- Jun 25, 2013
- 2,053
- 5,023
- Old wild camper in transit
Can I ask you personal question what treatment did you have ? No problem if private , but I take a lot of interest in this subject .treatment.
No problem, I was diagnosed with intermediate favourable prostate cancer, 1 of 14 samples on biopsy, Gleason score of 3+4, so all treatment options were available. As all treatment options give similar 10 year “cure and survival” outcomes, I was most concerned with side effects and quality of life. The 2 main potential serious side effects that I wanted to avoid were incontenance and impotence, so for me that weighed in favour of radiation rather than surgery, I elected brachytherapy where they implant seeds into the prostate which over 6/9 months release radiation and kill the cancer cells. Procedure was painless, in and out of hospital same day, side effects have been minor and manageable, mainly going for a pee a bit more often and flow a bit weaker. Sexually mechanics all in working order! It’s a very personal decision, a friend just wanted the prostate out, knowing the cancer was gone, much more serious side effects but peace of mind.Can I ask you personal question what treatment did you have ? No problem if private , but I take a lot of interest in this subject .
Good to hear, I too had 1 of the 14 samples testing positive and a Gleason of 3+3. After numerous information leaflets etc and a comprehensive explanation of all the options by the Consultant, I thought the Brachytherapy would be the best option. Currently though I’m on ‘surveillance’ with a next PSA test in January.No problem, I was diagnosed with intermediate favourable prostate cancer, 1 of 14 samples on biopsy, Gleason score of 3+4, so all treatment options were available. As all treatment options give similar 10 year “cure and survival” outcomes, I was most concerned with side effects and quality of life. The 2 main potential serious side effects that I wanted to avoid were incontenance and impotence, so for me that weighed in favour of radiation rather than surgery, I elected brachytherapy where they implant seeds into the prostate which over 6/9 months release radiation and kill the cancer cells. Procedure was painless, in and out of hospital same day, side effects have been minor and manageable, mainly going for a pee a bit more often and flow a bit weaker. Sexually mechanics all in working order! It’s a very personal decision, a friend just wanted the prostate out, knowing the cancer was gone, much more serious side effects but peace of mind.
If my Gleason had been 3+3 I would have done the same, but knowing there was a bit of “spreading” cancer convinced me to treat it. Good luck for January. If you decide on brachytherapy, let me know if you want more info.Good to hear, I too had one of the 14 samples testing positive and a Gleason of 3+3. After numerous information leaflets etc and a comprehensive explanation of all the options by the Consultant, I thought the Brachytherapy would be the best option. Currently though I’m on ‘surveillance’ with a next PSA test in January.
Very very much borderline ,which is good , luckily such a slow growing cancer surveillance is the way for quality of life , because any treatment is not a free ride .Currently though I’m on ‘surveillance’ with a next PSA test in January.
Friend of mine has recently had brachytherapy. Seems to be doing OK atm. Not sure if he glows in the dark. I'll have to ask his wife.No problem, I was diagnosed with intermediate favourable prostate cancer, 1 of 14 samples on biopsy, Gleason score of 3+4, so all treatment options were available. As all treatment options give similar 10 year “cure and survival” outcomes, I was most concerned with side effects and quality of life. The 2 main potential serious side effects that I wanted to avoid were incontenance and impotence, so for me that weighed in favour of radiation rather than surgery, I elected brachytherapy where they implant seeds into the prostate which over 6/9 months release radiation and kill the cancer cells. Procedure was painless, in and out of hospital same day, side effects have been minor and manageable, mainly going for a pee a bit more often and flow a bit weaker. Sexually mechanics all in working order! It’s a very personal decision, a friend just wanted the prostate out, knowing the cancer was gone, much more serious side effects but peace of mind.
They give you a card to show at airport security in case you set the sensors off! Thankfully on our recent holiday in South Africa I wandered through 8 different security areas and none detected the radiation from the 68 seeds. Helen tells me I don’t glow in the dark!Friend of mine has recently had brachytherapy. Seems to be doing OK atm. Not sure if he glows in the dark. I'll have to ask his wife.
Must of been Mrs God to get back at us men because of all the pmt they have suffered !!!!Only the other day I was thinking along these exact lines..
whoever designed the prostrate had a bad sense of humour ...
Gus, I asked the same question to my consultant his answer was while its possible they don't do it because of all the infections that it causes.I can never understand why they cannot use something similar to how they open up narrowed arteries & blood vessels? Insert an expanding spring from in to out through the prostate & jobs a good un? Only the same as how a catheter works?
Gus if you stop drinking the cola,bitter lemon, and the normal tea and coffee you will be up every 2 hours, try the decaffeinated ones it works for me and stop the carbonated drinks you will find it does help.2hrs for me, sometimes 1,5. Doesn't bother me. straight back to sleep.
I do drink a large amount though,not alcohol, but tea, coffee coca cola. bitter lemon & at least 2 litres of water. Probably at least at least 5 litres/day
I was prescribed TOLTERODINE TARTRATE for the same reason but had to stop after a few days as it gave me incredible headaches.Has any body been prescribed oxybutynin to help with urgency/frequency issues.
I'm half way through my first prescription of these and they have made a tremendous difference
I take tamulosin as well.
Chasnam
Well so far no side effects for me butable to sleep through the night only wake now due to hot flushes.I was prescribed TOLTERODINE TARTRATE for the same reason but had to stop after a few days as it gave me incredible headaches.
I only use Tamulosin ,Has any body been prescribed oxybutynin to help with urgency/frequency issues.
Chasnam
Oxybutynin is a medicine used to treat symptoms of an overactive bladder. These can include:
It's also used to treat bedwetting in children (nocturnal enuresis).
- a sudden and urgent need to pee (urinary urgency)
- needing to pee more often than usual (urinary frequency)
- wetting yourself if you cannot make it to the loo in time (urinary incontinence)
Oxybutynin works by relaxing the muscles around your bladder. This means your bladder can hold more liquid and you do not need to pee as often or as urgently.
Oxybutynin is only available on prescription.
It comes as standard tablets for immediate release, or slow-release tablets (also called prolonged release), a liquid to swallow, or as patches.
I’ve also got a MacMillan cancer charity card the hospital gave me, it’s to show in shops/cafe/hotels etc basically saying my cancer necessitates frequent toilet need and could they please help.There's a useful app called "Flush" which is basically a 'Find my nearest loo'.
went to the hospital today for my biopsy results no good its cancer but its in its early stages so we had a chat to how to go forward and i am to have a bone scan to check ,take a pill for 1 month and a weekly injection to stop testosterone and shrink the prostate then to barts hospital every day for 1 month for radiotherapy and hopefully thats it the consultant is very confident it will be as there is no sign of spread big thanks to Oldrat for the heads up at the beginning . i have had no symptoms at all and still dont so be aware
Welcome to the club that none of us want to belong to!went to the hospital today for my biopsy results no good its cancer but its in its early stages so we had a chat to how to go forward and i am to have a bone scan to check ,take a pill for 1 month and a weekly injection to stop testosterone and shrink the prostate then to barts hospital every day for 1 month for radiotherapy and hopefully thats it the consultant is very confident it will be as there is no sign of spread big thanks to Oldrat for the heads up at the beginning . i have had no symptoms at all and still dont so be aware
Did you or do you have any symptoms I ask as I have none at allWelcome to the club that none of us want to belong to!
I officially joined in early July 2023, now on HT since 27th Sept and now awaiting date for RT.
