Whoops ! Forget my post above, I see you have in fact named the site in your post. ![Sneaky :sneaky: :sneaky:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60f.png)
No worriesWhoops ! Forget my post above, I see you have in fact named the site in your post.![]()
Please don't think because the food in your freezer has defrosted you can't refreeze it because you can, the only reason they tell you nor to refreeze is because of the slight deterioration in taste, so slight you won't notice it, don't refreeze if it's seafood as this is more temperamental than meatNot sufficient voltage at Sidi Kaouki to power the fridge. I thought it might have come on at night when everyone switched off, but it has defrostedt......................the low voltage seems to be the norm rather than just at peak times.
Don't really want to use up the gas, so I guess we'll leave tomorrow....................... a warning for others who might just have stocked their freezer at the Carrefour in Essaouira.
Hi Phil, we've had ice once here about 6 days ago but since then we haven't needed the heating on at all so I think the temperature must be on the up, terrible wind last night tho,had to put the satelite dish down at 10pmThis was also our experience when there. Although we were getting 240 V. their was insufficient Amperage to switch our AES fridge to 240 V. and it switched to gas. This also happened at Camping Riad, both campsites stated 6 Amps but this was not the case and they are not bothered as its beyond then to correct and another customer will be along shortly anyway. As for gas, we have been using Butane without any problems at all. In fact, I'm getting towards the end of my first 12 KG bottle. It boils off at -2 Deg.C so will be fine in almost all of Morocco by now , I would think. (It's what the majority of locals are using too). Although, I do suspect there getting below zero degrees at night in Tafroute. (I remember scrapping ice of the motorhome in the mornings on my last two visits there). Quite breezy this morning but not a cloud in the sky, so expecting a better day than yesterday and with better weather moving in from tomorrow onwards.
Do say a little more about what this does........................my understanding is that the fridge, unlike everything else in the van (althought the kettle is a lot slower)will not operate at all below 200v.
In other places it has cut out when everyone puts their lights on in the evening but comes back on overnight.It seems that here the voltage is always below 200 even in the daytime.
I've not seen one of these before Ken. Our 240 V supply is protected by circuit breakers in our P.S.U. so the only concern I would have is the voltage/Amperage is too low. We did manage to boil water with our travel kettle so assumed it was simply too little amperage as a result of numerous French sucking up the power.Basically its a combined step up/step down transformer as I understand it with some sort of sensing facility i.e. voltage too low and its steps it up, too high and it steps it down.
The box is placed in line between the incoming supply and your van, so you will need a Euro two pin socket adaptor on the end of your EHU cable, then a piece of cable with two pin plug on one end, and your van's input socket on the other.
We placed the box under the van beneath the electrical input point.
That's a good Moroccan curry for you !Hi Phil, we've had ice once here about 6 days ago but since then we haven't needed the heating on at all so I think the temperature must be on the up, terrible wind last night tho,had to put the satelite dish down at 10pm
Him indoors is just at the garage I'll let you know how it goes, if not possible to refill it's going to be the red bottle that fits directly on the gaslow system ,140mad inc depositThanks for the info and photos @canopus ......................I have seen something similar under other vans and wondered what they were for..........................something to look out for.
Now thinking the gas is a better option as we can use the heating if needed..............perhaps an orange cylinder but would be interested in @River gypsys getting gas refilled in Tafroute
Now is it the voltage or the amperage that is too low.....................don't suppose it matters there's just not enough oomph.
Also @PhilandMena are you using one of the Moroccan red/orange cylinders.....................we have the pipe from Galow that connects to the fill point and the other end to the local cylinder (it fits perfect to the Moroccan cylinder) but I thought it would only work when the refillable was empty. It would be good to feel confident about the gas cos we could just flip the fridge over and stop worrying
The sun has just come out at Sidi Kaouki but it did rain quite overnight.
Sounds about right ! The refill on its own is around 40 Mad. I will be leaving my 12 KG bottle behind when we leave.Him indoors is just at the garage I'll let you know how it goes, if not possible to refill it's going to be the red bottle that fits directly on the gaslow system ,140mad inc deposit
Has anyone who has a Caxton card worked out if it is better to draw cash from a Moroccan cash point with the Caxton card or a UK Debit card ? Nat West charge 2% or £5.00 per transaction plus another bit depending on the size of the withdrawal. Claxton appear to do the transaction in Sterling then convert the required euros into Sterling and deduct from your balance. It's a mare trying to work the actual costs. I think I might be better off with Caxton but just guessing.
Colin, Hi I trust you and Tina are fine.Phil
I used Caxton extensively whilst we were there and I thought that the rate was competitive and no charges. I would recommend.
Colin
Yes! But it will be butane. I assume you are filling your's this way because you do not have a Moroc bottle.Back with a virtually full gas bottle, seems to be all ok
They are sold extensively all over Maroc because of the poor electricity supply stability problems.
Phil, if I remember correctly Mike & Gwen bought one as well.
Hi All.
An Electric question.
Also any recommendations in the Fes, Azrou, our next stop, area (or elsewhere in Morocco for that matter) for a professional to look at the system as I am concerned about safety.
Thanks in advance.
Regards
Nik.
Thanks @PhilandMena .
Your words are reassuring but I shall still be cautious. Being naked in the rain and mud here might be fun! I'll let you know.
Thanks again.
Nik
hi NikThanks @PhilandMena .
Thanks again.
Nik
