Project camper sorting out a damp
Won't be doing nothing today as it sumones birthday
Bill
Try Magnums at Grimsby Bill. Not far from you in Goole .
That's where Ralph got lots of his stuff from when he built Pug. You'll find absolutely everything you need in there , worth a trip over.
I use them a lot thanks
Bill
O'learys at Hull is good too, website shows only a fraction of the stuff they have.
Wouldn't worry too much about the woodwork if i can build a stud partition am sure you will do a marvellous job.
Now to persuade John to put up the floating shelves I bought before I retired, would have done it while he was away but think he has hidden his drill and mine died years ago.
Will be watching this project with great interest, love seeing things being not just restored, but improved.
The culpret is the roof lights very very poor atemps at repar over the years
Ill
As you can see from the piks it been bodge
First thing is removed all the rotation wood almost all the rotation is round the sky lights
The cross members apart from one are Sund
The roof is in three sections three seems the day that made this van I think that only had off cuts Left
Bill
Skylights are often the source of leaks, I think ideally they need to be removed and resealed every few years, the last motorhome I had a few years ago I removed every skylight and every window and renewed the mastic sealant just for piece of mind
On my new motorhome there's a few marks around the large heki sunroof which the previous owner said had been caused by it being left open once but I'm not sure if it's been that or if the seal has failed at some point, having looked at the seal it does seem intact but I'll be keeping a close eye on it.
Is that ductape that someone has stuck around that bill? I know it's good stuff but nit sure it's up to that job
I think once you've resealed all those joints and skylights and redone all the wood it will be good for many years to come.
Big project but a fun one and always a great sense of satisfaction when you've made something better than it was before
Love this thread @Wildbill and @scotzsue, love old things being revamped and recycled, can't believe some of the things that are dumped at the tip and not taken to charity shops. Not brill at diy but just rescued a toy tractor destined for tip and done up for grandson.
As Sue has said looking forward to work in progress! :)
Seconded(y)(y):)
Thing with all that tape, at least you know where it's been leaking ,some good sealant around there and you are half way there(y):)
Starting at the front I have dug out a channel in the insulation to ade more wood this will be inset in to the wall
With a tenon joint dug out of the wall struts.
Gloed then free expanding foam
Used to help fix it in place
Bill
Firs of many new roof struts
Once I have it brace up and nice and solid agane I will remove the old insulation and replace with King span it sumthing like that and Bond everything with poliy urathan fome
And Polly urathan glue
Bill
beware trying to cut a tennon joint into the old wood. I would use a couple of stainless steel angle brackets
I think you are wonderful revamping this old van. I will read your progress with interest.
The duck tape cam with the van previous bodge
By one of the previous owners
Bill
You are fairly cracking on Bill, ain't no stopping you now. Good luck and keep the pictures coming.
Just pope the head outside
Bill
Ha ha I've just been in this very same position, I'm itching to get on the roof of mine and reckon I can get up through the heki sunroof, looks like I've a few bits to touch up with sealant ( previous solar panel mounts left open) and give it a good clean and a Polish
we all crap in a plastic box, in a room the size of a wardrobe, then carry it away to empty it.
We are not all the same...
I don't have a plastic box.
Mine is made of aluminium/insulation/wood composite built on an alloy frame and topped with a one piece, moulded fibre glass roof.
I don't carry anything anywhere... I just drive over the disposal point and open the slide.
Just saying ;)
JJ :cool:
Love what you are doing Bill!(y) Love seeing old knackered things given a new life.(y)
Our Kreg A/Sleeper is just about up to scratch, gonna give it a thrash to Dorset next week, still looking for a good Fridge tho.
Cassette problems sorted with the generous help of @davidbaldam who supplied the parts we needed (y) Many thanks David:D
Ok riped out more rotten wood to find that the alloy roof seems have leaked cusing rot to all the roof timbers
Remove all the roof joyst now and replaced
The one I removed yesterday
The new wood fitted
Bill
Today's gap left by rotten wood
Not the light shining thrug what the rotation wood has caused carosion
This will be treated with a Good clean then panted with steck flex yes when it's clean and dry ruged up it will stick like s:swear2: to a blanket
Every whar wood has been in contact with aluminium and not Ben isolated by mastick has roted the alloy
I will clean up and treet both sides what carosion is obvious
Bill
It's gone all cloudy today down here so I got a bit worried for your open roof.
Looked up forecast for Goole, not a drop in any forecast up to a week on a Thursday. Looks like by luck or accident you have picked a good time for this job.
(y)
