stoke SP3 4SZ
LPG price: 0.599 GBP/L (21.06.2020)
Great, looks like a better site!
The Filllpg map can be very slow to populate when you zoom in but is usually far more up to date for UK sites than myLPG.euI cannot get the filllpg map to zoom into an area! Does anyone know of any autogas stations between Lymington and Trowbridge or else I will have to go out of my way to Romsey en route next weekend! Thanks
The diversion to Ower is not a great distance and since the direct route takes you through lots of narrow New Forest roads it probably won’t cost you much time, if any, to take it. From Cadnam take the M27 instead of the road through the Forest. Go to the first exit and follow the signs for the A36 towards Salisbury (first exit from the roundabout above the motorway). There is short bit of dual carriageway that ends at a roundabout and the Esso LPG station is directly off the roundabout, sharing a site with MacDonalds. Go straight onto the forecourt the LPG pump is on the right hand side of the forecourt. When you have filled go back round the roundabout and take the A36 to Salisbury. You will very soon be back on the shortest route and have missed some narrow roads as well.
Bulford would take you further off your direct route. There is an LPG pump at Codford which is on the direct route to Trowbridge but it is account only and you will need get a Flogas Key Card in advance, it is at the Hillside Cafe. There are 2 sites in Salisbury but one is Shell and due for decommissioning (plus a low bridge from the A36 slip road) and the other looks awkward to get to.
