If you really want to go down the route of connecting the solar to the Ecoflow, you'll need a connector. Anderson connectors are better than MC4 for easy disconnection. MC4 are weatherproof, but lock together and need a tool to release them. Or you can snip the locking tabs.
You'll need a changeover switch too, unless you want to unplug and plug in all the connectors.
Two possibilities for the connection. The wires from the solar panel can be connected to the solar panel input of the Ecoflow. Or the motorhome solar controller output can be connected to the 12V charging input of the Ecoflow.
Anderson SB50 (120A) Connector Housing - Grey
Anderson SB50 double pole power connector housing in grey for currents up to 120A. Ideal for making removable high-power connections to batteries.
www.12voltplanet.co.uk
Anderson SB50 Double-Pole & PP75 Powerpole Connector Terminal
Terminals to fit Anderson PP75 Powerpole connector housings and Anderson SB50 Double Pole connector housings
