Buy a spare in any case.MLT is now sending me abrupt messages ....
"You better turn off your Water Pump .... "
We are on our fourth one.
(2018 MLT 570)
How much!Looks like it would about £120 - £150 in parts and a day of messing around getting it all to fit.
I'd better double check my parts list first !How much!
Cost me about £60 when I did it on my Hymer.
The Reich 19L/1.5bar pump is fine.Buy a spare in any case.
(2018 MLT 570)
Ahhhh,I'm looking at reconfiguring the pump system with an external Shurflo pump as the flow / pressure is pretty poor with the OEM set-up. Looks like it would about £120 - £150 in parts and a day of messing around getting it all to fit.
The Shurflo type set up in my previous Carthago was a massively superior water delivery system.
I'm wondering whether the interface between the water pump switch and the Hymer Connect can be fooled. The Hymer Connect panel has a touch screen on/off button for the pump.Ahhhh,
But will it text you messages to say it's running hot ?
Don't fix what ain't brokeI'm wondering whether the interface between the water pump switch and the Hymer Connect can be fooled. The Hymer Connect panel has a touch screen on/off button for the pump.
Thinking, redirect the power supply to the existing pump to power a relay which would turn on /off the Surflo pump. That way I could turn the Surflo on and off using the Hymer touch screen and the iPhone app.
If that works .. then yes ... it would still send me a text based on "pump = powered on and tank water level = low".
Well that's the theory anyway ....
That’s a bit sloppy considering the cost.Here's another picture of Hymer cable management - this is under the wardrobe floor.
That is shocking, send some photos to their CEO, maybe he likes to explain it to his customersHere's another picture of Hymer cable management - this is under the wardrobe floor.
Great post! I’m definitely going to add mud flaps to ours.Inspired by LennyHB … I thought I’d start a post to details various mods and upgrades.
I have a brand new Hymer Mlt 580 sitting on my drive waiting for a DVLA to assign a registration number. In the meantime, of course I’m going to take take it apart, fettle and modify it …..
Firstly …. Hymer, why no front mudflaps? Genuine Mercedes parts are £75 a pair, could you not include them as standard?
Anyhow, an easy install as all the fitting points are present and line up perfectly.
Ten minutes per side and a great improvement both practically and visually. Should also save the habitation step mechanism from getting covered in mud.
Part Number: Mercedes-Benz Mud flaps Sprinter 907 front set A9078890600.
View attachment 956641View attachment 956642
About a grand cheaper.How do they compare price wise to the competition, I know that E and P are just over £6000
I've not noticed any extra noise since fitting a Maxxfan, I fitted the original Heki blind.A Christmas Eve mod....
The Maxxfan I had fitted last month is making the cabin road noise levels very uncomfortable.
On investigation I found that EU / UK supplied fans don't have a rubber sealing strip between the hood and the fan casing. This is to allow permanent air flow to the interior. Fortunately you can order a rubber sealing kit which is in the post to me.
In the mean-time I have purchased a natty magnetic Van Compass cover for it.
This required removing the inner flange of the Maxxfan, sticking some magnets to it and refitting. The cover then magnetically sticks to the Maxxfan flange.
View attachment 992806View attachment 992807View attachment 992808
